[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Wed Oct 27 07:29:03 CDT 2021
Hi Matthew,
the smallest mesh which crashes the code is a 2x5 mesh:
See the modified ex44.c
With smaller meshes(2x2, 2x4, etc), it passes... But it bugs latter
when I try to use DMPlexNaturalToGlobalBegin but let's keep that other
problem for later...
Thanks a lot for helping digging into this! :)
Eric
(sorry if you received this for a 2nd times, I have trouble with my mail)
On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
> Here is a screenshot of the partition I hard coded (top) and
> vertices/element numbers (down):
> I have not yet modified the ex44.c example to properly assign the
> coordinates...
> (but I would not have done it like it is in the last version
> because the sCoords array is the global array with global vertices
> number)
> I will have time to do this tomorrow...
> Maybe I can first try to reproduce all this with a smaller mesh?
> That might make it easier to find a problem.
> Thanks!
> Matt
> Eric
> On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>> Okay, I ran it. Something seems off with the mesh. First, I
>> cannot simply explain the partition. The number of shared
>> vertices and edges
>> does not seem to come from a straight cut. Second, the mesh look
>> scrambled on output.
>> Thanks,
>> Matt
>> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland
>> Hi Matthew,
>> ok, I started back from your ex44.c example and added the
>> global array of coordinates. I just have to code the
>> creation of the local coordinates now.
>> Eric
>> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland
>>> Hi Matthew,
>>> we tried to reproduce the error in a simple example.
>>> The context is the following: We hard coded the mesh and
>>> initial partition into the code (see sConnectivity and
>>> sInitialPartition) for 2 ranks and try to create a
>>> section in order to use the DMPlexNaturalToGlobalBegin
>>> function to retreive our initial element numbers.
>>> Now the call to DMPlexDistribute give different errors
>>> depending on what type of component we ask the field to
>>> be created. For our objective, we would like a global
>>> field to be created on elements only (like a P0
>>> interpolation).
>>> We now have the following error generated:
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>> [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>>> [0]PETSC ERROR: See
>>> https://www.mcs.anl.gov/petsc/documentation/faq.html
>>> <https://www.mcs.anl.gov/petsc/documentation/faq.html>
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>>> [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct
>>> 20 14:52:36 2021
>>> [0]PETSC ERROR: Configure options
>>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
>>> --with-mpi-compilers=1
>>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
>>> --with-cxx-dialect=C++14 --with-make-np=12
>>> --with-shared-libraries=1 --with-debugging=yes
>>> --with-memalign=64 --with-visibility=0
>>> --with-64-bit-indices=0 --download-ml=yes
>>> --download-mumps=yes --download-superlu=yes
>>> --download-hpddm=yes --download-slepc=yes
>>> --download-superlu_dist=yes --download-parmetis=yes
>>> --download-ptscotch=yes --download-metis=yes
>>> --download-strumpack=yes --download-suitesparse=yes
>>> --download-hypre=yes
>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>> --with-scalapack=1
>>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>> [0]PETSC ERROR: No PETSc Option Table entries
>>> [0]PETSC ERROR: ----------------End of Error Message
>>> -------send entire error message to
>>> petsc-maint at mcs.anl.gov
>>> <mailto:petsc-maint at mcs.anl.gov>----------
>>> Hope the attached code is self-explaining, note that to
>>> make it short, we have not included the final part of
>>> it, just the buggy part we are encountering right now...
>>> Thanks for your insights,
>>> Thanks for making the example. I tweaked it slightly. I put
>>> in a test case that just makes a parallel 7 x 10 quad mesh.
>>> This works
>>> fine. Thus I think it must be something connected with the
>>> original mesh. It is hard to get a handle on it without the
>>> coordinates.
>>> Do you think you could put the coordinate array in? I have
>>> added the code to load them (see attached file).
