[petsc-users] PETSc 3.15.3 compiling error
Satish Balay
balay at mcs.anl.gov
Wed Sep 1 14:00:24 CDT 2021
mumps is a fortran package - so best to specify fc. Any specific reason for needing to force '--with-fc=0'?
The attached configure.log is not using mumps.
Satish
On Wed, 1 Sep 2021, Sam Guo wrote:
> fc should not be required since I link PETSc with pre-compiled MUMPS. In
> fact, --with-mumps-include --with-mumps-lib --with-mumps-serial should not
> be required since my own CMake defines -DPETSC_HAVE_MUMPS and links my
> pre-compiled MUMPS.
> I am able to make it work using PETSc 3.11.3. Attached please find the
> cPETSc 3.11.3 onfigure.log PETSc.
> On Tue, Aug 31, 2021 at 4:47 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> > Package mumps requested requires Fortran but compiler turned off.
> > i.e remove '--with-fc=0' and rerun configure.
> > Satish
> > On Tue, 31 Aug 2021, Sam Guo wrote:
> > > Attached please find the latest configure.log.
> > > grep MUMPS_VERSION
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/*.h
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/cmumps_c.h:#ifndef
> > > MUMPS_VERSION
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/cmumps_c.h:#define
> > > MUMPS_VERSION "5.2.1"
> > > MUMPS_VERSION_MAX_LEN
> > > MUMPS_VERSION_MAX_LEN 30
> > > char version_number[MUMPS_VERSION_MAX_LEN + 1 + 1];
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/dmumps_c.h:#ifndef
> > > MUMPS_VERSION
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/dmumps_c.h:#define
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/smumps_c.h:#ifndef
> > > MUMPS_VERSION
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/smumps_c.h:#define
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/zmumps_c.h:#ifndef
> > > MUMPS_VERSION
> > /u/cd4hhv/dev4/mumps/5.2.1-vanilla-parmetis3.2.0-openmp-cda-001/linux-x86_64-2.3.4/include/zmumps_c.h:#define
> > > On Mon, Aug 30, 2021 at 9:47 PM Satish Balay <balay at mcs.anl.gov> wrote:
> > > > Also - what do you have for:
> > > > grep MUMPS_VERSION
> > > > Satish
> > > > On Mon, 30 Aug 2021, Satish Balay via petsc-users wrote:
> > > > > please resend the logs
> > > > > Satish
> > > > > On Mon, 30 Aug 2021, Sam Guo wrote:
> > > > > > Same compiling error with --with-mumps-serial=1.
> > > > > > On Mon, Aug 30, 2021 at 8:22 PM Satish Balay <balay at mcs.anl.gov>
> > > > wrote:
> > > > > > > Use the additional option: -with-mumps-serial
> > > > > > > Satish
> > > > > > > > Attached please find the configure.log. I use my own CMake. I
> > have
> > > > > > > > defined -DPETSC_HAVE_MUMPS. Thanks.
> > > > > > > > On Mon, Aug 30, 2021 at 4:56 PM Sam Guo <sam.guo at cd-adapco.com
> > > > wrote:
> > > > > > > > > I use pre-installed
> > > > > > > > > On Mon, Aug 30, 2021 at 4:53 PM Satish Balay <
> > > > > > > wrote:
> > > > > > > > >> Are you using --download-mumps or pre-installed mumps? If
> > using
> > > > > > > > >> pre-installed - try --download-mumps.
> > > > > > > > >> If you still have issues - send us configure.log and
> > make.log
> > > > from the
> > > > > > > > >> failed build.
> > > > > > > > >> Satish
> > > > > > > > >> > Dear PETSc dev team,
> > > > > > > > >> > I am compiling petsc 3.15.3 and got following compiling
> > > > error
> > > > > > > > >> > petsc/src/mat/impls/aij/mpi/mumps/mumps.c:52:31: error:
> > > > missing
> > > > > > > binary
> > > > > > > > >> > operator before token "("
> > > > > > > > >> > 52 | #if PETSC_PKG_MUMPS_VERSION_GE(5,3,0)
> > > > > > > > >> > Any idea what I did wrong?
> > > > > > > > >> > Thanks,
> > > > > > > > >> > Sam
