[petsc-users] SNES Matrix-Free Parameters
Barry Smith
bsmith at petsc.dev
Thu Apr 7 12:21:23 CDT 2022
The documentation is a bit out of date. Use -mat_mffd_type ds you can also use -help | grep mat_mffd to see the options for controlling the process.
Barry
> On Apr 7, 2022, at 11:21 AM, Alfredo J Duarte Gomez <aduarteg at utexas.edu> wrote:
> Hello Barry,
> Thank you for the clarification, the petsc user manual does list snes_mf_type <default or wp> as the options so I was confused.
> I believe the function accuracy is fine, but I would like to experiment with other "h" routines to see if I can get some improvement for small time steps. However, i am still having trouble switching that routine at least from what I see from the message I described in my previous email. I tried out -snes_mf_type dp, but it did not change the output.
> I am currently only calling SNESSetFromOptions() on my snes object, which I assumed would handle the -snes_mf_type option. Do I need to get the Jacobian from the snes and then call a MatSetFromOptions() on my matrix-free jacobian to use this option?
> Thank you,
> -Alfredo
> On Wed, Apr 6, 2022 at 6:35 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
> I notice that this part of the message does not change even when I specify "-snes_mf_type default" (which is the alternative to wp), so I am a bit confused on how I interact to the -snes_mf_type or if I am interpreting the message wrong. Could you clarify this?
> Hmm, the two possibilities are -snes_mf_type wp or ds. I would expect an error message if you passed default.
> Regarding selecting the
> err=1.49012e-08 (relative error in function evaluation)
> this number should be the square root of the expected error in the function evaluation. So for double-precision numbers and a function evaluation with no noise (so computed accurately to double precision) the tolerance is the square root of the machine epsilon.
> You should only change this number (make it bigger) if you know that your function evaluations are not fully accurate. For example, if you know your function evaluation is only accurate to 10 decimal digits you could use an err of 1e-5.
> But if your function evaluations are accurate to double precision then changing this number is unlikely to help anything.
> Barry
>> On Apr 6, 2022, at 3:13 PM, Alfredo J Duarte Gomez <aduarteg at utexas.edu <mailto:aduarteg at utexas.edu>> wrote:
>> Good afternoon petsc team,
>> I have a few questions regarding the matrixfree in the snes context.
>> I am currently using the matrix-free method with my own preconditioner to solve a TS problem. I currently trigger this with the -snes_mf_operator option.
>> So far the default values have been working great, but I ran into trouble during a convergence study when I made the time step very small, which I suspect is probably happening because it's dropping below the matrix-vector product tolerance.
>> I wanted to explore the parameters of the matrix-vector product but using the -snes_view option I notice that the following full message comes out:
>> SNES Object: 96 MPI processes
>> type: newtonls
>> maximum iterations=20, maximum function evaluations=10000
>> tolerances: relative=1e-06, absolute=1e-06, solution=1e-15
>> total number of linear solver iterations=14
>> total number of function evaluations=35
>> norm schedule ALWAYS
>> Jacobian is never rebuilt
>> Jacobian is applied matrix-free with differencing
>> Jacobian is applied matrix-free with differencing, no explict Jacobian
>> SNESLineSearch Object: 96 MPI processes
>> type: l2
>> maxstep=1.000000e+08, minlambda=1.000000e-12
>> tolerances: relative=1.000000e-08, absolute=1.000000e-15, lambda=1.000000e-08
>> maximum iterations=1
>> KSP Object: 96 MPI processes
>> type: gmres
>> restart=100, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
>> happy breakdown tolerance 1e-30
>> maximum iterations=400, initial guess is zero
>> tolerances: relative=0.01, absolute=1e-50, divergence=10000.
>> left preconditioning
>> using PRECONDITIONED norm type for convergence test
>> PC Object: 96 MPI processes
>> type: shell
>> MyPreconditioner
>> linear system matrix followed by preconditioner matrix:
>> Mat Object: 96 MPI processes
>> type: mffd
>> rows=8400000, cols=8400000
>> Matrix-free approximation:
>> Using wp compute h routine
>> Does not compute normU
>> type: mpiaij
>> rows=8400000, cols=8400000, bs=4
>> total: nonzeros=2041029504, allocated nonzeros=2041029504
>> total number of mallocs used during MatSetValues calls=0
>> I have been focusing specifically on the part:
>> Also let me know if you have any general suggestions on tightening the tolerance of the matricxvector products.
>> Thank you,
>> -Alfredo
>> Alfredo Duarte
>> Graduate Research Assistant
>> The University of Texas at Austin
> Alfredo Duarte
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20220407/2fdb797f/attachment.html>
