[petsc-users] Speed of matrix assembly
Mark Adams mfadams at lbl.gov
Thu Dec 1 07:23:46 CST 2022
This is the recommended call sequence to create a matrix:
 PetscCall(MatCreate(comm, &A));  PetscCall(MatSetSizes(A,
PETSC_DECIDE, PETSC_DECIDE, N, N));  PetscCall(MatSetFromOptions(A));
PetscCall(MatSeqAIJSetPreallocation(A, 3, NULL));
PetscCall(MatMPIAIJSetPreallocation(A, 3, NULL, 2, NULL));
You need to look at
https://petsc.org/main/docs/manualpages/Mat/MatMPIAIJSetPreallocation
And set the preallocation correctly.
Note, you can run with -info (very noisy so filter with grep or something)
and look for messages about the number of mallocs in the matrix assembly.
You want to preallocate enough to have zero mallocs.
On Thu, Dec 1, 2022 at 2:32 AM 김성익 <ksi2443 at gmail.com> wrote:
> Hello,
> I set a large-sized global matrix through matsetsize and proceed with the
> process of assembling multiple local-sized matrices into a global matrix
> (By using MatSetValue).
> However, only using matsetsize much less than expected performance.
> In this case, what can be done to speed up assembly?
> Thanks,
> Hyung Kim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20221201/270bad91/attachment.html>
