[petsc-users] Why is there MAPMPIAIJ
Matthew Knepley
knepley at gmail.com
Thu Feb 17 06:12:26 CST 2022
On Thu, Feb 17, 2022 at 7:01 AM Bojan Niceno <
bojan.niceno.scientist at gmail.com> wrote:
> Dear all,
> I am coupling my unstructured CFD solver with PETSc. At this moment,
> sequential version is working fine, but I obviously want to migrate to MPI
> parallel. My code is MPI parallel since ages.
> Anyhow, as a part of the migration to parallel, I changed the matrix type
> from MATSEQAIJ to MATMPIAIJ. The code compiled, but when I executed it one
> processor, I received an error message that combination of matrix format
> does not support BICG solver and PCILU preconditoner. I took a look at the
> compatibility matrix (
> https://petsc.org/release/overview/linear_solve_table/#preconditioners)
> and noticed that MATMPIAIJ supports only MKL CParadiso preconditioner which
> seems to belong to Intel.
> I did some more reading and realised that I should probably continue with
> MATAIJ (which should work in sequential and parallel), but I am wondering
> why would there even be MATMPIAJ if it supports only one third-party
> preconditioner?
1) MATAIJ is not a concrete type, it just creates MATSEQAIJ in serial and
MATMPIAIJ in parallel
2) MATMPIAIJ supports many parallel direct solvers (see the end of
https://petsc.org/main/docs/manual/ksp/), including
MUMPS
SuperLU_dist
Hypre (Euclid)
CPardiso
There are also parallel AMG solvers, parallel DD solvers, and Krylov
solvers.
The complaint you got said that a serial LU was being used with a parallel
matrix type, so using AIJ is the right solution.
Matt
> Cheers,
> Bojan Niceno
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220217/9aaf79dc/attachment.html>
