[petsc-users] DMPlex PETSCViewer for Surface Component
Mike Michell
mi.mike1021 at gmail.com
Fri Aug 5 08:09:32 CDT 2022
Thank you Jed and Matt. That is exactly what I wanted to do.
I was wondering if there is an example of mapping between DMPLEXs.
I have several requirements of the mapping for my code, such as
- mapping solution vectors on cell-centroids into vertices
- mapping from volume dmplex into sub-dm for wall surface region
Any example will help.
Many thanks,
Mike
> Yes, you can use DMPlexCreateSubmesh() (and friends depending on exactly
> what kind of submesh you want). This will allow you to create a vector over
> only this mesh, and map your volumetric solution to that subvector. Then
> you can view the subvector (which pulls in the submesh).
> Thanks,
> Matt
> On Mon, Aug 1, 2022 at 10:59 PM Jed Brown <jed at jedbrown.org> wrote:
>> I would create a sub-DM containing only the part you want to view.
>> Mike Michell <mi.mike1021 at gmail.com> writes:
>> > Hi,
>> > I am a user of DMPlex object in 3D grid topology. Currently the solution
>> > field is printed out using viewer PETSCVIEWERVTK in .vtu format. By
>> doing
>> > that the entire volume components are written in the file. I was
>> wondering
>> > if there is an option that I can tell PETSc viewer to print out only
>> > surface component, instead of the entire volume.
>> > Best,
>> > Mike
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220805/d4e9ada1/attachment.html>
