[petsc-users] Question regarding DMPlex reordering
Matthew Knepley
knepley at gmail.com
Wed Oct 27 08:03:39 CDT 2021
On Wed, Oct 27, 2021 at 3:15 AM Pierre Seize <pierre.seize at onera.fr> wrote:
> On 26/10/21 22:28, Matthew Knepley wrote:
> On Tue, Oct 26, 2021 at 10:17 AM Pierre Seize <pierre.seize at onera.fr>
> wrote:
>> Hi, I had the idea to try and renumber my mesh cells, as I've heard it's
>> better: "neighbouring cells are stored next to one another, and memory
>> access are faster".
>> Right now, I load the mesh then I distribute it over the processes. I
>> thought I'd try to permute the numbering between those two steps :
>> DMPlexCreateFromFile
>> DMPlexGetOrdering
>> DMPlexPermute
>> DMPlexDistribute
>> but that gives me an error when it runs on more than one process:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: No support for this operation for this object type
>> [0]PETSC ERROR: Number of dofs for point 0 in the local section should be
>> positive
>> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.16.0, unknown
>> [0]PETSC ERROR: ./build/bin/yanss on a named ldmpe202z.onera by pseize
>> Tue Oct 26 16:03:33 2021
>> [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-ld-gcc
>> --download-metis --download-parmetis --prefix=~/.local --with-cgns
>> [0]PETSC ERROR: #1 PetscPartitionerDMPlexPartition() at
>> /stck/pseize/softwares/petsc/src/dm/impls/plex/plexpartition.c:720
>> [0]PETSC ERROR: #2 DMPlexDistribute() at
>> /stck/pseize/softwares/petsc/src/dm/impls/plex/plexdistribute.c:1630
>> [0]PETSC ERROR: #3 MeshLoadFromFile() at src/spatial.c:689
>> [0]PETSC ERROR: #4 main() at src/main.c:22
>> [0]PETSC ERROR: PETSc Option Table entries:
>> [0]PETSC ERROR: -draw_comp 0
>> [0]PETSC ERROR: -mesh data/box.msh
>> [0]PETSC ERROR: -mesh_view draw
>> [0]PETSC ERROR: -riemann anrs
>> [0]PETSC ERROR: -ts_max_steps 100
>> [0]PETSC ERROR: -vec_view_partition
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> I checked and before I tried to reorder the mesh, the dm->localSection
>> was NULL before entering DMPlexDistribute, and I was able to fix the
>> error with DMSetLocalSection(dm, NULL) after DMPlexPermute, but it
>> doesn't seems it's the right way to do what I want. Does someone have any
>> advice ?
> Oh, this is probably me trying to be too clever. If a local section is
> defined, then I try to use the number of dofs in it to load balance better.
> There should never be a negative number of dofs in the local section (a
> global section uses this to indicate a dof owned by another process).
> So eliminating the local section will definitely fix that error.
> Now the question of how you got a local section. DMPlexPermute() does not
> create one, so it seems like you had one ahead of time, and that
> the values were not valid.
> DMPlexPermute calls DMGetLocalSection, which creates dm->localSection if
> it's NULL, so before DMPlexPermute my dm->localSection is NULL, and after
> it is set. Because of that I enter the if in
> src/dm/impls/plex/plexpartition.c:707 and then I got the error.
> If i have a "wrong" dm->localSection, I think it has to come from
> DMPlexPermute.
> Note that you can probably get rid of some of the loading code using
> DMCreate(comm, &dm);
> DMSetType(dm, DMPLEX);
> DMSetFromOptions(dm);
> DMViewFromOptions(dm, NULL, "-mesh_view");
> and use
> -dm_plex_filename databox,msh -mesh_view
> My loading code is already small, but just to make sure I wrote this
> minimal example:
> int main(int argc, char **argv){
> PetscErrorCode ierr;
> ierr = PetscInitialize(&argc, &argv, NULL, help); if (ierr) return ierr;
> DM dm, foo_dm;
> ierr = DMCreate(PETSC_COMM_WORLD, &dm); CHKERRQ(ierr);
> ierr = DMSetType(dm, DMPLEX); CHKERRQ(ierr);
> ierr = DMSetFromOptions(dm); CHKERRQ(ierr);
> IS perm;
> ierr = DMPlexGetOrdering(dm, NULL, NULL, &perm); CHKERRQ(ierr);
> ierr = DMPlexPermute(dm, perm, &foo_dm); CHKERRQ(ierr);
> if (foo_dm) {
> ierr = DMDestroy(&dm); CHKERRQ(ierr);
> dm = foo_dm;
> ierr = DMPlexDistribute(dm, 2, NULL, &foo_dm); CHKERRQ(ierr);
> if (foo_dm) {
> dm = foo_dm;
> ierr = ISDestroy(&perm); CHKERRQ(ierr);
> ierr = PetscFinalize();
> return ierr;
> ran with mpiexec -n 2 ./build/bin/yanss -dm_plex_filename data/box.msh.
> The mesh is a 2D box from GMSH but I've got the same result with any mesh
> I've tried. It runs fine with 1 process but gives the previous error for
> more processes.
Hi Pierre,
You are right. This is my bug. Here is the fix:
https://gitlab.com/petsc/petsc/-/merge_requests/4504
Is it possible to try this branch?
Matt
> Pierre
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/87430a63/attachment.html>
