[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Tue Oct 26 23:17:36 CDT 2021
Hi Matthew,
the smallest mesh which crashes the code is a 2x5 mesh:
See the modified ex44.c
With smaller meshes(2x2, 2x4, etc), it passes...  But it bugs latter
when I try to use DMPlexNaturalToGlobalBegin but let's keep that other
problem for later...
Thanks a lot for helping digging into this! :)
Eric
On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>     Here is a screenshot of the partition I hard coded (top) and
>     vertices/element numbers (down):
>     I have not yet modified the ex44.c example to properly assign the
>     coordinates...
>     (but I would not have done it like it is in the last version
>     because the sCoords array is the global array with global vertices
>     number)
>     I will have time to do this tomorrow...
>     Maybe I can first try to reproduce all this with a smaller mesh?
> That might make it easier to find a problem.
>   Thanks!
>      Matt
>     Eric
>     On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>>     Okay, I ran it. Something seems off with the mesh. First, I
>>     cannot simply explain the partition. The number of shared
>>     vertices and edges
>>     does not seem to come from a straight cut. Second, the mesh look
>>     scrambled on output.
>>       Thanks,
>>         Matt
>>     On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland
>>         Hi Matthew,
>>         ok, I started back from your ex44.c example and added the
>>         global array of coordinates.  I just have to code the
>>         creation of the local coordinates now.
>>         Eric
>>         On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>>         On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland
>>>             Hi Matthew,
>>>             we tried to reproduce the error in a simple example.
>>>             The context is the following: We hard coded the mesh and
>>>             initial partition into the code (see sConnectivity and
>>>             sInitialPartition) for 2 ranks and try to create a
>>>             section in order to use the DMPlexNaturalToGlobalBegin
>>>             function to retreive our initial element numbers.
>>>             Now the call to DMPlexDistribute give different errors
>>>             depending on what type of component we ask the field to
>>>             be created.  For our objective, we would like a global
>>>             field to be created on elements only (like a P0
>>>             interpolation).
>>>             We now have the following error generated:
>>>             [0]PETSC ERROR: --------------------- Error Message
>>>             [0]PETSC ERROR: Petsc has generated inconsistent data
>>>             [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>>>             [0]PETSC ERROR: See
>>>             https://www.mcs.anl.gov/petsc/documentation/faq.html
>>>             <https://www.mcs.anl.gov/petsc/documentation/faq.html>
>>>             for trouble shooting.
>>>             [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>>>             [0]PETSC ERROR: ./bug on a  named rohan by ericc Wed Oct
>>>             20 14:52:36 2021
>>>             [0]PETSC ERROR: Configure options
>>>             --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
>>>             --with-mpi-compilers=1
>>>             --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
>>>             --with-cxx-dialect=C++14 --with-make-np=12
>>>             --with-shared-libraries=1 --with-debugging=yes
>>>             --with-memalign=64 --with-visibility=0
>>>             --with-64-bit-indices=0 --download-ml=yes
>>>             --download-mumps=yes --download-superlu=yes
>>>             --download-hpddm=yes --download-slepc=yes
>>>             --download-superlu_dist=yes --download-parmetis=yes
>>>             --download-ptscotch=yes --download-metis=yes
>>>             --download-strumpack=yes --download-suitesparse=yes
>>>             --download-hypre=yes
>>>             --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>             --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>             --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>             --with-scalapack=1
>>>             --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>             --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>             -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>>             [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>>             /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>             [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>>>             /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>             [0]PETSC ERROR: #3 DMPlexDistribute() at
>>>             /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>             [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>>             [0]PETSC ERROR: No PETSc Option Table entries
>>>             [0]PETSC ERROR: ----------------End of Error Message
>>>             -------send entire error message to
>>>             petsc-maint at mcs.anl.gov
>>>             <mailto:petsc-maint at mcs.anl.gov>----------
>>>             Hope the attached code is self-explaining, note that to
>>>             make it short, we have not included the final part of
>>>             it, just the buggy part we are encountering right now...
>>>             Thanks for your insights,
>>>         Thanks for making the example. I tweaked it slightly. I put
>>>         in a test case that just makes a parallel 7 x 10 quad mesh.
>>>         This works
>>>         fine. Thus I think it must be something connected with the
>>>         original mesh. It is hard to get a handle on it without the
>>>         coordinates.
>>>         Do you think you could put the coordinate array in? I have
>>>         added the code to load them (see attached file).
