[petsc-users] Compile error on petsc-3.17
Jake Lee
leejaku at gmail.com
Thu Dec 1 08:42:29 CST 2022
Dear Petsc Project Manager,
I am Jake Lee with the Advanced Institute of Convergence Technology in
South Korea.
I'm programming with Petsc-3.17 and I encountered the following two errors.
PETSC_FUNCTION_NAME_CXX and PETSC_RESTRICT macros are not defined?
1. ./petsc-3.17.0/include/petscmacros.h:10:31: error:
‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean
‘PETSC_FUNCTION_NAME_C’?
10 | # define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_CXX
2. In file included from ./slepc-3.17.0/include/slepcsys.h:18,
from ./slepc-3.17.0/include/slepcst.h:16,
from ./slepc-3.17.0/include/slepceps.h:16,
from main.cpp:15:
./petsc-3.17.0/include/petscsys.h:2548:108: error: expected ‘,’ or ‘...’
before ‘*’ token
2548 | static inline PetscErrorCode PetscSegBufferGetInts(PetscSegBuffer
seg,size_t count,PetscInt *PETSC_RESTRICT*slot) {return
PetscSegBufferGet(seg,count,(void**)slot);}
./petsc-3.17.0/include/petscsys.h: In function ‘PetscErrorCode
PetscSegBufferGetInts(PetscSegBuffer, size_t, PetscInt*)’:
./petsc-3.17.0/include/petscsys.h:2548:159: error: ‘slot’ was not declared
in this scope
2548 | rrorCode PetscSegBufferGetInts(PetscSegBuffer seg,size_t
It seems to be a simple problem. Can I get some hints for them?
My environment is...
- CentOS 7
- gcc 9.3.1
- compile option
g++ -std=c++17 -I./eigen-3.4.0 -I./boost_1_77_0 -I./petsc-3.17.0/include
-I./petsc-3.17.0/arch-linux-c-debug/include -I./slepc-3.17.0/include
-I./slepc-3.17.0/arch-linux-c-debug/include -c main.cpp
Thank you!
Jake Lee (이재규)
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221201/45941120/attachment-0001.html>
