[petsc-users] Memory usage
Karthikeyan Chockalingam - STFC UKRI
karthikeyan.chockalingam at stfc.ac.uk
Fri Oct 29 03:40:06 CDT 2021
Hello,
I used the flags -memory_view -malloc_log to ran a problem on the same size on 32 cores and 64 cores.
I understand what is total, max and min memory usage of the problem is. However I don’t understand the difference between Maximum and Current process memory?
I also curious to understand why the memory usage is different on 32 cores (1 node, 2 sockets with 16 cores/socket) and 64 cores (2 nodes) for a problem of the same size?
On 32 core:
Summary of Memory Usage in PETSc
Maximum (over computational time) process memory: total 7.5014e+10 max 2.6396e+09 min 2.0659e+09
Current process memory: total 3.2583e+10 max 1.3562e+09 min 8.3587e+08
On 64 core:
Maximum (over computational time) process memory: total 7.9337e+10 max 1.5433e+09 min 1.0319e+09
Current process memory: total 6.4491e+10 max 1.2090e+09 min 8.4000e+08
Kind regards,
Karthik.
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211029/81515cb7/attachment.html>
