[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Wed Oct 27 10:14:27 CDT 2021
On Wed, Oct 27, 2021 at 8:29 AM Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi Matthew,
> the smallest mesh which crashes the code is a 2x5 mesh:
> See the modified ex44.c
> With smaller meshes(2x2, 2x4, etc), it passes...  But it bugs latter when
> I try to use DMPlexNaturalToGlobalBegin but let's keep that other problem
> for later...
> Thanks a lot for helping digging into this! :)
I have made a small fix in this branch
  https://gitlab.com/petsc/petsc/-/commits/knepley/fix-plex-g2n
It seems to run for me. Can you check it?
     Matt
> Eric
> (sorry if you received this for a  2nd times, I have trouble with my mail)
> On 2021-10-26 4:35 p.m., Matthew Knepley wrote:
> On Tue, Oct 26, 2021 at 1:35 PM Eric Chamberland <
>> Here is a screenshot of the partition I hard coded (top) and
>> vertices/element numbers (down):
>> I have not yet modified the ex44.c example to properly assign the
>> coordinates...
>> (but I would not have done it like it is in the last version because the
>> sCoords array is the global array with global vertices number)
>> I will have time to do this tomorrow...
>> Maybe I can first try to reproduce all this with a smaller mesh?
> That might make it easier to find a problem.
>   Thanks!
>      Matt
>> Eric
>> On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
>> Okay, I ran it. Something seems off with the mesh. First, I cannot simply
>> explain the partition. The number of shared vertices and edges
>> does not seem to come from a straight cut. Second, the mesh look
>> scrambled on output.
>>   Thanks,
>>     Matt
>> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland <
>>> Hi Matthew,
>>> ok, I started back from your ex44.c example and added the global array
>>> of coordinates.  I just have to code the creation of the local coordinates
>>> now.
>>> Eric
>>> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland <
>>>> Hi Matthew,
>>>> we tried to reproduce the error in a simple example.
>>>> The context is the following: We hard coded the mesh and initial
>>>> partition into the code (see sConnectivity and sInitialPartition) for 2
>>>> ranks and try to create a section in order to use the
>>>> DMPlexNaturalToGlobalBegin function to retreive our initial element numbers.
>>>> Now the call to DMPlexDistribute give different errors depending on
>>>> what type of component we ask the field to be created.  For our objective,
>>>> we would like a global field to be created on elements only (like a P0
>>>> interpolation).
>>>> We now have the following error generated:
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Petsc has generated inconsistent data
>>>> [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>>>> [0]PETSC ERROR: See
>>>> https://www.mcs.anl.gov/petsc/documentation/faq.html for trouble
>>>> shooting.
>>>> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>>>> [0]PETSC ERROR: ./bug on a  named rohan by ericc Wed Oct 20 14:52:36
>>>> 2021
>>>> [0]PETSC ERROR: Configure options
>>>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1
>>>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14
>>>> --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes
>>>> --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0
>>>> --download-ml=yes --download-mumps=yes --download-superlu=yes
>>>> --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes
>>>> --download-parmetis=yes --download-ptscotch=yes --download-metis=yes
>>>> --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes
>>>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>>> --with-scalapack=1
>>>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>>> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>>>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>>> [0]PETSC ERROR: No PETSc Option Table entries
>>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>>> error message to petsc-maint at mcs.anl.gov----------
>>>> Hope the attached code is self-explaining, note that to make it short,
>>>> we have not included the final part of it, just the buggy part we are
>>>> encountering right now...
>>>> Thanks for your insights,
>>> Thanks for making the example. I tweaked it slightly. I put in a test
>>> case that just makes a parallel 7 x 10 quad mesh. This works
>>> fine. Thus I think it must be something connected with the original
>>> mesh. It is hard to get a handle on it without the coordinates.
>>> Do you think you could put the coordinate array in? I have added the
>>> code to load them (see attached file).
