[petsc-users] Question regarding DMPlex reordering
Pierre Seize pierre.seize at onera.fr
Wed Oct 27 08:54:09 CDT 2021
Hi, thanks for the fix. It seems to work fine.
Out of curiosity, I noticed the MatOrderingType of DMPlexGetOrdering is
not used. Is this intentional ? To match MatGetOrdering ?
Pierre
On 27/10/21 15:03, Matthew Knepley wrote:
> On Wed, Oct 27, 2021 at 3:15 AM Pierre Seize <pierre.seize at onera.fr
> <mailto:pierre.seize at onera.fr>> wrote:
>     On 26/10/21 22:28, Matthew Knepley wrote:
>>     On Tue, Oct 26, 2021 at 10:17 AM Pierre Seize
>>     <pierre.seize at onera.fr <mailto:pierre.seize at onera.fr>> wrote:
>>         Hi, I had the idea to try and renumber my mesh cells, as I've
>>         heard it's better: "neighbouring cells are stored next to one
>>         another, and memory access are faster".
>>         Right now, I load the mesh then I distribute it over the
>>         processes. I thought I'd try to permute the numbering between
>>         those two steps :
>>             DMPlexCreateFromFile
>>             DMPlexGetOrdering
>>             DMPlexPermute
>>             DMPlexDistribute
>>         but that gives me an error when it runs on more than one process:
>>         [0]PETSC ERROR: --------------------- Error Message
>>         [0]PETSC ERROR: No support for this operation for this object
>>         type
>>         [0]PETSC ERROR: Number of dofs for point 0 in the local
>>         section should be positive
>>         [0]PETSC ERROR: See https://petsc.org/release/faq/ for
>>         trouble shooting.
>>         [0]PETSC ERROR: Petsc Release Version 3.16.0, unknown
>>         [0]PETSC ERROR: ./build/bin/yanss on a  named ldmpe202z.onera
>>         by pseize Tue Oct 26 16:03:33 2021
>>         [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-ld-gcc
>>         --download-metis --download-parmetis --prefix=~/.local
>>         --with-cgns
>>         [0]PETSC ERROR: #1 PetscPartitionerDMPlexPartition() at
>>         /stck/pseize/softwares/petsc/src/dm/impls/plex/plexpartition.c:720
>>         [0]PETSC ERROR: #2 DMPlexDistribute() at
>>         /stck/pseize/softwares/petsc/src/dm/impls/plex/plexdistribute.c:1630
>>         [0]PETSC ERROR: #3 MeshLoadFromFile() at src/spatial.c:689
>>         [0]PETSC ERROR: #4 main() at src/main.c:22
>>         [0]PETSC ERROR: PETSc Option Table entries:
>>         [0]PETSC ERROR: -draw_comp 0
>>         [0]PETSC ERROR: -mesh data/box.msh
>>         [0]PETSC ERROR: -mesh_view draw
>>         [0]PETSC ERROR: -riemann anrs
>>         [0]PETSC ERROR: -ts_max_steps 100
>>         [0]PETSC ERROR: -vec_view_partition
>>         [0]PETSC ERROR: ----------------End of Error Message
>>         -------send entire error message to petsc-maint at mcs.anl.gov
>>         <mailto:petsc-maint at mcs.anl.gov>----------
>>         I checked and before I tried to reorder the mesh, the
>>         dm->localSection was NULL before entering DMPlexDistribute,
>>         and I was able to fix the error with DMSetLocalSection(dm,
>>         NULL) after DMPlexPermute, but it doesn't seems it's the
>>         right way to do what I want. Does someone have any advice ?
>>     Oh, this is probably me trying to be too clever. If a local
>>     section is defined, then I try to use the number of dofs in it to
>>     load balance better.
>>     There should never be a negative number of dofs in the local
>>     section (a global section uses this to indicate a dof owned by
>>     another process).
>>     So eliminating the local section will definitely fix that error.
>>     Now the question of how you got a local section. DMPlexPermute()
>>     does not create one, so it seems like you had one ahead of time,
>>     and that
>>     the values were not valid.
>     DMPlexPermute calls DMGetLocalSection, which creates
>     dm->localSection if it's NULL, so before DMPlexPermute my
>     dm->localSection is NULL, and after it is set. Because of that I
>     enter the if in src/dm/impls/plex/plexpartition.c:707 and then I
>     got the error.
>     If i have a "wrong" dm->localSection, I think it has to come from
>     DMPlexPermute.
>>     Note that you can probably get rid of some of the loading code using
>>       DMCreate(comm, &dm);
>>       DMSetType(dm, DMPLEX);
>>       DMSetFromOptions(dm);
>>       DMViewFromOptions(dm, NULL, "-mesh_view");
>>     and use
>>       -dm_plex_filename databox,msh -mesh_view
>     My loading code is already small, but just to make sure I wrote
>     this minimal example:
>     int main(int argc, char **argv){
>       PetscErrorCode ierr;
>       ierr = PetscInitialize(&argc, &argv, NULL, help); if (ierr)
>     return ierr;
>       DM dm, foo_dm;
>       ierr = DMCreate(PETSC_COMM_WORLD, &dm); CHKERRQ(ierr);
>       ierr = DMSetType(dm, DMPLEX); CHKERRQ(ierr);
>       ierr = DMSetFromOptions(dm); CHKERRQ(ierr);
>       IS perm;
>       ierr = DMPlexGetOrdering(dm, NULL, NULL, &perm); CHKERRQ(ierr);
>       ierr = DMPlexPermute(dm, perm, &foo_dm); CHKERRQ(ierr);
>       if (foo_dm) {
>         ierr = DMDestroy(&dm); CHKERRQ(ierr);
>         dm = foo_dm;
>       ierr = DMPlexDistribute(dm, 2, NULL, &foo_dm); CHKERRQ(ierr);
>       if (foo_dm) {
>         dm = foo_dm;
>       ierr = ISDestroy(&perm); CHKERRQ(ierr);
>       ierr = PetscFinalize();
>       return ierr;
>     ran with mpiexec -n 2 ./build/bin/yanss -dm_plex_filename
>     data/box.msh. The mesh is a 2D box from GMSH but I've got the same
>     result with any mesh I've tried. It runs fine with 1 process but
>     gives the previous error for more processes.
> Hi Pierre,
> You are right. This is my bug. Here is the fix:
> https://gitlab.com/petsc/petsc/-/merge_requests/4504
> Is it possible to try this branch?
>   Thanks,
>      Matt
>     Pierre
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/%7Eknepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7a0356db/attachment-0001.html>
