[petsc-users] [DMCreate from a Gmsh with mixed mesh crash for DMPlex]
Mike Michell mi.mike1021 at gmail.com
Wed Jul 13 10:41:19 CDT 2022
Thank you for the quick response. Below is the full error message I get.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Argument out of range
[0]PETSC ERROR: No face description for cell type unknown
[0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.17.0, unknown
[0]PETSC ERROR: /home/Mike/Workspace/test on a named Mike Wed Jul 13
10:38:31 2022
[0]PETSC ERROR: Configure options
--prefix=/home/Mike/Library/petsc_partition/install-intel
PETSC_ARCH=linux-gnu-intel --with-cc=mpiicc --with-cxx=mpiicpc
--with-fc=mpiifort --download-fblaslapack --download-metis
--download-parmetis --download-eigen --download-pragmatic --download-hdf5
--download-triangle --with-debugging=1 COPTFLAGS="-O3 -mtune=native"
CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
[0]PETSC ERROR: #1 DMPlexGetRawFaces_Internal() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:312
[0]PETSC ERROR: #2 DMPlexInterpolateFaces_Internal() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:350
[0]PETSC ERROR: #3 DMPlexInterpolate() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:1327
[0]PETSC ERROR: #4 DMPlexCreateGmsh() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexgmsh.c:1634
[0]PETSC ERROR: #5 DMPlexCreateGmshFromFile() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexgmsh.c:1418
[0]PETSC ERROR: #6 DMPlexCreateFromFile() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:4721
[0]PETSC ERROR: #7 DMPlexCreateFromOptions_Internal() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:3212
[0]PETSC ERROR: #8 DMSetFromOptions_Plex() at
/home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:3433
[0]PETSC ERROR: #9 DMSetFromOptions() at
/home/Mike/Library/petsc_partition/src/dm/interface/dm.c:887
[0]PETSC ERROR: #10 User provided function() at User file:0
Abort(63) on node 0 (rank 0 in comm 16): application called
MPI_Abort(MPI_COMM_SELF, 63) - process 0
Mike
> On Wed, Jul 13, 2022 at 10:30 AM Mike Michell <mi.mike1021 at gmail.com>
> wrote:
>> Hi, DMCreate() is used to load/distribute grid built from gmsh, and the
>> function crashes when a mixed mesh of tetra and pyramids in 3D. It looks
>> PETSc can handle the cell types of
>> Tetra/Hexa/Prism/Pyramids/Polygon/Polyhedra in 3D. Thus I am unsure why it
>> crashes when pyramids included in gmsh file.
>> Below functions are used to mesh distribution.
>> call DMCreate(PETSC_COMM_WORLD, dm_g, ierr);CHKERRA(ierr)
>> call DMSetType(dm_g, DMPLEX, ierr);CHKERRA(ierr)
>> call DMSetFromOptions(dm_g, ierr);CHKERRA(ierr)
>> Below error messages got from run.
> I need the complete error message. This is only the stack. I cannot see
> the error message, or the version of PETSc you are using.
> This should work, so I do not immediately know what is wrong.
>   Thanks,
>      Matt
>> Can I get any comments on that?
>> Thanks,
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220713/743f4d9f/attachment.html>