>>>           Thanks,
>>>              Matt
>>>             Eric
>>>             On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>>             On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland
>>>>                 Hi Matthew,
>>>>                 we tried to use that.  Now, we discovered that:
>>>>                 1- even if we "ask" for sfNatural creation with
>>>>                 DMSetUseNatural, it is not created because
>>>>                 DMPlexCreateGlobalToNaturalSF looks for a
>>>>                 "section": this is not documented in
>>>>                 DMSetUseNaturalso we are asking ourselfs: "is this
>>>>                 a permanent feature or a temporary situation?"
>>>>             I think explaining this will help clear up a lot.
>>>>             What the Natural2Global map does is permute a solution
>>>>             vector into the ordering that it would have had prior
>>>>             to mesh distribution.
>>>>             Now, in order to do this permutation, I need to know
>>>>             the original (global) data layout. If it is not
>>>>             specified _before_ distribution, we
>>>>             cannot build the permutation.  The section describes
>>>>             the data layout, so I need it before distribution.
>>>>             I cannot think of another way that you would implement
>>>>             this, but if you want something else, let me know.
>>>>                 2- We then tried to create a "section" in different
>>>>                 manners: we took the code into the example
>>>>                 petsc/src/dm/impls/plex/tests/ex15.c. However, we
>>>>                 ended up with a segfault:
>>>>                 corrupted size vs. prev_size
>>>>                 [rohan:07297] *** Process received signal ***
>>>>                 [rohan:07297] Signal: Aborted (6)
>>>>                 [rohan:07297] Signal code: (-6)
>>>>                 [rohan:07297] [ 0]
>>>>                 /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>                 [rohan:07297] [ 1]
>>>>                 /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>                 [rohan:07297] [ 2]
>>>>                 /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>                 [rohan:07297] [ 3]
>>>>                 /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>                 [rohan:07297] [ 4]
>>>>                 /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>                 [rohan:07297] [ 5]
>>>>                 /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>                 [rohan:07297] [ 6]
>>>>                 /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>                 [rohan:07297] [ 7]
>>>>                 /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>                 [rohan:07297] [ 8]
>>>>                 /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>                 [rohan:07297] [ 9]
>>>>                 /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>                 [rohan:07297] [10]
>>>>                 /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>                 [rohan:07297] [11]
>>>>                 /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>                 [rohan:07297] [12]
>>>>                 /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>                 [rohan:07297] [13]
>>>>                 /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>                 [rohan:07297] [14]
>>>>                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>                 [rohan:07297] [15]
>>>>                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>                 [rohan:07297] [16]
>>>>                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>                 [rohan:07297] [17]
>>>>                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>                 [rohan:07297] [18]
>>>>                 /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>>             I am not sure what happened here, but if you could send
>>>>             a sample code, I will figure it out.
>>>>                 If we do not create a section, the call to
>>>>                 DMPlexDistribute is successful, but
>>>>                 DMPlexGetGlobalToNaturalSF return a null SF pointer...
>>>>             Yes, it just ignores it in this case because it does
>>>>             not have a global layout.
>>>>                 Here are the operations we are calling ( this is
>>>>                 almost the code we are using, I just removed
>>>>                 verifications and creation of the connectivity
>>>>                 which use our parallel structure and code):
>>>>                   PetscInt* lCells      = 0;
>>>>                   PetscInt  lNumCorners = 0;
>>>>                   PetscInt  lDimMail    = 0;
>>>>                   PetscInt  lnumCells   = 0;
>>>>                   //At this point we create the cells for PETSc
>>>>                 expected input for DMPlexBuildFromCellListParallel
>>>>                 and set lNumCorners, lDimMail and lnumCells to
>>>>                 correct values.
>>>>                   DM       lDMBete = 0
>>>>                 DMPlexCreate(lMPIComm,&lDMBete);
>>>>                   DMSetDimension(lDMBete, lDimMail);
>>>>                 DMPlexBuildFromCellListParallel(lDMBete,
>>>>                                                   lnumCells,
>>>>                                                   PETSC_DECIDE,
>>>>                 pLectureElementsLocaux.reqNbTotalSommets(),
>>>>                                                   lNumCorners,
>>>>                                                   lCells,
>>>>                                                   PETSC_NULL);
>>>>                   DM lDMBeteInterp = 0;
>>>>                   DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>>                   DMDestroy(&lDMBete);
>>>>                   lDMBete = lDMBeteInterp;
>>>>                 DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>                   PetscSF lSFMigrationSansOvl = 0;
>>>>                   PetscSF lSFMigrationOvl = 0;
>>>>                   DM lDMDistribueSansOvl = 0;
>>>>                   DM lDMAvecOverlap = 0;
>>>>                   PetscPartitioner lPart;
>>>>                 DMPlexGetPartitioner(lDMBete, &lPart);
>>>>                 PetscPartitionerSetFromOptions(lPart);
>>>>                   PetscSection   section;
>>>>                   PetscInt       numFields = 1;
>>>>                   PetscInt       numBC = 0;
>>>>                   PetscInt       numComp[1] = {1};
>>>>                   PetscInt       numDof[4] = {1, 0, 0, 0};
>>>>                   PetscInt       bcFields[1] = {0};
>>>>                   IS             bcPoints[1] = {NULL};
>>>>                   DMSetNumFields(lDMBete, numFields);
>>>>                 DMPlexCreateSection(lDMBete, NULL, numComp, numDof,
>>>>                 numBC, bcFields, bcPoints, NULL, NULL, &section);
>>>>                   DMSetLocalSection(lDMBete, section);
>>>>                   DMPlexDistribute(lDMBete, 0,
>>>>                 &lSFMigrationSansOvl, &lDMDistribueSansOvl); //
>>>>                 segfault!
