[petsc-users] 3.16.4 amd blis libflame linking problem
Anton Popov popov at uni-mainz.de
Fri Feb 4 14:17:35 CST 2022
Am 04.02.2022 um 18:54 schrieb Satish Balay:
> On Fri, 4 Feb 2022, Anton Popov wrote:
>> Thanks Matt, Barry and Satish, for  your suggestions.
>> The problem was indeed in mismatch between the gfortran library version
>> (system has libgfortran.so.4 libflame needs libgfortran.so.5)
>> 3.9.4 did not detect this during configure, but only gave error later during
>> test.
>> 3.16.4 detected this immediately.
>> After installing libgfortran.so.5, both PETSc versions install just fine,
>> however I get the warning mentioned by Satish.
> Hm - you could install libgfortran.so.5 without the corresponding compiler?
Yes, apparently it is possible on Ubuntu 18.04.
>>> /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so
> Ah - this is a binary download - not something compiled locally?
Yes it is the latest binary from AMD website.
> I wonder if the compiler gave both an error [return code] and a warning previously [with the missing libgfortran.so.5] - as Barry was suggesting.
It was an error at runtime, configure was just fine.
> As you say - you still get that warning [which is expected - as you are using a different version of gfortran than what libflame.so was built with]
Now since libgfortran.so.5 coexists with libgfortran.so.4 it links
against the proper one, but gives a warning that both versions are
available.
I think I will just compile BLIS and LibFLAME from sources on my system
to avoid these problems altogether.
Best,
Anton
> Satish
>> Maybe it is indeed worth upgrading everything to the compatible versions.
>> Best,
>> Anton
>> On 04.02.22 18:33, Barry Smith wrote:
>>>> On Feb 4, 2022, at 12:27 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>>> Probably best if you can use the same version of gfortran to build both
>>>> petsc and libflame/blis
>>>>> /usr/bin/ld: warning: libgfortran.so.5, needed by
>>>>> /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so, not found (try using
>>>>> -rpath or -rpath-link):
>>>> This is probably an ignore-able warning - but configure defaults to -Werror
>>>> mode here.
>>>     Hmm, if it needs libgfortran.so.5 then it needs it and it cannot be
>>>     ignored since a link cannot succeed. Flame presumably contains a lot of
>>>     old Fortran code from Lapack so would normally need the fortran
>>>     libraries.
>>>> Wrt forcing link with static libraries - you can try:
>>>> LIBS="/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a
>>>> /opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a"
>>>> [instead of --with-blas-lib= --with-lapack-lib= options].
>>>> Satish
>>>> On Fri, 4 Feb 2022, Barry Smith wrote:
>>>>> Please do
>>>>>    ldd -O /opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.so
>>>>> You may need to list the gfortran library directory of libgfortran.so.5 it
>>>>> needs to use in LDFLAGS passed to PETSc configure
>>>>> Barry
>>>>> Note: Even though you explicitly listed a static library of libflame to
>>>>> use our configure is goofy and loses that information and wants to link
>>>>> with the shared version
>>>>>> On Feb 4, 2022, at 12:00 PM, Anton Popov <popov at uni-mainz.de> wrote:
>>>>>> On 04.02.22 17:39, Matthew Knepley wrote:
>>>>>>> On Fri, Feb 4, 2022 at 11:35 AM Anton Popov <popov at uni-mainz.de
>>>>>>> <mailto:popov at uni-mainz.de>> wrote:
>>>>>>> Hi Satish,
>>>>>>> I just discovered that PETSc 3.16.4 fails to link against the latest AMD
>>>>>>> BLIS and LibFLAME libraries on a Linux box.
>>>>>>> You set a value for --with-blas-lib=<lib> and --with-lapack-lib=<lib>,
>>>>>>> but ['/opt/amd/amd-blis-3.1.0/lib/lp64/libblis.a'] and
>>>>>>> ['/opt/amd/amd-libflame-3.1.0/lib/lp64/libflame.a'] cannot be used
>>>>>>> My previous experience with 3.9.4 on the same system was fully
>>>>>>> successful. Looking in the configure logs (attached) reveals small
>>>>>>> difference in the linking compared to 3.9.4
>>>>>>> Could you please make a guess what went wrong?
>>>>>>> Down in the log I see:
>>>>>> Thanks Matt, I'll try.
>>>>>>> Did the gfortran library move or get upgraded?
>>>>>> Not at all. I have configured 3.9.4 just now to make a test, and it
>>>>>> perfectly finds all the libraries. So there must be something that 3.16.4
>>>>>> does differently.
>>>>>> Best,
>>>>>> Anton
>>>>>>>    Thanks,
>>>>>>>       Matt
>>>>>>> Best regards,
>>>>>>> Anton
>>>>>>> What most experimenters take for granted before they begin their
>>>>>>> experiments is infinitely more interesting than any results to which
>>>>>>> their experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>>>> <http://www.cse.buffalo.edu/~knepley/>
