[petsc-users] Memory usage
Mark Adams
mfadams at lbl.gov
Fri Oct 29 05:16:45 CDT 2021
On Fri, Oct 29, 2021 at 4:40 AM Karthikeyan Chockalingam - STFC UKRI <
karthikeyan.chockalingam at stfc.ac.uk> wrote:
> Hello,
> I used the flags -memory_view -malloc_log to ran a problem on the same
> size on 32 cores and 64 cores.
> I understand what is total, max and min memory usage of the problem is.
Total is the sum of all 32/62 processes. Max is, as it says "Maximum (over
computational time)"
> However I don’t understand the difference between Maximum and Current
> process memory?
Current memory usage does not include some earlier high water mark in
memory usage.
> I also curious to understand why the memory usage is different on 32 cores
> (1 node, 2 sockets with 16 cores/socket) and 64 cores (2 nodes) for a
> problem of the same size?
There is some data and metadata that is stored redundantly on each process.
> On 32 core:
> Summary of Memory Usage in PETSc
> Maximum (over computational time) process memory: total 7.5014e+10
> max 2.6396e+09 min 2.0659e+09
> Current process memory:
> total 3.2583e+10 max 1.3562e+09 min 8.3587e+08
> On 64 core:
> Maximum (over computational time) process memory: total 7.9337e+10
> max 1.5433e+09 min 1.0319e+09
> total 6.4491e+10 max 1.2090e+09 min 8.4000e+08
> Kind regards,
> Karthik.
> This email and any attachments are intended solely for the use of the
> named recipients. If you are not the intended recipient you must not use,
> disclose, copy or distribute this email or any of its attachments and
> should notify the sender immediately and delete this email from your
> system. UK Research and Innovation (UKRI) has taken every reasonable
> precaution to minimise risk of this email or any attachments containing
> viruses or malware but the recipient should carry out its own virus and
> malware checks before opening the attachments. UKRI does not accept any
> liability for any losses or damages which the recipient may sustain due to
> presence of any viruses.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211029/fbf1e798/attachment.html>
