[petsc-users] PETSc 3.15.3 compiling error
Sam Guo
sam.guo at cd-adapco.com
Wed Sep 1 14:12:57 CDT 2021
I believe I am using MUMPS since I have done following
(1) defined -DPETSC_HAVE_MUMPS,
(2) compiles and links mat/impls/aij/mpi/mumps/mumps.c
(3) link my pre-compiled MUMPS, and
(4) specifies following PETSc options
checkError(EPSGetST(eps, &st));
checkError(STSetType(st, STSINVERT));
//if(useShellMatrix) checkError(STSetMatMode(st, ST_MATMODE_SHELL));
checkError(STGetKSP(st, &ksp));
checkError(KSPSetOperators(ksp, A, A));
checkError(KSPSetType(ksp, KSPPREONLY));
checkError(KSPGetPC(ksp, &pc));
checkError(MatSetOption(A, MAT_SPD, PETSC_TRUE));
checkError(PCSetType(pc, PCCHOLESKY));
checkError(PCFactorSetMatSolverType(pc, MATSOLVERMUMPS));
checkError(PCFactorSetUpMatSolverType(pc));
checkError(PetscOptionsSetValue(NULL, "-mat_mumps_icntl_13","1"));
Another evidence I am using MUMPS is that If I skip (1)-(3) above, I got
the PETSc error saying that MUMPS is required.
On Wed, Sep 1, 2021 at 12:00 PM Satish Balay <balay at mcs.anl.gov> wrote:
> mumps is a fortran package - so best to specify fc. Any specific reason
> for needing to force '--with-fc=0'?
> The attached configure.log is not using mumps.
> Satish
> On Wed, 1 Sep 2021, Sam Guo wrote:
> > fc should not be required since I link PETSc with pre-compiled MUMPS. In
> > fact, --with-mumps-include --with-mumps-lib --with-mumps-serial should
> not
> > be required since my own CMake defines -DPETSC_HAVE_MUMPS and links my
> > pre-compiled MUMPS.
> > I am able to make it work using PETSc 3.11.3. Attached please find the
> > cPETSc 3.11.3 onfigure.log PETSc.
> > On Tue, Aug 31, 2021 at 4:47 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log
> for
> > > details):
> > > Package mumps requested requires Fortran but compiler turned off.
> > > i.e remove '--with-fc=0' and rerun configure.
> > > Satish
> > > On Tue, 31 Aug 2021, Sam Guo wrote:
> > > > Attached please find the latest configure.log.
> > > > grep MUMPS_VERSION
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/*.h
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/cmumps_c.h:#ifndef
> > > > MUMPS_VERSION
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/cmumps_c.h:#define
> > > > MUMPS_VERSION "5.2.1"
> > > > MUMPS_VERSION_MAX_LEN
> > > > MUMPS_VERSION_MAX_LEN 30
> > > > char version_number[MUMPS_VERSION_MAX_LEN + 1 + 1];
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/dmumps_c.h:#ifndef
> > > > MUMPS_VERSION
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/dmumps_c.h:#define
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/smumps_c.h:#ifndef
> > > > MUMPS_VERSION
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/smumps_c.h:#define
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/zmumps_c.h:#ifndef
> > > > MUMPS_VERSION
> /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/zmumps_c.h:#define
> > > > On Mon, Aug 30, 2021 at 9:47 PM Satish Balay <balay at mcs.anl.gov>
> wrote:
> > > > > Also - what do you have for:
> > > > > grep MUMPS_VERSION
> > > > > Satish
> > > > > On Mon, 30 Aug 2021, Satish Balay via petsc-users wrote:
> > > > > > please resend the logs
> > > > > > Satish
> > > > > > On Mon, 30 Aug 2021, Sam Guo wrote:
> > > > > > > Same compiling error with --with-mumps-serial=1.
> > > > > > > On Mon, Aug 30, 2021 at 8:22 PM Satish Balay <
> > > > > wrote:
> > > > > > > > Use the additional option: -with-mumps-serial
> > > > > > > > Satish
> > > > > > > > > Attached please find the configure.log. I use my own
> CMake. I
> > > have
> > > > > > > > > defined -DPETSC_HAVE_MUMPS. Thanks.
> > > > > > > > > On Mon, Aug 30, 2021 at 4:56 PM Sam Guo <
> > > > > wrote:
> > > > > > > > > > I use pre-installed
> > > > > > > > > > On Mon, Aug 30, 2021 at 4:53 PM Satish Balay <
> > > > > > > > wrote:
> > > > > > > > > >> Are you using --download-mumps or pre-installed mumps?
> If
> > > using
> > > > > > > > > >> pre-installed - try --download-mumps.
> > > > > > > > > >> If you still have issues - send us configure.log and
> > > make.log
> > > > > from the
> > > > > > > > > >> failed build.
> > > > > > > > > >> Satish
> > > > > > > > > >> > Dear PETSc dev team,
> > > > > > > > > >> > I am compiling petsc 3.15.3 and got following
> compiling
> > > > > error
> > > > > > > > > >> > petsc/src/mat/impls/aij/mpi/mumps/mumps.c:52:31:
> error:
> > > > > missing
> > > > > > > > binary
> > > > > > > > > >> > operator before token "("
> > > > > > > > > >> > 52 | #if PETSC_PKG_MUMPS_VERSION_GE(5,3,0)
> > > > > > > > > >> > Any idea what I did wrong?
> > > > > > > > > >> > Thanks,
> > > > > > > > > >> > Sam
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20210901/fb94fb8e/attachment-0001.html>
