[petsc-users] DMPlex PETSCViewer for Surface Component
    Matthew Knepley
    knepley at gmail.com
    Tue Aug  2 09:38:16 CDT 2022
Yes, you can use DMPlexCreateSubmesh() (and friends depending on exactly
what kind of submesh you want). This will allow you to create a vector over
only this mesh, and map your volumetric solution to that subvector. Then
you can view the subvector (which pulls in the submesh).
     Matt
On Mon, Aug 1, 2022 at 10:59 PM Jed Brown <jed at jedbrown.org> wrote:
> I would create a sub-DM containing only the part you want to view.
> Mike Michell <mi.mike1021 at gmail.com> writes:
> > Hi,
> > I am a user of DMPlex object in 3D grid topology. Currently the solution
> > field is printed out using viewer PETSCVIEWERVTK in .vtu format. By doing
> > that the entire volume components are written in the file. I was
> wondering
> > if there is an option that I can tell PETSc viewer to print out only
> > surface component, instead of the entire volume.
> > Best,
> > Mike
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220802/1266e139/attachment.html>
