[petsc-users] [DMCreate from a Gmsh with mixed mesh crash for DMPlex]
Wed Jul 13 10:36:18 CDT 2022
On Wed, Jul 13, 2022 at 10:30 AM Mike Michell <mi.mike1021 at gmail.com> wrote:
> Hi, DMCreate() is used to load/distribute grid built from gmsh, and the
> function crashes when a mixed mesh of tetra and pyramids in 3D. It looks
> PETSc can handle the cell types of
> Tetra/Hexa/Prism/Pyramids/Polygon/Polyhedra in 3D. Thus I am unsure why it
> crashes when pyramids included in gmsh file.
> Below functions are used to mesh distribution.
> call DMCreate(PETSC_COMM_WORLD, dm_g, ierr);CHKERRA(ierr)
> call DMSetType(dm_g, DMPLEX, ierr);CHKERRA(ierr)
> call DMSetFromOptions(dm_g, ierr);CHKERRA(ierr)
> Below error messages got from run.
I need the complete error message. This is only the stack. I cannot see the
error message, or the version of PETSc you are using.
This should work, so I do not immediately know what is wrong.
     Matt
> [0]PETSC ERROR: #1 DMPlexGetRawFaces_Internal() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:312
> [0]PETSC ERROR: #2 DMPlexInterpolateFaces_Internal() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:350
> [0]PETSC ERROR: #3 DMPlexInterpolate() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexinterpolate.c:1327
> [0]PETSC ERROR: #4 DMPlexCreateGmsh() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexgmsh.c:1634
> [0]PETSC ERROR: #5 DMPlexCreateGmshFromFile() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexgmsh.c:1418
> [0]PETSC ERROR: #6 DMPlexCreateFromFile() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:4721
> [0]PETSC ERROR: #7 DMPlexCreateFromOptions_Internal() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:3212
> [0]PETSC ERROR: #8 DMSetFromOptions_Plex() at
> /home/Mike/Library/petsc_partition/src/dm/impls/plex/plexcreate.c:3433
> [0]PETSC ERROR: #9 DMSetFromOptions() at
> /home/Mike/Library/petsc_partition/src/dm/interface/dm.c:887
> [0]PETSC ERROR: #10 User provided function() at User file:0
> Abort(63) on node 0 (rank 0 in comm 16): application called
> MPI_Abort(MPI_COMM_SELF, 63) - process 0
> Can I get any comments on that?
> Thanks,
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220713/d7c8faf3/attachment.html>