>>> Thanks,
>>> Matt
>>> Eric
>>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland
>>>> Hi Matthew,
>>>> we tried to use that. Now, we discovered that:
>>>> 1- even if we "ask" for sfNatural creation with
>>>> DMSetUseNatural, it is not created because
>>>> DMPlexCreateGlobalToNaturalSF looks for a
>>>> "section": this is not documented in
>>>> DMSetUseNaturalso we are asking ourselfs: "is this
>>>> a permanent feature or a temporary situation?"
>>>> I think explaining this will help clear up a lot.
>>>> What the Natural2Global map does is permute a solution
>>>> vector into the ordering that it would have had prior
>>>> to mesh distribution.
>>>> Now, in order to do this permutation, I need to know
>>>> the original (global) data layout. If it is not
>>>> specified _before_ distribution, we
>>>> cannot build the permutation. The section describes
>>>> the data layout, so I need it before distribution.
>>>> I cannot think of another way that you would implement
>>>> this, but if you want something else, let me know.
>>>> 2- We then tried to create a "section" in different
>>>> manners: we took the code into the example
>>>> petsc/src/dm/impls/plex/tests/ex15.c. However, we
>>>> ended up with a segfault:
>>>> corrupted size vs. prev_size
>>>> [rohan:07297] *** Process received signal ***
>>>> [rohan:07297] Signal: Aborted (6)
>>>> [rohan:07297] Signal code: (-6)
>>>> [rohan:07297] [ 0]
>>>> /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>> [rohan:07297] [ 1]
>>>> /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>> [rohan:07297] [ 2]
>>>> /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>> [rohan:07297] [ 3]
>>>> /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>> [rohan:07297] [ 4]
>>>> /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>> [rohan:07297] [ 5]
>>>> /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>> [rohan:07297] [ 6]
>>>> /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>> [rohan:07297] [ 7]
>>>> /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>> [rohan:07297] [ 8]
>>>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>> [rohan:07297] [ 9]
>>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>> [rohan:07297] [10]
>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>> [rohan:07297] [11]
>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>> [rohan:07297] [12]
>>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>> [rohan:07297] [13]
>>>> /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>> [rohan:07297] [14]
>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>> [rohan:07297] [15]
>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>> [rohan:07297] [16]
>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>> [rohan:07297] [17]
>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>> [rohan:07297] [18]
>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>> I am not sure what happened here, but if you could send
>>>> a sample code, I will figure it out.
>>>> If we do not create a section, the call to
>>>> DMPlexDistribute is successful, but
>>>> DMPlexGetGlobalToNaturalSF return a null SF pointer...
>>>> Yes, it just ignores it in this case because it does
>>>> not have a global layout.
>>>> Here are the operations we are calling ( this is
>>>> almost the code we are using, I just removed
>>>> verifications and creation of the connectivity
>>>> which use our parallel structure and code):
>>>> PetscInt* lCells = 0;
>>>> PetscInt lNumCorners = 0;
>>>> PetscInt lDimMail = 0;
>>>> PetscInt lnumCells = 0;
>>>> //At this point we create the cells for PETSc
>>>> expected input for DMPlexBuildFromCellListParallel
>>>> and set lNumCorners, lDimMail and lnumCells to
>>>> correct values.
>>>> DM lDMBete = 0
>>>> DMPlexCreate(lMPIComm,&lDMBete);
>>>> DMSetDimension(lDMBete, lDimMail);
>>>> DMPlexBuildFromCellListParallel(lDMBete,
>>>> lnumCells,
>>>> PETSC_DECIDE,
>>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>>> lNumCorners,
>>>> lCells,
>>>> PETSC_NULL);
>>>> DM lDMBeteInterp = 0;
>>>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>> DMDestroy(&lDMBete);
>>>> lDMBete = lDMBeteInterp;
>>>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>> PetscSF lSFMigrationSansOvl = 0;
>>>> PetscSF lSFMigrationOvl = 0;
>>>> DM lDMDistribueSansOvl = 0;
>>>> DM lDMAvecOverlap = 0;
>>>> PetscPartitioner lPart;
>>>> DMPlexGetPartitioner(lDMBete, &lPart);
>>>> PetscPartitionerSetFromOptions(lPart);
>>>> PetscSection section;
>>>> PetscInt numFields = 1;
>>>> PetscInt numBC = 0;
>>>> PetscInt numComp[1] = {1};
>>>> PetscInt numDof[4] = {1, 0, 0, 0};
>>>> PetscInt bcFields[1] = {0};
>>>> IS bcPoints[1] = {NULL};
>>>> DMSetNumFields(lDMBete, numFields);
>>>> DMPlexCreateSection(lDMBete, NULL, numComp, numDof,
>>>> numBC, bcFields, bcPoints, NULL, NULL, §ion);
>>>> DMSetLocalSection(lDMBete, section);
>>>> DMPlexDistribute(lDMBete, 0,
>>>> &lSFMigrationSansOvl, &lDMDistribueSansOvl); //
>>>> segfault!
