[petsc-users] Installation on NEC SX-Aurora TSUBASA
Rafael Monteiro da Silva
rafael.m.silva at alumni.usp.br
Thu Oct 28 15:03:21 CDT 2021
Thanks for examplation, Stefano.
I was referring to options for downloading external packages, like mumps.
My understanding is that I'll need to look for how to build those packages
and check if they support nec vector engine, is that correct?
Rafael.
Em qui., 28 de out. de 2021 às 16:54, Stefano Zampini <
stefano.zampini at gmail.com> escreveu:
> On Oct 28, 2021, at 10:52 PM, Rafael Monteiro da Silva <
> rafael.m.silva at alumni.usp.br> wrote:
> Thank you Satish and Stefano for pointing me out how to do this.
> Stefano, if I'm interpreting correctly, I could try to add build options I
> need to this script. Is that correct?
> The script configures PETSc with default options for NEC. I don’t
> recommend changing compilation flags
> First, I'll try to install (based on arch-necve.py script) and then, as
> Satish suggested, include additional build options.
> Good luck with building and running these external packages
> Rafael.
> Em qui., 28 de out. de 2021 às 16:38, Stefano Zampini <
>> Rafael
>> PETSc can be built for NEC vector engines. Here is a sample configure
>> script
>> https://gitlab.com/petsc/petsc/-/blob/main/config/examples/arch-necve.py
>> NEC blas lapack should be automatically used.
>> I don’t know if the packages you need will compile and run smoothly.
>> Their C/C++ compiler is very buggy, and I had to resort compiling with
>> -O1to get almost all PETSc tests pass.
>> PETSc automatically uses this optimization flag if you compile using
>> with-debugging=0. Do not use higher optimizations, unless you are willing
>> to file bug reports to them
>> Stefano
>> On Oct 28, 2021, at 10:12 PM, Rafael Monteiro da Silva <
>> Hello.
>> On my machine, for initial tests, I use the following options to install
>> petsc:
>> PETSC_DIR=/home/rafael/petsc PETSC_ARCH=optimized-v3.15.5
>> --with-debugging=0 COPTFLAGS="-O3 -march=native -mtune=native"
>> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3 -march=native
>> -mtune=native" --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
>> --download-fblaslapack --download-mpich --download-superlu_dist
>> --download-metis --download-parmetis --download-mumps --download-scalapack
>> --download-hdf5
>> I need to test our software in an environment with NEC SX-Aurora
>> TSUBASA Vector Engine.
>> Is there any resource where I can set up petsc to use Vector Engine?
>> Thank you!
>> Regards,
>> Rafael.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211028/f66f2e56/attachment.html>
