[petsc-users] 3.16.4 amd blis libflame linking problem
Fri Feb 4 11:54:51 CST 2022
On Fri, 4 Feb 2022, Anton Popov wrote:
> Thanks Matt, Barry and Satish, for  your suggestions.
> The problem was indeed in mismatch between the gfortran library version
> (system has libgfortran.so.4 libflame needs libgfortran.so.5)
> 3.9.4 did not detect this during configure, but only gave error later during
> test.
> 3.16.4 detected this immediately.
> After installing libgfortran.so.5, both PETSc versions install just fine,
> however I get the warning mentioned by Satish.
Hm - you could install libgfortran.so.5 without the corresponding compiler?
>> /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so
Ah - this is a binary download - not something compiled locally?
I wonder if the compiler gave both an error [return code] and a warning previously [with the missing libgfortran.so.5] - as Barry was suggesting.
As you say - you still get that warning [which is expected - as you are using a different version of gfortran than what libflame.so was built with]
Satish
> Maybe it is indeed worth upgrading everything to the compatible versions.
> Best,
> Anton
> On 04.02.22 18:33, Barry Smith wrote:
> >> On Feb 4, 2022, at 12:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> >> Probably best if you can use the same version of gfortran to build both
> >> petsc and libflame/blis
> >>> /usr/bin/ld: warning: libgfortran.so.5, needed by
> >>> /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so, not found (try using
> >>> -rpath or -rpath-link):
> >> This is probably an ignore-able warning - but configure defaults to -Werror
> >> mode here.
> >    Hmm, if it needs libgfortran.so.5 then it needs it and it cannot be
> >    ignored since a link cannot succeed. Flame presumably contains a lot of
> >    old Fortran code from Lapack so would normally need the fortran
> >    libraries.
> >> Wrt forcing link with static libraries - you can try:
> >> LIBS="/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a
> >> /opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a"
> >> [instead of --with-blas-lib= --with-lapack-lib= options].
> >> Satish
> >> On Fri, 4 Feb 2022, Barry Smith wrote:
> >>> Please do
> >>>   ldd -O /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so
> >>> You may need to list the gfortran library directory of libgfortran.so.5 it
> >>> needs to use in LDFLAGS passed to PETSc configure
> >>> Barry
> >>> Note: Even though you explicitly listed a static library of libflame to
> >>> use our configure is goofy and loses that information and wants to link
> >>> with the shared version
> >>>> On Feb 4, 2022, at 12:00 PM, Anton Popov <popov at uni-mainz.de> wrote:
> >>>> On 04.02.22 17:39, Matthew Knepley wrote:
> >>>>> On Fri, Feb 4, 2022 at 11:35 AM Anton Popov <popov at uni-mainz.de
> >>>>> <mailto:popov at uni-mainz.de>> wrote:
> >>>>> Hi Satish,
> >>>>> I just discovered that PETSc 3.16.4 fails to link against the latest AMD
> >>>>> BLIS and LibFLAME libraries on a Linux box.
> >>>>> You set a value for --with-blas-lib=<lib> and --with-lapack-lib=<lib>,
> >>>>> but ['/opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a'] and
> >>>>> ['/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a'] cannot be used
> >>>>> My previous experience with 3.9.4 on the same system was fully
> >>>>> successful. Looking in the configure logs (attached) reveals small
> >>>>> difference in the linking compared to 3.9.4
> >>>>> Could you please make a guess what went wrong?
> >>>>> Down in the log I see:
> >>>> Thanks Matt, I'll try.
> >>>>> Did the gfortran library move or get upgraded?
> >>>> Not at all. I have configured 3.9.4 just now to make a test, and it
> >>>> perfectly finds all the libraries. So there must be something that 3.16.4
> >>>> does differently.
> >>>> Best,
> >>>> Anton
> >>>>>   Thanks,
> >>>>>      Matt
> >>>>> Best regards,
> >>>>> Anton
> >>>>> What most experimenters take for granted before they begin their
> >>>>> experiments is infinitely more interesting than any results to which
> >>>>> their experiments lead.
> >>>>> -- Norbert Wiener
> >>>>> https://www.cse.buffalo.edu/~knepley/
> >>>>> <http://www.cse.buffalo.edu/~knepley/>
