[petsc-users] Generating data on dmplex with varying DOFs
Fri Jul 15 07:13:12 CDT 2022
On Fri, Jul 15, 2022 at 7:08 AM Prateek Gupta <prateekgupta1709 at gmail.com>
wrote:
> Hi,
> Is it possible to generate data using PetscSection with varying degrees of
> freedom? I am building a sample example on a mixed grid (with both
> hexahedra and tetrahedra) and thinking if it is possible to generate the
> face data using PetscSection (or something else) on the resulting. The quad
> faces have p*p data points and tri faces have p*(p-1)/2 data points.
Yes, you can set the size to whatever you want using
  PetscSectionSetDof()
  PetscSectionSetFieldDof()
The DMPlexCreateSection() routine is overly simplistic here since I assume
all k-cells have the same layout.
     Matt
> Thank you.
> Sincerely,
> Prateek Gupta, PhD
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220715/32a476a0/attachment-0001.html>
