[petsc-users] Seg fault in gdb but program runs
Matthew Knepley
knepley at gmail.com
Tue Dec 13 08:35:35 CST 2022
On Tue, Dec 13, 2022 at 1:52 AM Yuyun Yang <yyang85 at alumni.stanford.edu>
wrote:
> Ok I’ll check that, thanks for taking a look! By the way, when I reduce
> the domain size this error doesn’t appear anymore, so I don’t know whether
> gdb just cannot handle the memory, and start to cut things off which is
> causing the seg fault.
It is not the size, it is your arguments. See here
mat=@0x555555927e10: 0x555557791bb0, diag=5, offDiag=0)
Matt
> *From: *Matthew Knepley <knepley at gmail.com>
> *Date: *Tuesday, December 13, 2022 at 2:49 PM
> *To: *Yuyun Yang <yyang85 at alumni.stanford.edu>
> *Cc: *petsc-users <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Seg fault in gdb but program runs
> On Tue, Dec 13, 2022 at 1:14 AM Yuyun Yang <yyang85 at alumni.stanford.edu>
> wrote:
> Here is the error message:
> Program received signal SIGSEGV, Segmentation fault.
> 0x00005555555e73b7 in kronConvert (left=..., right=...,
> at /home/yuyun/scycle-2/source/spmat.cpp:265
> 265 kronConvert_symbolic(left,right,mat,d_nnz,o_nnz);
> d_nnz and o_nnz are pointers, and they are supposed to hold arrays of the
> number of nonzero in each row,
> You seem to be passing integers.
> Thanks,
> Matt
> On Tue, Dec 13, 2022 at 12:41 PM Matthew Knepley <knepley at gmail.com>
> wrote:
> On Mon, Dec 12, 2022 at 9:56 PM Yuyun Yang <yyang85 at alumni.stanford.edu>
> wrote:
> Hello team,
> I’m debugging my code using gdb. The program runs just fine if I don’t
> debug it, but when I use gdb, it seg faults at a place where it never
> experienced any seg fault when I debugged it 1-2 years ago. I wonder if
> this might be caused by the PETSc version change?
> The only PETSc calls are the MatGetOwnershipRange() calls, which have not
> changed, so I think this is unlikely.
> Or something wrong with gdb itself? I’ve included the code block that is
> problematic for you to take a look at what might be wrong – seg fault
> happens when this function is called. For context, Spmat is a class of
> sparse matrices in the code:
> What is the debugger output?
> Thanks,
> Matt
> // calculate the exact nonzero structure which results from the kronecker
> outer product of left and right
> // d_nnz = diagonal nonzero structure, o_nnz = off-diagonal nonzero
> structure
> void kronConvert_symbolic(const Spmat &left, const Spmat &right, Mat &mat,
> PetscInt* d_nnz, PetscInt* o_nnz)
> size_t rightRowSize = right.size(1);
> size_t rightColSize = right.size(2);
> PetscInt Istart,Iend; // rows owned by current processor
> PetscInt Jstart,Jend; // cols owned by current processor
> // allocate space for mat
> MatGetOwnershipRange(mat,&Istart,&Iend);
> MatGetOwnershipRangeColumn(mat,&Jstart,&Jend);
> PetscInt m = Iend - Istart;
> for (int ii=0; ii<m; ii++) { d_nnz[ii] = 0; }
> for (int ii=0; ii<m; ii++) { o_nnz[ii] = 0; }
> // iterate over only nnz entries
> Spmat::const_row_iter IiL,IiR;
> Spmat::const_col_iter JjL,JjR;
> double valL=0, valR=0, val=0;
> PetscInt row,col;
> size_t rowL,colL,rowR,colR;
> // loop over all values in left
> for (IiL=left._mat.begin(); IiL!=left._mat.end(); IiL++) {
> for (JjL=(IiL->second).begin(); JjL!=(IiL->second).end(); JjL++) {
> rowL = IiL->first;
> colL = JjL->first;
> valL = JjL->second;
> if (valL==0) { continue; }
> // loop over all values in right
> for (IiR=right._mat.begin(); IiR!=right._mat.end(); IiR++) {
> for (JjR=(IiR->second).begin(); JjR!=(IiR->second).end(); JjR++)
> rowR = IiR->first;
> colR = JjR->first;
> valR = JjR->second;
> // the new values and coordinates for the product matrix
> val = valL*valR;
> row = rowL*rightRowSize + rowR;
> col = colL*rightColSize + colR;
> PetscInt ii = row - Istart; // array index for d_nnz and o_nnz
> if (val!=0 && row >= Istart && row < Iend && col >= Jstart &&
> col < Jend) { d_nnz[ii]++; \
> if ( (val!=0 && row >= Istart && row < Iend) && (col < Jstart
> || col >= Jend) ) { o_nnz[i\
> i]++; }
> Thank you,
> Yuyun
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/44cf9517/attachment-0001.html>
