[petsc-users] Compile error on petsc-3.17
Matthew Knepley
knepley at gmail.com
Thu Dec 1 09:06:43 CST 2022
On Thu, Dec 1, 2022 at 9:53 AM Jake Lee <leejaku at gmail.com> wrote:
> Dear Petsc Project Manager,
> I am Jake Lee with the Advanced Institute of Convergence Technology in
> South Korea.
> I'm programming with Petsc-3.17 and I encountered the following two
> errors.
> PETSC_FUNCTION_NAME_CXX and PETSC_RESTRICT macros are not defined?
> 1. ./petsc-3.17.0/include/petscmacros.h:10:31: error:
> ‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean
> ‘PETSC_FUNCTION_NAME_C’?
> 10 | # define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_CXX
> 2. In file included from ./slepc-3.17.0/include/slepcsys.h:18,
> from ./slepc-3.17.0/include/slepcst.h:16,
> from ./slepc-3.17.0/include/slepceps.h:16,
> from main.cpp:15:
> ./petsc-3.17.0/include/petscsys.h:2548:108: error: expected ‘,’ or ‘...’
> before ‘*’ token
> 2548 | static inline PetscErrorCode PetscSegBufferGetInts(PetscSegBuffer
> seg,size_t count,PetscInt *PETSC_RESTRICT*slot) {return
> PetscSegBufferGet(seg,count,(void**)slot);}
> ./petsc-3.17.0/include/petscsys.h: In function ‘PetscErrorCode
> PetscSegBufferGetInts(PetscSegBuffer, size_t, PetscInt*)’:
> ./petsc-3.17.0/include/petscsys.h:2548:159: error: ‘slot’ was not declared
> in this scope
> 2548 | rrorCode PetscSegBufferGetInts(PetscSegBuffer seg,size_t
1. PETSC_FUNCTION_NAME_CXX is defined in petscconf.h which is created by
configure. Perhaps you need to rerun your configure
if you updated from an earlier version. You can check in
petsc-3.17.0/arch-linux-c-debug/include/petscconf.h
for the macro
2. The PETSC_RESTRICT is a knock-on error from the last error.
Matt
> It seems to be a simple problem. Can I get some hints for them?
> My environment is...
> - CentOS 7
> - gcc 9.3.1
> - compile option
> g++ -std=c++17 -I./eigen-3.4.0 -I./boost_1_77_0 -I./petsc-3.17.0/include
> -I./petsc-3.17.0/arch-linux-c-debug/include -I./slepc-3.17.0/include
> -I./slepc-3.17.0/arch-linux-c-debug/include -c main.cpp
> Thank you!
> Jake Lee (이재규)
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221201/a6618d1f/attachment.html>
