[petsc-users] Question regarding DMPlex reordering
Matthew Knepley
knepley at gmail.com
Wed Oct 27 09:06:58 CDT 2021
On Wed, Oct 27, 2021 at 9:54 AM Pierre Seize <pierre.seize at onera.fr> wrote:
> Hi, thanks for the fix. It seems to work fine.
> Out of curiosity, I noticed the MatOrderingType of DMPlexGetOrdering is
> not used. Is this intentional ? To match MatGetOrdering ?
True. It only does RCM. I noticed that when fixing it. I have to write
interfaces to the rest of the matrix ordering routines since they are
slightly different for meshes. I will make an issue.
Matt
> Pierre
> On 27/10/21 15:03, Matthew Knepley wrote:
> On Wed, Oct 27, 2021 at 3:15 AM Pierre Seize <pierre.seize at onera.fr>
> wrote:
>> On 26/10/21 22:28, Matthew Knepley wrote:
>> On Tue, Oct 26, 2021 at 10:17 AM Pierre Seize <pierre.seize at onera.fr>
>> wrote:
>>> Hi, I had the idea to try and renumber my mesh cells, as I've heard it's
>>> better: "neighbouring cells are stored next to one another, and memory
>>> access are faster".
>>> Right now, I load the mesh then I distribute it over the processes. I
>>> thought I'd try to permute the numbering between those two steps :
>>> DMPlexCreateFromFile
>>> DMPlexGetOrdering
>>> DMPlexPermute
>>> DMPlexDistribute
>>> but that gives me an error when it runs on more than one process:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: No support for this operation for this object type
>>> [0]PETSC ERROR: Number of dofs for point 0 in the local section should
>>> be positive
>>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.16.0, unknown
>>> [0]PETSC ERROR: ./build/bin/yanss on a named ldmpe202z.onera by pseize
>>> Tue Oct 26 16:03:33 2021
>>> [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-ld-gcc
>>> --download-metis --download-parmetis --prefix=~/.local --with-cgns
>>> [0]PETSC ERROR: #1 PetscPartitionerDMPlexPartition() at
>>> /stck/pseize/softwares/petsc/src/dm/impls/plex/plexpartition.c:720
>>> [0]PETSC ERROR: #2 DMPlexDistribute() at
>>> /stck/pseize/softwares/petsc/src/dm/impls/plex/plexdistribute.c:1630
>>> [0]PETSC ERROR: #3 MeshLoadFromFile() at src/spatial.c:689
>>> [0]PETSC ERROR: #4 main() at src/main.c:22
>>> [0]PETSC ERROR: PETSc Option Table entries:
>>> [0]PETSC ERROR: -draw_comp 0
>>> [0]PETSC ERROR: -mesh data/box.msh
>>> [0]PETSC ERROR: -mesh_view draw
>>> [0]PETSC ERROR: -riemann anrs
>>> [0]PETSC ERROR: -ts_max_steps 100
>>> [0]PETSC ERROR: -vec_view_partition
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> I checked and before I tried to reorder the mesh, the dm->localSection
>>> was NULL before entering DMPlexDistribute, and I was able to fix the
>>> error with DMSetLocalSection(dm, NULL) after DMPlexPermute, but it
>>> doesn't seems it's the right way to do what I want. Does someone have any
>>> advice ?
>> Oh, this is probably me trying to be too clever. If a local section is
>> defined, then I try to use the number of dofs in it to load balance better.
>> There should never be a negative number of dofs in the local section (a
>> global section uses this to indicate a dof owned by another process).
>> So eliminating the local section will definitely fix that error.
>> Now the question of how you got a local section. DMPlexPermute() does
>> not create one, so it seems like you had one ahead of time, and that
>> the values were not valid.
>> DMPlexPermute calls DMGetLocalSection, which creates dm->localSection if
>> it's NULL, so before DMPlexPermute my dm->localSection is NULL, and
>> after it is set. Because of that I enter the if in
>> src/dm/impls/plex/plexpartition.c:707 and then I got the error.
>> If i have a "wrong" dm->localSection, I think it has to come from
>> DMPlexPermute.
>> Note that you can probably get rid of some of the loading code using
>> DMCreate(comm, &dm);
>> DMSetType(dm, DMPLEX);
>> DMSetFromOptions(dm);
>> DMViewFromOptions(dm, NULL, "-mesh_view");
>> and use
>> -dm_plex_filename databox,msh -mesh_view
>> My loading code is already small, but just to make sure I wrote this
>> minimal example:
>> int main(int argc, char **argv){
>> PetscErrorCode ierr;
>> ierr = PetscInitialize(&argc, &argv, NULL, help); if (ierr) return ierr;
>> DM dm, foo_dm;
>> ierr = DMCreate(PETSC_COMM_WORLD, &dm); CHKERRQ(ierr);
>> ierr = DMSetType(dm, DMPLEX); CHKERRQ(ierr);
>> ierr = DMSetFromOptions(dm); CHKERRQ(ierr);
>> IS perm;
>> ierr = DMPlexGetOrdering(dm, NULL, NULL, &perm); CHKERRQ(ierr);
>> ierr = DMPlexPermute(dm, perm, &foo_dm); CHKERRQ(ierr);
>> if (foo_dm) {
>> ierr = DMDestroy(&dm); CHKERRQ(ierr);
>> dm = foo_dm;
>> ierr = DMPlexDistribute(dm, 2, NULL, &foo_dm); CHKERRQ(ierr);
>> if (foo_dm) {
>> dm = foo_dm;
>> ierr = ISDestroy(&perm); CHKERRQ(ierr);
>> ierr = PetscFinalize();
>> return ierr;
>> ran with mpiexec -n 2 ./build/bin/yanss -dm_plex_filename data/box.msh.
>> The mesh is a 2D box from GMSH but I've got the same result with any mesh
>> I've tried. It runs fine with 1 process but gives the previous error for
>> more processes.
> Hi Pierre,
> You are right. This is my bug. Here is the fix:
> https://gitlab.com/petsc/petsc/-/merge_requests/4504
> Is it possible to try this branch?
> Thanks,
> Matt
>> Pierre
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/c81ae0c1/attachment.html>
