[petsc-users] Seg fault in gdb but program runs
Yuyun Yang
yyang85 at alumni.stanford.edu
Tue Dec 13 00:14:24 CST 2022
Here is the error message:
Program received signal SIGSEGV, Segmentation fault.
0x00005555555e73b7 in kronConvert (left=..., right=...,
mat=@0x555555927e10: 0x555557791bb0, diag=5, offDiag=0)
at /home/yuyun/scycle-2/source/spmat.cpp:265
265 kronConvert_symbolic(left,right,mat,d_nnz,o_nnz);
On Tue, Dec 13, 2022 at 12:41 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Dec 12, 2022 at 9:56 PM Yuyun Yang <yyang85 at alumni.stanford.edu>
> wrote:
>> Hello team,
>> I’m debugging my code using gdb. The program runs just fine if I don’t
>> debug it, but when I use gdb, it seg faults at a place where it never
>> experienced any seg fault when I debugged it 1-2 years ago. I wonder if
>> this might be caused by the PETSc version change?
> The only PETSc calls are the MatGetOwnershipRange() calls, which have not
> changed, so I think this is unlikely.
>> Or something wrong with gdb itself? I’ve included the code block that is
>> problematic for you to take a look at what might be wrong – seg fault
>> happens when this function is called. For context, Spmat is a class of
>> sparse matrices in the code:
> What is the debugger output?
> Thanks,
> Matt
>> // calculate the exact nonzero structure which results from the kronecker
>> outer product of left and right
>> // d_nnz = diagonal nonzero structure, o_nnz = off-diagonal nonzero
>> structure
>> void kronConvert_symbolic(const Spmat &left, const Spmat &right, Mat &mat,
>> PetscInt* d_nnz, PetscInt* o_nnz)
>> size_t rightRowSize = right.size(1);
>> size_t rightColSize = right.size(2);
>> PetscInt Istart,Iend; // rows owned by current processor
>> PetscInt Jstart,Jend; // cols owned by current processor
>> // allocate space for mat
>> MatGetOwnershipRange(mat,&Istart,&Iend);
>> MatGetOwnershipRangeColumn(mat,&Jstart,&Jend);
>> PetscInt m = Iend - Istart;
>> for (int ii=0; ii<m; ii++) { d_nnz[ii] = 0; }
>> for (int ii=0; ii<m; ii++) { o_nnz[ii] = 0; }
>> // iterate over only nnz entries
>> Spmat::const_row_iter IiL,IiR;
>> Spmat::const_col_iter JjL,JjR;
>> double valL=0, valR=0, val=0;
>> PetscInt row,col;
>> size_t rowL,colL,rowR,colR;
>> // loop over all values in left
>> for (IiL=left._mat.begin(); IiL!=left._mat.end(); IiL++) {
>> for (JjL=(IiL->second).begin(); JjL!=(IiL->second).end(); JjL++) {
>> rowL = IiL->first;
>> colL = JjL->first;
>> valL = JjL->second;
>> if (valL==0) { continue; }
>> // loop over all values in right
>> for (IiR=right._mat.begin(); IiR!=right._mat.end(); IiR++) {
>> for (JjR=(IiR->second).begin(); JjR!=(IiR->second).end(); JjR++)
>> rowR = IiR->first;
>> colR = JjR->first;
>> valR = JjR->second;
>> // the new values and coordinates for the product matrix
>> val = valL*valR;
>> row = rowL*rightRowSize + rowR;
>> col = colL*rightColSize + colR;
>> PetscInt ii = row - Istart; // array index for d_nnz and o_nnz
>> if (val!=0 && row >= Istart && row < Iend && col >= Jstart &&
>> col < Jend) { d_nnz[ii]++; \
>> if ( (val!=0 && row >= Istart && row < Iend) && (col < Jstart
>> || col >= Jend) ) { o_nnz[i\
>> i]++; }
>> Thank you,
>> Yuyun
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221213/c1d4e0f9/attachment-0001.html>
