[petsc-users] [DMCreate from a Gmsh with mixed mesh crash for DMPlex]
Wed Jul 13 10:46:26 CDT 2022
On Wed, Jul 13, 2022 at 10:41 AM Mike Michell <mi.mike1021 at gmail.com> wrote:
> Thank you for the quick response. Below is the full error message I get.
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Argument out of range
> [0]PETSC ERROR: No face description for cell type unknown
Here is the problem. The pyramid (or some other cell) was classified as
"unknown". First, make sure the Gmsh file is version 4.1.
If that fails, send the Gmsh file and I will try to figure out why the cell
is not coming up as a pyramid.
     Matt
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.17.0, unknown
> [0]PETSC ERROR: /home/Mike/Workspace/test on a named Mike Wed Jul 13
> 10:38:31 2022
> [0]PETSC ERROR: Configure options
> --prefix=/home/Mike/Library/petsc_partition/install-intel
> PETSC_ARCH=linux-gnu-intel --with-cc=mpiicc --with-cxx=mpiicpc
> --with-fc=mpiifort --download-fblaslapack --download-metis
> --download-parmetis --download-eigen --download-pragmatic --download-hdf5
> --download-triangle --with-debugging=1 COPTFLAGS="-O3 -mtune=native"
> CXXOPTFLAGS=-O3 FOPTFLAGS=-O3
> [0]PETSC ERROR: #1 DMPlexGetRawFaces_Internal() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:312
> [0]PETSC ERROR: #2 DMPlexInterpolateFaces_Internal() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:350
> [0]PETSC ERROR: #3 DMPlexInterpolate() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:1327
> [0]PETSC ERROR: #4 DMPlexCreateGmsh() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexgmsh.c:1634
> [0]PETSC ERROR: #5 DMPlexCreateGmshFromFile() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexgmsh.c:1418
> [0]PETSC ERROR: #6 DMPlexCreateFromFile() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:4721
> [0]PETSC ERROR: #7 DMPlexCreateFromOptions_Internal() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:3212
> [0]PETSC ERROR: #8 DMSetFromOptions_Plex() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:3433
> [0]PETSC ERROR: #9 DMSetFromOptions() at
> /home/Mike/Library/petsc_partition/src/dm/interface/dm.c:887
> [0]PETSC ERROR: #10 User provided function() at User file:0
> Abort(63) on node 0 (rank 0 in comm 16): application called
> MPI_Abort(MPI_COMM_SELF, 63) - process 0
> Thanks,
> Mike
>> On Wed, Jul 13, 2022 at 10:30 AM Mike Michell <mi.mike1021 at gmail.com>
>> wrote:
>>> Hi, DMCreate() is used to load/distribute grid built from gmsh, and the
>>> function crashes when a mixed mesh of tetra and pyramids in 3D. It looks
>>> PETSc can handle the cell types of
>>> Tetra/Hexa/Prism/Pyramids/Polygon/Polyhedra in 3D. Thus I am unsure why it
>>> crashes when pyramids included in gmsh file.
>>> Below functions are used to mesh distribution.
>>> call DMCreate(PETSC_COMM_WORLD, dm_g, ierr);CHKERRA(ierr)
>>> call DMSetType(dm_g, DMPLEX, ierr);CHKERRA(ierr)
>>> call DMSetFromOptions(dm_g, ierr);CHKERRA(ierr)
>>> Below error messages got from run.
>> I need the complete error message. This is only the stack. I cannot see
>> the error message, or the version of PETSc you are using.
>> This should work, so I do not immediately know what is wrong.
>>   Thanks,
>>      Matt
>>> Can I get any comments on that?
>>> Thanks,
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220713/e4fc8b56/attachment.html>
