[petsc-users] SNES and TS for nonlinear quasi-static problems
Jed Brown jed at jedbrown.org
Mon Dec 19 07:40:49 CST 2022
Indeed, this is exactly how we do quasistatic analysis for solid mechanics in Ratel (https://gitlab.com/micromorph/ratel) -- make sure to choose an L-stable integrator (backward Euler being the most natural choice). Implicit dynamics can be done by choosing a suitable integrator, like TSALPHA2, with almost no code change to the residual (only adding the mass term in DMTSSetI2Function()).
Matthew Knepley <knepley at gmail.com> writes:
> On Mon, Dec 19, 2022 at 6:12 AM TARDIEU Nicolas via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear PETSc users,
>> I plan to solve nonlinear quasi-static problems with PETSc. More
>> precisely, these are solid mechanics problems with elasto-plasticity.
>> So they do not involve  "physical time", rather  "pseudo time", which is
>> mandatory to describe the stepping of the loading application.
>> In general, the loading vector F(x, t) is expressed as the following
>> product  F(x, t)=F0(x)*g(t), where g is a scalar function of the
>> pseudo-time.
>> I see how to use a SNES in order to solve a certain step of the loading
>> history but I wonder if a TS can be used to deal with the loading history
>> through the definition of this g(t) function ?
> I believe so. We would want you to formulate it as a differential equation,
>   F(x, \dot x, t) = G(x)
> which is your case is easy
>   F(x, t) = 0
> so you would just put your function completely into the IFunction. Since
> there is no \dot x term, this is a DAE,
> and you need to use one of the solvers for that.
>> Furthermore, since too large load steps can lead to non-convergence, a
>> stepping strategy is almost always required to restart a load step that
>> failed. Does TS offer such a feature ?
> I think you can use PETSc adaptation. There is a PID option, which might be
> able to capture your behavior.
>   Thanks,
>       Matt
>> Thank you for your answers.
>> Regards,
>> Nicolas
>> *Nicolas Tardieu*
>> *Ing PhD Computational Mechanics*
>> EDF - R&D Dpt ERMES
>> PARIS-SACLAY, FRANCE
>> Ce message et toutes les pièces jointes (ci-après le 'Message') sont
>> établis à l'intention exclusive des destinataires et les informations qui y
>> figurent sont strictement confidentielles. Toute utilisation de ce Message
>> non conforme à sa destination, toute diffusion ou toute publication totale
>> ou partielle, est interdite sauf autorisation expresse.
>> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de
>> le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou
>> partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de
>> votre système, ainsi que toutes ses copies, et de n'en garder aucune trace
>> sur quelque support que ce soit. Nous vous remercions également d'en
>> avertir immédiatement l'expéditeur par retour du message.
>> Il est impossible de garantir que les communications par messagerie
>> électronique arrivent en temps utile, sont sécurisées ou dénuées de toute
>> erreur ou virus.
>> ____________________________________________________
>> This message and any attachments (the 'Message') are intended solely for
>> the addressees. The information contained in this Message is confidential.
>> Any use of information contained in this Message not in accord with its
>> purpose, any dissemination or disclosure, either whole or partial, is
>> prohibited except formal approval.
>> If you are not the addressee, you may not copy, forward, disclose or use
>> any part of it. If you have received this message in error, please delete
>> it and all copies from your system and notify the sender immediately by
>> return message.
>> E-mail communication cannot be guaranteed to be timely secure, error or
>> virus-free.
> experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
