[petsc-users] Matrix preallocation - d_nz and o_nz
Matthew Knepley
knepley at gmail.com
Thu Apr 7 05:47:24 CDT 2022
On Thu, Apr 7, 2022 at 6:12 AM Gabriela Nečasová <necaga at gmail.com> wrote:
> Dear PETSc team,
> I would like to ask you a question about the matrix preallocation.
> I am using the routine MatMPIAIJSetPreallocation().
> Example: The matrix A has the size 18 x 18 with 168 nonzeros:
> A =
> 106.21 -91.667 26.042 0 0 0
> 0 0 0 -2704.2 2862.5 -1354.2
> 260.42 0 0 0 0
> 0
> -91.667 132.25 -91.667 26.042 0
> 0 0 0 0 2862.5 -4058.3
> 3122.9 -1354.2 260.42 0 0 0
> 0
> 26.042 -91.667 132.25 -91.667 26.042
> 0 0 0 0 -1354.2 3122.9
> -4058.3 3122.9 -1354.2 260.42 0 0
> 0
> 0 26.042 -91.667 132.25 -91.667
> 26.042 0 0 0 260.42 -1354.2
> 3122.9 -4058.3 3122.9 -1354.2 260.42 0
> 0
> 0 0 26.042 -91.667 132.25
> -91.667 26.042 0 0 0 260.42
> -1354.2 3122.9 -4058.3 3122.9 -1354.2 260.42
> 0
> 0 0 0 26.042 -91.667
> 132.25 -91.667 26.042 0 0 0
> 260.42 -1354.2 3122.9 -4058.3 3122.9 -1354.2
> 260.42
> 0 0 0 0 26.042
> -91.667 132.25 -91.667 26.042 0 0
> 0 260.42 -1354.2 3122.9 -4058.3 3122.9
> -1354.2
> 0 0 0 0 0
> 26.042 -91.667 132.25 -91.667 0 0
> 0 0 260.42 -1354.2 3122.9 -4058.3
> 2862.5
> 0 0 0 0 0
> 0 26.042 -91.667 106.21 0 0
> 0 0 0 260.42 -1354.2 2862.5
> -2704.2
> 9.3542 -8.3333 2.6042 0 0
> 0 0 0 0 106.21 -91.667
> 26.042 0 0 0 0 0
> 0
> -8.3333 11.958 -8.3333 2.6042 0
> 0 0 0 0 -91.667 132.25
> -91.667 26.042 0 0 0 0
> 0
> 2.6042 -8.3333 11.958 -8.3333 2.6042
> 0 0 0 0 26.042 -91.667
> 0
> 0 2.6042 -8.3333 11.958 -8.3333
> 2.6042 0 0 0 0 26.042
> 0
> 0 0 2.6042 -8.3333 11.958
> -8.3333 2.6042 0 0 0 0
> 26.042 -91.667 132.25 -91.667 26.042 0
> 0
> 0 0 0 2.6042 -8.3333
> 11.958 -8.3333 2.6042 0 0 0
> 0 26.042 -91.667 132.25 -91.667 26.042
> 0
> 0 0 0 0 2.6042
> -8.3333 11.958 -8.3333 2.6042 0 0
> 0 0 26.042 -91.667 132.25 -91.667
> 26.042
> 0 0 0 0 0
> 2.6042 -8.3333 11.958 -8.3333 0 0
> 0 0 0 26.042 -91.667 132.25
> -91.667
> 0 0 0 0 0
> 0 2.6042 -8.3333 9.3542 0 0
> 106.21
> I am wondering how the d_nz and o_nz values should be set.
> I read the docs:
> https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html
> *For example, for 2 processes P1, P2: *
> mi - denote the number of rows which belong to process Pi
> P0: m0 = 9
> P1: m1 = 9
> The dn_nz and o_nz should be:
> P0: d_nz = 5; o_nz = 7
> P1: d_nz = 5; o_nz = 7
> Therefore, we are allocating m*(d_nz+o_nz) storage locations for every
> process:
> P0: 9*(5+7) = 108
> P1: 9*(5+7) = 108
> So, in total, we have 216 storage locations to store 168 nonzeros.
> But I am doing more experiments and I use the various number of processes
> - e.g. 2, 4, 8, 19, 32, etc.
> *For example, if we take 3 processes - P0, P1, P2:*
> P0: m0 = 6
> P1: m1 = 6
> P2: m2 = 6
> P0: d_nz = 5; o_nz = 7 (I took the maximum number of o_nz)
> P1: d_nz = 3; o_nz = 8 (I took the maximum number of o_nz)
> P2: d_nz = 5; o_nz = 7 (I took the maximum number of o_nz)
> process:
> P0: 6*(5+7) = 72
> P1: 6*(3+8) = 66
> P2: 6*(5+7) = 72
> So, in total, we have 210 storage locations to store 168 nonzeros.
> *My questions are:*
> 1) How should I set the d_nz and o_nz values when the number of processes
> changes in every experiment?
> -- I suppose, there has to be some "general" settings, so you do not have
> to change these values for every experiment, right?
> -- For better illustration, I am sending you figures of the matrix A in
> the attachment.
I think the correct answer is that d_nz/o_nz should only be used for
testing or example codes. Production codes should
specify the number of nonzeros in every row, d_nnz/o_nnz. We provide
support for doing this easily with the
MatPreallocator class..
> 2) If I run the code sequentially, then the MatMPIAIJSetPreallocation()
> routine will crash?
If you run sequentially, meaning with the type MATSEQAIJ, then this
function is ignored, so your matrix
will not be preallocated. This can still work, but will be slow.
> 3) If I need to generate a large identity matrix, is this a correct
> approach, please?
> //create matrix I (diagonal matrix)
> ierr = MatCreate(comm, &Ione);CHKERRQ(ierr);
> ierr = MatSetType(Ione, MATMPIAIJ);CHKERRQ(ierr);
> ierr = MatSetSizes(Ione, PETSC_DECIDE, PETSC_DECIDE, data_size,
> data_size);CHKERRQ(ierr);
> // parallel sparse - preallocation for better performance
> ierr = MatMPIAIJSetPreallocation(Ione, 1, PETSC_NULL, 0,
> PETSC_NULL);CHKERRQ(ierr);
> // create vector with ones
> ierr = VecCreate(PETSC_COMM_WORLD, &diagVec);CHKERRQ(ierr);
> ierr = VecSetType(diagVec, VECMPI);CHKERRQ(ierr);
> ierr = VecSetSizes(diagVec, PETSC_DECIDE, data_size);CHKERRQ(ierr);
> ierr = VecSet(diagVec, 1);CHKERRQ(ierr);
> // set the diagonal of matrix I using the vector diagVec
> ierr = MatDiagonalSet(Ione, diagVec, INSERT_VALUES);CHKERRQ(ierr);
> ierr = MatAssemblyBegin(Ione, MAT_FINAL_ASSEMBLY);
> ierr = MatAssemblyEnd(Ione, MAT_FINAL_ASSEMBLY);
Yes, that is a fine way to do it.
Matt
> Thank you very much in advance.
> Kind regards
> Gabi
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220407/fe186142/attachment.html>
