[petsc-users] Seg fault in gdb but program runs
Matthew Knepley
knepley at gmail.com
Tue Dec 13 00:49:09 CST 2022
On Tue, Dec 13, 2022 at 1:14 AM Yuyun Yang <yyang85 at alumni.stanford.edu>
wrote:
> Here is the error message:
> Program received signal SIGSEGV, Segmentation fault.
> 0x00005555555e73b7 in kronConvert (left=..., right=...,
> mat=@0x555555927e10: 0x555557791bb0, diag=5, offDiag=0)
> at /home/yuyun/scycle-2/source/spmat.cpp:265
> 265 kronConvert_symbolic(left,right,mat,d_nnz,o_nnz);
d_nnz and o_nnz are pointers, and they are supposed to hold arrays of the
number of nonzero in each row,
You seem to be passing integers.
Matt
> On Tue, Dec 13, 2022 at 12:41 PM Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Mon, Dec 12, 2022 at 9:56 PM Yuyun Yang <yyang85 at alumni.stanford.edu>
>> wrote:
>>> Hello team,
>>> I’m debugging my code using gdb. The program runs just fine if I don’t
>>> debug it, but when I use gdb, it seg faults at a place where it never
>>> experienced any seg fault when I debugged it 1-2 years ago. I wonder if
>>> this might be caused by the PETSc version change?
>> The only PETSc calls are the MatGetOwnershipRange() calls, which have not
>> changed, so I think this is unlikely.
>>> Or something wrong with gdb itself? I’ve included the code block that is
>>> problematic for you to take a look at what might be wrong – seg fault
>>> happens when this function is called. For context, Spmat is a class of
>>> sparse matrices in the code:
>> What is the debugger output?
>> Thanks,
>> Matt
>>> // calculate the exact nonzero structure which results from the
>>> kronecker outer product of left and right
>>> // d_nnz = diagonal nonzero structure, o_nnz = off-diagonal nonzero
>>> structure
>>> void kronConvert_symbolic(const Spmat &left, const Spmat &right, Mat &
>>> mat, PetscInt* d_nnz, PetscInt* o_nnz)
>>> size_t rightRowSize = right.size(1);
>>> size_t rightColSize = right.size(2);
>>> PetscInt Istart,Iend; // rows owned by current processor
>>> PetscInt Jstart,Jend; // cols owned by current processor
>>> // allocate space for mat
>>> MatGetOwnershipRange(mat,&Istart,&Iend);
>>> MatGetOwnershipRangeColumn(mat,&Jstart,&Jend);
>>> PetscInt m = Iend - Istart;
>>> for (int ii=0; ii<m; ii++) { d_nnz[ii] = 0; }
>>> for (int ii=0; ii<m; ii++) { o_nnz[ii] = 0; }
>>> // iterate over only nnz entries
>>> Spmat::const_row_iter IiL,IiR;
>>> Spmat::const_col_iter JjL,JjR;
>>> double valL=0, valR=0, val=0;
>>> PetscInt row,col;
>>> size_t rowL,colL,rowR,colR;
>>> // loop over all values in left
>>> for (IiL=left._mat.begin(); IiL!=left._mat.end(); IiL++) {
>>> for (JjL=(IiL->second).begin(); JjL!=(IiL->second).end(); JjL++) {
>>> rowL = IiL->first;
>>> colL = JjL->first;
>>> valL = JjL->second;
>>> if (valL==0) { continue; }
>>> // loop over all values in right
>>> for (IiR=right._mat.begin(); IiR!=right._mat.end(); IiR++) {
>>> for (JjR=(IiR->second).begin(); JjR!=(IiR->second).end();
>>> JjR++) {
>>> rowR = IiR->first;
>>> colR = JjR->first;
>>> valR = JjR->second;
>>> // the new values and coordinates for the product matrix
>>> val = valL*valR;
>>> row = rowL*rightRowSize + rowR;
>>> col = colL*rightColSize + colR;
>>> PetscInt ii = row - Istart; // array index for d_nnz and
>>> o_nnz
>>> if (val!=0 && row >= Istart && row < Iend && col >= Jstart &&
>>> col < Jend) { d_nnz[ii]++; \
>>> if ( (val!=0 && row >= Istart && row < Iend) && (col < Jstart
>>> || col >= Jend) ) { o_nnz[i\
>>> i]++; }
>>> Thank you,
>>> Yuyun
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/e2d26791/attachment-0001.html>
