[petsc-users] Crusher configure problem
Mark Adams mfadams at lbl.gov
Fri Jan 28 12:15:18 CST 2022
Something is very messed up on Crusher.  I've never seen this "Cannot
allocate memory", but see it for everything:
13:11 1 main= crusher:/gpfs/alpine/csc314/scratch/adams/petsc2$ ll
ls: cannot read symbolic link 'configure.log.bkp': Cannot allocate memory
ls: cannot read symbolic link 'make.log': Cannot allocate memory
ls: cannot read symbolic link 'configure.log': Cannot allocate memory
total 25637
drwxr-xr-x  8 adams adams      4096 Jan 20 08:51 arch-olcf-crusher
drwxr-xr-x  8 adams adams      4096 Jan 18 20:23 arch-spock-amd
drwxrwxr-x  5 adams adams      4096 Jan 26 19:10 arch-summit-dbg-gnu-cuda
and
13:11 main= crusher:/gpfs/alpine/csc314/scratch/adams/petsc2$ git fetch
remote: Enumerating objects: 648, done.
remote: Counting objects: 100% (547/547), done.
remote: Compressing objects: 100% (238/238), done.
remote: Total 648 (delta 379), reused 442 (delta 308), pack-reused 101
Receiving objects: 100% (648/648), 591.28 KiB | 1.38 MiB/s, done.
Resolving deltas: 100% (402/402), completed with 114 local objects.
error: cannot update the ref 'refs/remotes/origin/main': unable to append
to '.git/logs/refs/remotes/origin/main': Cannot allocate memory
>From https://gitlab.com/petsc/petsc
On Fri, Jan 28, 2022 at 1:07 PM Mark Adams <mfadams at lbl.gov> wrote:
> Crusher has been giving me fits and now I get this error (empty log)
> 13:01 main *= crusher:/gpfs/alpine/csc314/scratch/adams/petsc$
> ../arch-olcf-crusher.py
> Traceback (most recent call last):
>   File "../arch-olcf-crusher.py", line 55, in <module>
>     configure.petsc_configure(configure_options)
> AttributeError: module 'configure' has no attribute 'petsc_configure'
> This is a modified version of the repo configure file. This was working
> this AM.
> Any idea what could cause this?
> Thanks,
> Mark
> #!/usr/bin/python3
> #  Modules loaded by default (on login to Crusher):
> # 1) craype-x86-trento                       9) cce/13.0.0
> # 2) libfabric/1.13.0.0                     10) craype/2.7.13
> # 3) craype-network-ofi                     11) cray-dsmml/0.2.2
> # 4) perftools-base/21.12.0                 12) cray-libsci/21.08.1.2
> # 5) xpmem/2.3.2-2.2_1.16__g9ea452c.shasta  13) PrgEnv-cray/8.2.0
> # 6) cray-pmi/6.0.16                        14) DefApps/default
> # 7) cray-pmi-lib/6.0.16                    15) rocm/4.5.0
> # 8) tmux/3.2a                              16) cray-mpich/8.1.12
> # We use Cray Programming Environment, Cray compilers, Cray-mpich.
> # To enable GPU-aware MPI, one has to also set this environment variable
> # export MPICH_GPU_SUPPORT_ENABLED=1
> # Additional note: If "craype-accel-amd-gfx90a" module is loaded (that is
> # needed for "OpenMP offload") - it causes link errors when using 'cc or
> hipcc'
> # with fortran objs, hence not used
> if __name__ == '__main__':
>   import sys
>   import os
>   sys.path.insert(0, os.path.abspath('config'))
>   import configure
>   configure_options = [
>     '--with-cc=cc',
>     '--with-cxx=CC',
>     '--with-fc=ftn',
>     '--COPTFLAGS=-g -ggdb',
>     '--CXXOPTFLAGS=-g -ggdb',
>     '--FOPTFLAGS=-g',
>     '--with-fortran-bindings=0',
>     'LIBS=-L{x}/gtl/lib
> -lmpi_gtl_hsa'.format(x=os.environ['CRAY_MPICH_ROOTDIR']),
>     '--with-debugging=1',
>     #'--with-64-bit-indices=1',
>     '--with-mpiexec=srun -p batch -N 1 -A csc314_crusher -t 00:10:00',
>     '--with-hip',
>     '--with-hipc=hipcc',
>     '--download-hypre',
>     #'--download-hypre-commit=HEAD',
>     #'--download-hypre-configure-arguments=--enable-unified-memory',
>     #'--with-hypre-gpuarch=gfx90a',
>     '--with-hip-arch=gfx90a',
>     '--download-kokkos',
>     '--download-kokkos-kernels',
>     #'--with-kokkos-kernels-tpl=1',
> #'--prefix=/gpfs/alpine/world-shared/geo127/petsc/arch-crusher-opt-cray', #
> /gpfs/alpine/phy122/proj-shared/petsc/current/arch-opt-amd-hypre',
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220128/f92b4b19/attachment.html>
