[petsc-users] SNES and TS for nonlinear quasi-static problems
TARDIEU Nicolas nicolas.tardieu at edf.fr
Mon Dec 19 09:45:21 CST 2022
Dear Matt and Jed,
Thank you for your answers. I'll have a look at Ratel to see how to set-up a quasi-static nonlinear problem with TS and SNES.
Best regards,
Nicolas
Nicolas Tardieu
Ing PhD Computational Mechanics
EDF - R&D Dpt ERMES
PARIS-SACLAY, FRANCE
De : jed at jedbrown.org <jed at jedbrown.org>
Envoyé : lundi 19 décembre 2022 14:40
À : Matthew Knepley <knepley at gmail.com>; TARDIEU Nicolas <nicolas.tardieu at edf.fr>
Cc : petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Objet : Re: [petsc-users] SNES and TS for nonlinear quasi-static problems
Indeed, this is exactly how we do quasistatic analysis for solid mechanics in Ratel (https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fgitlab.com%2Fmicromorph%2Fratel&data=05%7C01%7Cnicolas.tardieu%40edf.fr%7C08e0ffed6942443fe5e908dae1c6c819%7Ce242425b70fc44dc9ddfc21e304e6c80%7C1%7C0%7C638070541137140223%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=9E63JeIqTU1efxC8ij5OaL6XWPcErHbaVAAZwpvPY3o%3D&reserved=0) -- make sure to choose an L-stable integrator (backward Euler being the most natural choice). Implicit dynamics can be done by choosing a suitable integrator, like TSALPHA2, with almost no code change to the residual (only adding the mass term in DMTSSetI2Function()).
Matthew Knepley <knepley at gmail.com> writes:
> On Mon, Dec 19, 2022 at 6:12 AM TARDIEU Nicolas via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Dear PETSc users,
>> I plan to solve nonlinear quasi-static problems with PETSc. More
>> precisely, these are solid mechanics problems with elasto-plasticity.
>> So they do not involve  "physical time", rather  "pseudo time", which is
>> mandatory to describe the stepping of the loading application.
>> In general, the loading vector F(x, t) is expressed as the following
>> product  F(x, t)=F0(x)*g(t), where g is a scalar function of the
>> pseudo-time.
>> I see how to use a SNES in order to solve a certain step of the loading
>> history but I wonder if a TS can be used to deal with the loading history
>> through the definition of this g(t) function ?
> I believe so. We would want you to formulate it as a differential equation,
>   F(x, \dot x, t) = G(x)
> which is your case is easy
>   F(x, t) = 0
> so you would just put your function completely into the IFunction. Since
> there is no \dot x term, this is a DAE,
> and you need to use one of the solvers for that.
>> Furthermore, since too large load steps can lead to non-convergence, a
>> stepping strategy is almost always required to restart a load step that
>> failed. Does TS offer such a feature ?
> I think you can use PETSc adaptation. There is a PID option, which might be
> able to capture your behavior.
>   Thanks,
>       Matt
>> Regards,
>> Nicolas
>> *Nicolas Tardieu*
>> *Ing PhD Computational Mechanics*
>> EDF - R&D Dpt ERMES
>> Ce message et toutes les pièces jointes (ci-après le 'Message') sont
>> établis à l'intention exclusive des destinataires et les informations qui y
>> figurent sont strictement confidentielles. Toute utilisation de ce Message
>> non conforme à sa destination, toute diffusion ou toute publication totale
>> ou partielle, est interdite sauf autorisation expresse.
>> Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de
>> le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou
>> partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de
>> votre système, ainsi que toutes ses copies, et de n'en garder aucune trace
>> sur quelque support que ce soit. Nous vous remercions également d'en
>> avertir immédiatement l'expéditeur par retour du message.
>> Il est impossible de garantir que les communications par messagerie
>> électronique arrivent en temps utile, sont sécurisées ou dénuées de toute
>> erreur ou virus.
>> ____________________________________________________
>> This message and any attachments (the 'Message') are intended solely for
>> the addressees. The information contained in this Message is confidential.
>> Any use of information contained in this Message not in accord with its
>> purpose, any dissemination or disclosure, either whole or partial, is
>> prohibited except formal approval.
>> If you are not the addressee, you may not copy, forward, disclose or use
>> any part of it. If you have received this message in error, please delete
>> it and all copies from your system and notify the sender immediately by
>> return message.
>> E-mail communication cannot be guaranteed to be timely secure, error or
>> virus-free.
> experiments lead.
> -- Norbert Wiener
> https://eur01.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7Cnicolas.tardieu%40edf.fr%7C08e0ffed6942443fe5e908dae1c6c819%7Ce242425b70fc44dc9ddfc21e304e6c80%7C1%7C0%7C638070541137140223%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=a7f7QQi5pGTnaSeqHJmCe5v7S17c4yq%2FSaXGRr0P6w0%3D&reserved=0 <https://eur01.safelinks.protection.outlook.com/?url=http%3A%2F%2Fwww.cse.buffalo.edu%2F~knepley%2F&data=05%7C01%7Cnicolas.tardieu%40edf.fr%7C08e0ffed6942443fe5e908dae1c6c819%7Ce242425b70fc44dc9ddfc21e304e6c80%7C1%7C0%7C638070541137140223%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=iWLeb9jnS8ejiSDgl1JXoIdvLnSKRMZWjogDJta20LE%3D&reserved=0>
Ce message et toutes les pièces jointes (ci-après le 'Message') sont établis à l'intention exclusive des destinataires et les informations qui y figurent sont strictement confidentielles. Toute utilisation de ce Message non conforme à sa destination, toute diffusion ou toute publication totale ou partielle, est interdite sauf autorisation expresse.
Si vous n'êtes pas le destinataire de ce Message, il vous est interdit de le copier, de le faire suivre, de le divulguer ou d'en utiliser tout ou partie. Si vous avez reçu ce Message par erreur, merci de le supprimer de votre système, ainsi que toutes ses copies, et de n'en garder aucune trace sur quelque support que ce soit. Nous vous remercions également d'en avertir immédiatement l'expéditeur par retour du message.
Il est impossible de garantir que les communications par messagerie électronique arrivent en temps utile, sont sécurisées ou dénuées de toute erreur ou virus.
This message and any attachments (the 'Message') are intended solely for the addressees. The information contained in this Message is confidential. Any use of information contained in this Message not in accord with its purpose, any dissemination or disclosure, either whole or partial, is prohibited except formal approval.
If you are not the addressee, you may not copy, forward, disclose or use any part of it. If you have received this message in error, please delete it and all copies from your system and notify the sender immediately by return message.
E-mail communication cannot be guaranteed to be timely secure, error or virus-free.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221219/d88591c5/attachment-0001.html>