>>>>                 So we have other question/remarks:
>>>>                 3- Maybe PETSc expect something specific that is
>>>>                 missing/not verified: for example, we didn't gave
>>>>                 any coordinates since we just want to partition and
>>>>                 compute overlap for the mesh... and then recover
>>>>                 our element numbers in a "simple way"
>>>>                 4- We are telling ourselves it is somewhat a "big
>>>>                 price to pay" to have to build an unused section to
>>>>                 have the global to natural ordering set ?  Could
>>>>                 this requirement be avoided?
>>>>             I don't think so. There would have to be _some_ way of
>>>>             describing your data layout in terms of mesh points,
>>>>             and I do not see how you could use less memory doing that.
>>>>                 5- Are there any improvement towards our usages in
>>>>                 3.16 release?
>>>>             Let me try and run the code above.
>>>>               Thanks,
>>>>                  Matt
>>>>                 Thanks,
>>>>                 Eric
>>>>                 On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>>                 On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland
>>>>>                     Hi,
>>>>>                     I come back with _almost_ the original question:
>>>>>                     I would like to add an integer information
>>>>>                     (*our* original element
>>>>>                     number, not petsc one) on each element of the
>>>>>                     DMPlex I create with
>>>>>                     DMPlexBuildFromCellListParallel.
>>>>>                     I would like this interger to be distribruted
>>>>>                     by or the same way
>>>>>                     DMPlexDistribute distribute the mesh.
>>>>>                     Is it possible to do this?
>>>>>                 I think we already have support for what you want.
>>>>>                 If you call
>>>>>                 https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>>                 <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>>>>                 before DMPlexDistribute(), it will compute a
>>>>>                 PetscSF encoding the global to natural map. You
>>>>>                 can get it with
>>>>>                 https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>>                 <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>>>>                 and use it with
>>>>>                 https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>>                 <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>>>>                 Is this sufficient?
>>>>>                   Thanks,
>>>>>                      Matt
>>>>>                     Thanks,
>>>>>                     Eric
>>>>>                     On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>>>                     > Hi,
>>>>>                     > I want to use DMPlexDistribute from PETSc
>>>>>                     for computing overlapping
>>>>>                     > and play with the different partitioners
>>>>>                     supported.
>>>>>                     > However, after calling DMPlexDistribute, I
>>>>>                     noticed the elements are
>>>>>                     > renumbered and then the original number is lost.
>>>>>                     > What would be the best way to keep track of
>>>>>                     the element renumbering?
>>>>>                     > a) Adding an optional parameter to let the
>>>>>                     user retrieve a vector or
>>>>>                     > "IS" giving the old number?
>>>>>                     > b) Adding a DMLabel (seems a wrong good
>>>>>                     solution)
>>>>>                     > c) Other idea?
>>>>>                     > Of course, I don't want to loose
>>>>>                     performances with the need of this
>>>>>                     > "mapping"...
>>>>>                     > Thanks,
>>>>>                     > Eric
>>>>>                     Eric Chamberland, ing., M. Ing
>>>>>                     Professionnel de recherche
>>>>>                     GIREF/Université Laval
>>>>>                     (418) 656-2131 poste 41 22 42
>>>>>                 What most experimenters take for granted before
>>>>>                 they begin their experiments is infinitely more
>>>>>                 interesting than any results to which their
>>>>>                 experiments lead.
>>>>>                 -- Norbert Wiener
>>>>>                 https://www.cse.buffalo.edu/~knepley/
>>>>>                 <http://www.cse.buffalo.edu/~knepley/>
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/1154aac4/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/1154aac4/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/1154aac4/attachment-0003.png>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/1154aac4/attachment-0001.bin>
