[petsc-users] Matrix preallocation - d_nz and o_nz
Gabriela Nečasová necaga at gmail.com
Thu Apr 7 04:55:46 CDT 2022
 Dear PETSc team,
I would like to ask you a question about the matrix preallocation.
I am using the routine MatMPIAIJSetPreallocation().
Example: The matrix A has the size 18 x 18 with 168 nonzeros:
A =
 106.21      -91.667       26.042            0            0            0
         0            0            0      -2704.2       2862.5      -1354.2
      260.42            0            0            0            0
 0
      -91.667       132.25      -91.667       26.042            0
 0            0            0            0       2862.5      -4058.3
3122.9      -1354.2       260.42            0            0            0
       0
       26.042      -91.667       132.25      -91.667       26.042
 0            0            0            0      -1354.2       3122.9
 -4058.3       3122.9      -1354.2       260.42            0            0
         0
            0       26.042      -91.667       132.25      -91.667
26.042            0            0            0       260.42      -1354.2
  3122.9      -4058.3       3122.9      -1354.2       260.42            0
         0
            0            0       26.042      -91.667       132.25
 -91.667       26.042            0            0            0       260.42
   -1354.2       3122.9      -4058.3       3122.9      -1354.2       260.42
           0
            0            0            0       26.042      -91.667
132.25      -91.667       26.042            0            0            0
  260.42      -1354.2       3122.9      -4058.3       3122.9      -1354.2
    260.42
            0            0            0            0       26.042
 -91.667       132.25      -91.667       26.042            0            0
         0       260.42      -1354.2       3122.9      -4058.3       3122.9
     -1354.2
            0            0            0            0            0
26.042      -91.667       132.25      -91.667            0            0
       0            0       260.42      -1354.2       3122.9      -4058.3
    2862.5
            0            0            0            0            0
 0       26.042      -91.667       106.21            0            0
   0            0            0       260.42      -1354.2       2862.5
 -2704.2
       9.3542      -8.3333       2.6042            0            0
 0            0            0            0       106.21      -91.667
26.042            0            0            0            0            0
       0
      -8.3333       11.958      -8.3333       2.6042            0
 0            0            0            0      -91.667       132.25
 -91.667       26.042            0            0            0            0
         0
       2.6042      -8.3333       11.958      -8.3333       2.6042
 0            0            0            0       26.042      -91.667
       0
            0       2.6042      -8.3333       11.958      -8.3333
2.6042            0            0            0            0       26.042
         0
            0            0       2.6042      -8.3333       11.958
 -8.3333       2.6042            0            0            0            0
    26.042      -91.667       132.25      -91.667       26.042            0
           0
            0            0            0       2.6042      -8.3333
11.958      -8.3333       2.6042            0            0            0
       0       26.042      -91.667       132.25      -91.667       26.042
         0
            0            0            0            0       2.6042
 -8.3333       11.958      -8.3333       2.6042            0            0
         0            0       26.042      -91.667       132.25      -91.667
      26.042
            0            0            0            0            0
2.6042      -8.3333       11.958      -8.3333            0            0
       0            0            0       26.042      -91.667       132.25
   -91.667
            0            0            0            0            0
 0       2.6042      -8.3333       9.3542            0            0
106.21
I am wondering how the d_nz and o_nz values should be set.
I read the docs:
https://petsc.org/release/docs/manualpages/Mat/MatMPIAIJSetPreallocation.html
*For example, for 2 processes P1, P2: *
mi - denote the number of rows which belong to process Pi
P0: m0 = 9
P1: m1 = 9
The dn_nz and o_nz should be:
P0: d_nz = 5; o_nz = 7
P1: d_nz = 5; o_nz = 7
Therefore, we are allocating m*(d_nz+o_nz) storage locations for every
process:
P0: 9*(5+7) = 108
P1: 9*(5+7) = 108
So, in total, we have 216 storage locations to store 168 nonzeros.
But I am doing more experiments and I use the various number of processes -
e.g. 2, 4, 8, 19, 32, etc.
*For example, if we take 3 processes - P0, P1, P2:*
P0: m0 = 6
P1: m1 = 6
P2: m2 = 6
P0: d_nz = 5; o_nz = 7 (I took the maximum number of o_nz)
P1: d_nz = 3; o_nz = 8  (I took the maximum number of o_nz)
P2: d_nz = 5; o_nz = 7 (I took the maximum number of o_nz)
process:
P0: 6*(5+7) = 72
P1: 6*(3+8) = 66
P2: 6*(5+7) = 72
So, in total, we have 210 storage locations to store 168 nonzeros.
*My questions are:*
1) How should I set the d_nz and o_nz values when the number of processes
changes in every experiment?
-- I suppose, there has to be some "general" settings, so you do not have
to change these values for every experiment, right?
-- For better illustration, I am sending you figures of the matrix A in the
attachment.
2) If I run the code sequentially, then the MatMPIAIJSetPreallocation()
routine will crash?
3) If I need to generate a large identity matrix, is this a correct
approach, please?
//create matrix I (diagonal matrix)
ierr = MatCreate(comm, &Ione);CHKERRQ(ierr);
ierr = MatSetType(Ione, MATMPIAIJ);CHKERRQ(ierr);
ierr = MatSetSizes(Ione, PETSC_DECIDE, PETSC_DECIDE, data_size,
data_size);CHKERRQ(ierr);
// parallel sparse - preallocation for better performance
ierr = MatMPIAIJSetPreallocation(Ione, 1, PETSC_NULL, 0,
PETSC_NULL);CHKERRQ(ierr);
// create vector with ones
ierr = VecCreate(PETSC_COMM_WORLD, &diagVec);CHKERRQ(ierr);
ierr = VecSetType(diagVec, VECMPI);CHKERRQ(ierr);
ierr = VecSetSizes(diagVec, PETSC_DECIDE, data_size);CHKERRQ(ierr);
ierr = VecSet(diagVec, 1);CHKERRQ(ierr);
// set the diagonal of matrix I using the vector diagVec
ierr = MatDiagonalSet(Ione, diagVec, INSERT_VALUES);CHKERRQ(ierr);
ierr = MatAssemblyBegin(Ione, MAT_FINAL_ASSEMBLY);
ierr = MatAssemblyEnd(Ione, MAT_FINAL_ASSEMBLY);
Thank you very much in advance.
Kind regards
Gabi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220407/903e909e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220407/903e909e/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220407/903e909e/attachment-0003.png>
