[petsc-users] Seg fault in gdb but program runs
Yuyun Yang
yyang85 at alumni.stanford.edu
Tue Dec 13 00:52:46 CST 2022
Ok I’ll check that, thanks for taking a look! By the way, when I reduce the domain size this error doesn’t appear anymore, so I don’t know whether gdb just cannot handle the memory, and start to cut things off which is causing the seg fault.
Date: Tuesday, December 13, 2022 at 2:49 PM
To: Yuyun Yang <yyang85 at alumni.stanford.edu>
Cc: petsc-users <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Seg fault in gdb but program runs
On Tue, Dec 13, 2022 at 1:14 AM Yuyun Yang <yyang85 at alumni.stanford.edu<mailto:yyang85 at alumni.stanford.edu>> wrote:
Here is the error message:
Program received signal SIGSEGV, Segmentation fault.
0x00005555555e73b7 in kronConvert (left=..., right=...,
mat=@0x555555927e10: 0x555557791bb0, diag=5, offDiag=0)
at /home/yuyun/scycle-2/source/spmat.cpp:265
265 kronConvert_symbolic(left,right,mat,d_nnz,o_nnz);
d_nnz and o_nnz are pointers, and they are supposed to hold arrays of the number of nonzero in each row,
You seem to be passing integers.
Matt
On Tue, Dec 13, 2022 at 12:41 PM Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Mon, Dec 12, 2022 at 9:56 PM Yuyun Yang <yyang85 at alumni.stanford.edu<mailto:yyang85 at alumni.stanford.edu>> wrote:
Hello team,
I’m debugging my code using gdb. The program runs just fine if I don’t debug it, but when I use gdb, it seg faults at a place where it never experienced any seg fault when I debugged it 1-2 years ago. I wonder if this might be caused by the PETSc version change?
The only PETSc calls are the MatGetOwnershipRange() calls, which have not changed, so I think this is unlikely.
Or something wrong with gdb itself? I’ve included the code block that is problematic for you to take a look at what might be wrong – seg fault happens when this function is called. For context, Spmat is a class of sparse matrices in the code:
What is the debugger output?
Matt
// calculate the exact nonzero structure which results from the kronecker outer product of left and right
// d_nnz = diagonal nonzero structure, o_nnz = off-diagonal nonzero structure
void kronConvert_symbolic(const Spmat &left, const Spmat &right, Mat &mat, PetscInt* d_nnz, PetscInt* o_nnz)
size_t rightRowSize = right.size(1);
size_t rightColSize = right.size(2);
PetscInt Istart,Iend; // rows owned by current processor
PetscInt Jstart,Jend; // cols owned by current processor
// allocate space for mat
MatGetOwnershipRange(mat,&Istart,&Iend);
MatGetOwnershipRangeColumn(mat,&Jstart,&Jend);
PetscInt m = Iend - Istart;
for (int ii=0; ii<m; ii++) { d_nnz[ii] = 0; }
for (int ii=0; ii<m; ii++) { o_nnz[ii] = 0; }
// iterate over only nnz entries
Spmat::const_row_iter IiL,IiR;
Spmat::const_col_iter JjL,JjR;
double valL=0, valR=0, val=0;
PetscInt row,col;
size_t rowL,colL,rowR,colR;
// loop over all values in left
for (IiL=left._mat.begin(); IiL!=left._mat.end(); IiL++) {
for (JjL=(IiL->second).begin(); JjL!=(IiL->second).end(); JjL++) {
rowL = IiL->first;
colL = JjL->first;
valL = JjL->second;
if (valL==0) { continue; }
// loop over all values in right
for (IiR=right._mat.begin(); IiR!=right._mat.end(); IiR++) {
for (JjR=(IiR->second).begin(); JjR!=(IiR->second).end(); JjR++) {
rowR = IiR->first;
colR = JjR->first;
valR = JjR->second;
// the new values and coordinates for the product matrix
val = valL*valR;
row = rowL*rightRowSize + rowR;
col = colL*rightColSize + colR;
PetscInt ii = row - Istart; // array index for d_nnz and o_nnz
if (val!=0 && row >= Istart && row < Iend && col >= Jstart && col < Jend) { d_nnz[ii]++; \
if ( (val!=0 && row >= Istart && row < Iend) && (col < Jstart || col >= Jend) ) { o_nnz[i\
i]++; }
Thank you,
Yuyun
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/3fb46fa5/attachment-0001.html>