>>>   Thanks,
>>>      Matt
>>>> Eric
>>>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland <
>>>>> Hi Matthew,
>>>>> we tried to use that.  Now, we discovered that:
>>>>> 1- even if we "ask" for sfNatural creation with DMSetUseNatural, it is
>>>>> not created because DMPlexCreateGlobalToNaturalSF looks for a "section":
>>>>> this is not documented in DMSetUseNaturalso we are asking ourselfs: "is
>>>>> this a permanent feature or a temporary situation?"
>>>> I think explaining this will help clear up a lot.
>>>> What the Natural2Global map does is permute a solution vector into the
>>>> ordering that it would have had prior to mesh distribution.
>>>> Now, in order to do this permutation, I need to know the original
>>>> (global) data layout. If it is not specified _before_ distribution, we
>>>> cannot build the permutation.  The section describes the data layout,
>>>> so I need it before distribution.
>>>> I cannot think of another way that you would implement this, but if you
>>>> want something else, let me know.
>>>>> 2- We then tried to create a "section" in different manners: we took
>>>>> the code into the example petsc/src/dm/impls/plex/tests/ex15.c.  However,
>>>>> we ended up with a segfault:
>>>>> corrupted size vs. prev_size
>>>>> [rohan:07297] *** Process received signal ***
>>>>> [rohan:07297] Signal: Aborted (6)
>>>>> [rohan:07297] Signal code:  (-6)
>>>>> [rohan:07297] [ 0] /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>>> [rohan:07297] [ 1] /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>>> [rohan:07297] [ 2] /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>>> [rohan:07297] [ 3] /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>>> [rohan:07297] [ 4] /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>>> [rohan:07297] [ 5] /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>>> [rohan:07297] [ 6] /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>>> [rohan:07297] [ 7] /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>>> [rohan:07297] [ 8]
>>>>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>>> [rohan:07297] [ 9]
>>>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>>> [rohan:07297] [10]
>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>>> [rohan:07297] [11]
>>>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>>> [rohan:07297] [12]
>>>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>>> [rohan:07297] [13] /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>>> [rohan:07297] [14]
>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>>> [rohan:07297] [15]
>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>>> [rohan:07297] [16]
>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>>> [rohan:07297] [17]
>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>>> [rohan:07297] [18]
>>>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>> I am not sure what happened here, but if you could send a sample code,
>>>> I will figure it out.
>>>>> If we do not create a section, the call to DMPlexDistribute is
>>>>> successful, but DMPlexGetGlobalToNaturalSF return a null SF pointer...
>>>> Yes, it just ignores it in this case because it does not have a global
>>>> layout.
>>>>> Here are the operations we are calling ( this is almost the code we
>>>>> are using, I just removed verifications and creation of the connectivity
>>>>> which use our parallel structure and code):
>>>>>   PetscInt* lCells      = 0;
>>>>>   PetscInt  lNumCorners = 0;
>>>>>   PetscInt  lDimMail    = 0;
>>>>>   PetscInt  lnumCells   = 0;
>>>>>   //At this point we create the cells for PETSc expected input for
>>>>> DMPlexBuildFromCellListParallel and set lNumCorners, lDimMail and lnumCells
>>>>> to correct values.
