[petsc-users] Question about SuperLU
Jorti, Zakariae
zjorti at lanl.gov
Thu Jun 9 16:19:51 CDT 2022
I am solving non-linear problem that has 5 unknowns {ni, T, E, B, V}, and for the preconditioning part, I am using a FieldSplit preconditioner. At the last fieldsplit/level, we are left with a {B,V} block that tried to precondition in 2 different ways:
a) SuperLU:
-fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ksp_type preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_type lu -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_factor_mat_solver_type superlu_dist
b) a Schur-based fieldsplit preconditioner that uses SuperLU for both V and B blocks:
-fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ksp_type gmres -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_type fieldsplit -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_fieldsplit_type schur -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_pc_fieldsplit_schur_precondition selfp -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_ksp_type preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_pc_type lu -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_B_pc_factor_mat_solver_type superlu_dist -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_ksp_type preonly -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_pc_type lu -fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_fieldsplit_V_pc_factor_mat_solver_type superlu_dist
Option a) yields the following error:
" Linear fieldsplit_ni_ solve converged due to CONVERGED_ATOL iterations 0
Linear fieldsplit_TEBV_fieldsplit_tau_ solve converged due to CONVERGED_RTOL iterations 1
Linear fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_EP_ solve converged due to CONVERGED_RTOL iterations 5
Linear fieldsplit_TEBV_fieldsplit_EBV_fieldsplit_BV_ solve did not converge due to DIVERGED_PC_FAILED iterations 0
PC failed due to FACTOR_NUMERIC_ZEROPIVOT "
whereas options b) seems to be working well.
Is it possible that the SuperLU on the {V,B} block uses a reordering that introduces a zero pivot or could there be another explanation for this error?
Many thanks.
Best,
Zakariae
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220609/2c7f988d/attachment.html>
