[petsc-users] (no subject)
Bojan Niceno bojan.niceno.scientist at gmail.com
Thu Feb 17 10:45:50 CST 2022
Dear all,
I am experiencing difficulties when using PETSc in parallel in an
unstructured CFD code.  It uses CRS format to store its matrices.  I use
the following sequence of PETSc call in the hope to get PETSc solving my
linear systems in parallel.  Before I continue, I would just like to say
that the code is MPI parallel since long time ago, and performs its own
domain decomposition through METIS, and it works out its communication
patterns which work with its home-grown (non-PETSc) linear solvers.
Anyhow, I issue the following calls:
err = PetscInitialize(0, NULL, (char*)0, help);
err = MatCreate(MPI_COMM_WORLD, A);
In the above, I use MPI_COMM_WORLD instead of PETSC_COMM_SELF because the
call to MPI_Init is invoked outside of PETSc, from the main program.
err = MatSetSizes(A, m, m, M, M);
Since my matrices are exclusively square, M is set to the total number of
computational cells, while m is equal to the number of computational cells
within each subdomain/processor.  (Not all processors necessarily have the
same m, it depends on domain decomposition.)  I do not distinguish between
m (M) and n (N) since matrices are all square.  Am I wrong to assume that?
err = MatSetType(A, MATAIJ);
I set the matrix to be of type MATAIJ, to cover runs on one and on more
processors.  By the way, on one processors everything works fine
err = MatMPIAIJSetPreallocation(A, 0, d_nnz, 0, o_nnz);
err = MatSeqAIJSetPreallocation(A, 0, d_nnz);
The two lines above specify matrix preallocation.  Since d_nz and o_nz vary
from cell to cell (row to row), I set them to zero and provide arrays with
number of diagonal and off diagonal zeroes instead.  To my understanding,
that is legit since d_nz and o_nz are neglected if d_nnz and o_nnz are
provided.  Am I wrong?
Finally, inside a loop through rows and columns I call:
err = MatSetValue(A, row, col, value, INSERT_VALUES);
Here I make sure that row and col point to global cell (unknown) numbers.
Yet, when I run the code on more than one processor, I get the error:
[3]PETSC ERROR: --------------------- Error Message
[3]PETSC ERROR: Argument out of range
[3]PETSC ERROR: New nonzero at (21,356) caused a malloc
Use MatSetOption(A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_FALSE) to turn
off this check
[3]PETSC ERROR: #1 MatSetValues_MPIAIJ() at
/home/niceno/Development/petsc-debug/src/mat/impls/aij/mpi/mpiaij.c:517
[3]PETSC ERROR: #2 MatSetValues() at
/home/niceno/Development/petsc-debug/src/mat/interface/matrix.c:1398
[3]PETSC ERROR: #3 MatSetValues_MPIAIJ() at
[3]PETSC ERROR: #4 MatSetValues() at
and so forth, for roughly 10% of all matrix entries.  I checked if these
errors occur only for off-diagonal parts of the matrix entries, but that is
not the case.
Error code is 63; PETSC_ERR_ARG_OUTOFRANGE
Does anyone have an idea what am I doing wrong?  Is any of my assumptions
above (like thinking n(N) is always m(M) for square matrices, that I can
send zeros as d_nz and o_nz if I provide arrays d_nnz[] and o_nnz[] wrong?
Any idea how to debug it, where to look for an error?
I am carefully checking all the data I send to PETSc functions and looks
correct to me, but maybe I lack some fundamental understanding of what
should be provided to PETSc, as I write above?
    Best regards,
    Bojan Niceno
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220217/9bc3396d/attachment.html>