>>>>>   DM       lDMBete = 0
>>>>>   DMPlexCreate(lMPIComm,&lDMBete);
>>>>>   DMSetDimension(lDMBete, lDimMail);
>>>>>   DMPlexBuildFromCellListParallel(lDMBete,
>>>>>                                   lnumCells,
>>>>>                                   PETSC_DECIDE,
>>>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>>>>                                   lNumCorners,
>>>>>                                   lCells,
>>>>>                                   PETSC_NULL);
>>>>>   DM lDMBeteInterp = 0;
>>>>>   DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>>>   DMDestroy(&lDMBete);
>>>>>   lDMBete = lDMBeteInterp;
>>>>>   DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>>>   PetscSF lSFMigrationSansOvl = 0;
>>>>>   PetscSF lSFMigrationOvl = 0;
>>>>>   DM lDMDistribueSansOvl = 0;
>>>>>   DM lDMAvecOverlap = 0;
>>>>>   PetscPartitioner lPart;
>>>>>   DMPlexGetPartitioner(lDMBete, &lPart);
>>>>>   PetscPartitionerSetFromOptions(lPart);
>>>>>   PetscSection   section;
>>>>>   PetscInt       numFields   = 1;
>>>>>   PetscInt       numBC       = 0;
>>>>>   PetscInt       numComp[1]  = {1};
>>>>>   PetscInt       numDof[4]   = {1, 0, 0, 0};
>>>>>   PetscInt       bcFields[1] = {0};
>>>>>   IS             bcPoints[1] = {NULL};
>>>>>   DMSetNumFields(lDMBete, numFields);
>>>>>   DMPlexCreateSection(lDMBete, NULL, numComp, numDof, numBC, bcFields,
>>>>> bcPoints, NULL, NULL, &section);
>>>>>   DMSetLocalSection(lDMBete, section);
>>>>>   DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl,
>>>>> &lDMDistribueSansOvl); // segfault!
>>>>> So we have other question/remarks:
>>>>> 3- Maybe PETSc expect something specific that is missing/not verified:
>>>>> for example, we didn't gave any coordinates since we just want to partition
>>>>> and compute overlap for the mesh... and then recover our element numbers in
>>>>> a "simple way"
>>>>> 4- We are telling ourselves it is somewhat a "big price to pay" to
>>>>> have to build an unused section to have the global to natural ordering set
>>>>> ?  Could this requirement be avoided?
>>>> I don't think so. There would have to be _some_ way of describing your
>>>> data layout in terms of mesh points, and I do not see how you could use
>>>> less memory doing that.
>>>>> 5- Are there any improvement towards our usages in 3.16 release?
>>>> Let me try and run the code above.
>>>>   Thanks,
>>>>      Matt
>>>>> Thanks,
>>>>> Eric
>>>>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>> On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland <
>>>>>> Hi,
>>>>>> I come back with _almost_ the original question:
>>>>>> I would like to add an integer information (*our* original element
>>>>>> number, not petsc one) on each element of the DMPlex I create with
>>>>>> DMPlexBuildFromCellListParallel.
>>>>>> I would like this interger to be distribruted by or the same way
>>>>>> DMPlexDistribute distribute the mesh.
>>>>>> Is it possible to do this?
>>>>> I think we already have support for what you want. If you call
>>>>>   https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>> before DMPlexDistribute(), it will compute a PetscSF encoding the
>>>>> global to natural map. You
>>>>> can get it with
>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>> and use it with
>>>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>> Is this sufficient?
>>>>>   Thanks,
>>>>>      Matt
>>>>>> Thanks,
>>>>>> Eric
>>>>>> On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>>>> > Hi,
>>>>>> > I want to use DMPlexDistribute from PETSc for computing overlapping
>>>>>> > and play with the different partitioners supported.
>>>>>> > However, after calling DMPlexDistribute, I noticed the elements are
>>>>>> > renumbered and then the original number is lost.
>>>>>> > What would be the best way to keep track of the element renumbering?
>>>>>> > a) Adding an optional parameter to let the user retrieve a vector
>>>>>> or
>>>>>> > "IS" giving the old number?
>>>>>> > b) Adding a DMLabel (seems a wrong good solution)
>>>>>> > c) Other idea?
>>>>>> > Of course, I don't want to loose performances with the need of this
>>>>>> > "mapping"...
>>>>>> > Thanks,
>>>>>> > Eric
>>>>>> Eric Chamberland, ing., M. Ing
>>>>>> Professionnel de recherche
>>>>>> GIREF/Université Laval
>>>>>> (418) 656-2131 poste 41 22 42
>>>>> What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
>>>>> <http://www.cse.buffalo.edu/~knepley/>
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/169710f6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/169710f6/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211027/169710f6/attachment-0003.png>
