[petsc-users] Generating data on dmplex with varying DOFs
    Prateek Gupta
    prateekgupta1709 at gmail.com
    Fri Jul 15 07:07:27 CDT 2022
Is it possible to generate data using PetscSection with varying degrees of
freedom? I am building a sample example on a mixed grid (with both
hexahedra and tetrahedra) and thinking if it is possible to generate the
face data using PetscSection (or something else) on the resulting. The quad
faces have p*p data points and tri faces have p*(p-1)/2 data points.
Thank you.
Sincerely,
Prateek Gupta, PhD
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220715/397757ab/attachment.html>