>>>> So we have other question/remarks:
>>>> 3- Maybe PETSc expect something specific that is
>>>> missing/not verified: for example, we didn't gave
>>>> any coordinates since we just want to partition and
>>>> compute overlap for the mesh... and then recover
>>>> our element numbers in a "simple way"
>>>> 4- We are telling ourselves it is somewhat a "big
>>>> price to pay" to have to build an unused section to
>>>> have the global to natural ordering set ? Could
>>>> this requirement be avoided?
>>>> I don't think so. There would have to be _some_ way of
>>>> describing your data layout in terms of mesh points,
>>>> and I do not see how you could use less memory doing that.
>>>> 5- Are there any improvement towards our usages in
>>>> 3.16 release?
>>>> Let me try and run the code above.
>>>> Thanks,
>>>> Matt
>>>> Thanks,
>>>> Eric
>>>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>> On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland
>>>>> Hi,
>>>>> I come back with _almost_ the original question:
>>>>> I would like to add an integer information
>>>>> (*our* original element
>>>>> number, not petsc one) on each element of the
>>>>> DMPlex I create with
>>>>> DMPlexBuildFromCellListParallel.
>>>>> I would like this interger to be distribruted
>>>>> by or the same way
>>>>> DMPlexDistribute distribute the mesh.
>>>>> Is it possible to do this?
>>>>> I think we already have support for what you want.
>>>>> If you call
>>>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>> <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>>>> before DMPlexDistribute(), it will compute a
>>>>> PetscSF encoding the global to natural map. You
>>>>> can get it with
>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>>>> and use it with
>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>>>> Is this sufficient?
>>>>> Thanks,
>>>>> Matt
>>>>> Thanks,
>>>>> Eric
>>>>> On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>>> > Hi,
>>>>> > I want to use DMPlexDistribute from PETSc
>>>>> for computing overlapping
>>>>> > and play with the different partitioners
>>>>> supported.
>>>>> > However, after calling DMPlexDistribute, I
>>>>> noticed the elements are
>>>>> > renumbered and then the original number is lost.
>>>>> > What would be the best way to keep track of
>>>>> the element renumbering?
>>>>> > a) Adding an optional parameter to let the
>>>>> user retrieve a vector or
>>>>> > "IS" giving the old number?
>>>>> > b) Adding a DMLabel (seems a wrong good
>>>>> solution)
>>>>> > c) Other idea?
>>>>> > Of course, I don't want to loose
>>>>> performances with the need of this
>>>>> > "mapping"...
>>>>> > Thanks,
>>>>> > Eric
>>>>> Eric Chamberland, ing., M. Ing
>>>>> Professionnel de recherche
>>>>> GIREF/Université Laval
>>>>> (418) 656-2131 poste 41 22 42
>>>>> What most experimenters take for granted before
>>>>> they begin their experiments is infinitely more
>>>>> interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> What most experimenters take for granted before they
>>>> begin their experiments is infinitely more interesting
>>>> than any results to which their experiments lead.
>>>> -- Norbert Wiener
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> -- Norbert Wiener
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7b49e4fd/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7b49e4fd/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7b49e4fd/attachment-0003.png>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/7b49e4fd/attachment-0001.bin>
