[petsc-users] Crusher configure problem
Mark Adams
mfadams at lbl.gov
Fri Jan 28 12:07:32 CST 2022
Crusher has been giving me fits and now I get this error (empty log)
13:01 main *= crusher:/gpfs/alpine/csc314/scratch/adams/petsc$
../arch-olcf-crusher.py
Traceback (most recent call last):
File "../arch-olcf-crusher.py", line 55, in <module>
configure.petsc_configure(configure_options)
AttributeError: module 'configure' has no attribute 'petsc_configure'
This is a modified version of the repo configure file. This was working
this AM.
Any idea what could cause this?
#!/usr/bin/python3
# Modules loaded by default (on login to Crusher):
# 1) craype-x86-trento 9) cce/13.0.0
# 2) libfabric/1.13.0.0 10) craype/2.7.13
# 3) craype-network-ofi 11) cray-dsmml/0.2.2
# 4) perftools-base/21.12.0 12) cray-libsci/21.08.1.2
# 5) xpmem/2.3.2-2.2_1.16__g9ea452c.shasta 13) PrgEnv-cray/8.2.0
# 6) cray-pmi/6.0.16 14) DefApps/default
# 7) cray-pmi-lib/6.0.16 15) rocm/4.5.0
# 8) tmux/3.2a 16) cray-mpich/8.1.12
# We use Cray Programming Environment, Cray compilers, Cray-mpich.
# To enable GPU-aware MPI, one has to also set this environment variable
# export MPICH_GPU_SUPPORT_ENABLED=1
# Additional note: If "craype-accel-amd-gfx90a" module is loaded (that is
# needed for "OpenMP offload") - it causes link errors when using 'cc or
hipcc'
# with fortran objs, hence not used
if __name__ == '__main__':
import sys
import os
sys.path.insert(0, os.path.abspath('config'))
import configure
configure_options = [
'--with-cc=cc',
'--with-cxx=CC',
'--with-fc=ftn',
'--COPTFLAGS=-g -ggdb',
'--CXXOPTFLAGS=-g -ggdb',
'--FOPTFLAGS=-g',
'--with-fortran-bindings=0',
'LIBS=-L{x}/gtl/lib
-lmpi_gtl_hsa'.format(x=os.environ['CRAY_MPICH_ROOTDIR']),
'--with-debugging=1',
#'--with-64-bit-indices=1',
'--with-mpiexec=srun -p batch -N 1 -A csc314_crusher -t 00:10:00',
'--with-hip',
'--with-hipc=hipcc',
'--download-hypre',
#'--download-hypre-commit=HEAD',
#'--download-hypre-configure-arguments=--enable-unified-memory',
#'--with-hypre-gpuarch=gfx90a',
'--with-hip-arch=gfx90a',
'--download-kokkos',
'--download-kokkos-kernels',
#'--with-kokkos-kernels-tpl=1',
#'--prefix=/gpfs/alpine/world-shared/geo127/petsc/arch-crusher-opt-cray', #
/gpfs/alpine/phy122/proj-shared/petsc/current/arch-opt-amd-hypre',
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220128/b857e244/attachment.html>
