[petsc-users] Compile error on petsc-3.17
Jake Lee leejaku at gmail.com
Thu Dec 1 10:03:53 CST 2022
Dear Matt,
It was my "configure" mistake. I was set --with-cxx=0 not --with-cxx=g++.
This issue is solved now.
Thank you very much.
Jake Lee (이재규)
2022년 12월 2일 (금) 오전 12:06, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Thu, Dec 1, 2022 at 9:53 AM Jake Lee <leejaku at gmail.com> wrote:
>> Dear Petsc Project Manager,
>> I am Jake Lee with the Advanced Institute of Convergence Technology in
>> South Korea.
>> I'm programming with Petsc-3.17 and I encountered the following two
>> errors.
>> PETSC_FUNCTION_NAME_CXX and PETSC_RESTRICT macros are not defined?
>> 1. ./petsc-3.17.0/include/petscmacros.h:10:31: error:
>> ‘PETSC_FUNCTION_NAME_CXX’ was not declared in this scope; did you mean
>> ‘PETSC_FUNCTION_NAME_C’?
>>    10 | #  define PETSC_FUNCTION_NAME PETSC_FUNCTION_NAME_CXX
>> 2. In file included from ./slepc-3.17.0/include/slepcsys.h:18,
>>                  from ./slepc-3.17.0/include/slepcst.h:16,
>>                  from ./slepc-3.17.0/include/slepceps.h:16,
>>                  from main.cpp:15:
>> ./petsc-3.17.0/include/petscsys.h:2548:108: error: expected ‘,’ or ‘...’
>> before ‘*’ token
>>  2548 | static inline PetscErrorCode PetscSegBufferGetInts(PetscSegBuffer
>> seg,size_t count,PetscInt *PETSC_RESTRICT*slot) {return
>> PetscSegBufferGet(seg,count,(void**)slot);}
>> ./petsc-3.17.0/include/petscsys.h: In function ‘PetscErrorCode
>> PetscSegBufferGetInts(PetscSegBuffer, size_t, PetscInt*)’:
>> ./petsc-3.17.0/include/petscsys.h:2548:159: error: ‘slot’ was not
>>  2548 | rrorCode PetscSegBufferGetInts(PetscSegBuffer seg,size_t
> 1. PETSC_FUNCTION_NAME_CXX is defined in petscconf.h which is created by
> configure. Perhaps you need to rerun your configure
>     if you updated from an earlier version. You can check in
>        petsc-3.17.0/arch-linux-c-debug/include/petscconf.h
>    for the macro
> 2. The PETSC_RESTRICT is a knock-on error from the last error.
>   Thanks,
>      Matt
>> It seems to be a simple problem. Can I get some hints for them?
>> My environment is...
>> - CentOS 7
>> - gcc 9.3.1
>> - compile option
>> g++ -std=c++17   -I./eigen-3.4.0 -I./boost_1_77_0
>> -I./petsc-3.17.0/include -I./petsc-3.17.0/arch-linux-c-debug/include
>> -I./slepc-3.17.0/include -I./slepc-3.17.0/arch-linux-c-debug/include -c
>> main.cpp
>> Thank you!
>> Jake Lee (이재규)
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221202/28ebfc2d/attachment-0001.html>
