[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Matthew Knepley
knepley at gmail.com
Tue Oct 26 08:46:30 CDT 2021
Okay, I ran it. Something seems off with the mesh. First, I cannot simply
explain the partition. The number of shared vertices and edges
does not seem to come from a straight cut. Second, the mesh look scrambled
on output.
Matt
On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland <
Eric.Chamberland at giref.ulaval.ca> wrote:
> Hi Matthew,
> ok, I started back from your ex44.c example and added the global array of
> coordinates. I just have to code the creation of the local coordinates now.
> Eric
> On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland <
>> Hi Matthew,
>> we tried to reproduce the error in a simple example.
>> The context is the following: We hard coded the mesh and initial
>> partition into the code (see sConnectivity and sInitialPartition) for 2
>> ranks and try to create a section in order to use the
>> DMPlexNaturalToGlobalBegin function to retreive our initial element numbers.
>> Now the call to DMPlexDistribute give different errors depending on what
>> type of component we ask the field to be created. For our objective, we
>> would like a global field to be created on elements only (like a P0
>> interpolation).
>> We now have the following error generated:
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Petsc has generated inconsistent data
>> [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>> [0]PETSC ERROR: See https://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>> [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct 20 14:52:36 2021
>> [0]PETSC ERROR: Configure options
>> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7 --with-mpi-compilers=1
>> --with-mpi-dir=/opt/openmpi-4.1.0_gcc7 --with-cxx-dialect=C++14
>> --with-make-np=12 --with-shared-libraries=1 --with-debugging=yes
>> --with-memalign=64 --with-visibility=0 --with-64-bit-indices=0
>> --download-ml=yes --download-mumps=yes --download-superlu=yes
>> --download-hpddm=yes --download-slepc=yes --download-superlu_dist=yes
>> --download-parmetis=yes --download-ptscotch=yes --download-metis=yes
>> --download-strumpack=yes --download-suitesparse=yes --download-hypre=yes
>> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>> --with-scalapack=1
>> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>> [0]PETSC ERROR: #3 DMPlexDistribute() at
>> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>> [0]PETSC ERROR: #4 main() at bug_section.cc:159
>> [0]PETSC ERROR: No PETSc Option Table entries
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> Hope the attached code is self-explaining, note that to make it short, we
>> have not included the final part of it, just the buggy part we are
>> encountering right now...
>> Thanks for your insights,
> Thanks for making the example. I tweaked it slightly. I put in a test case
> that just makes a parallel 7 x 10 quad mesh. This works
> fine. Thus I think it must be something connected with the original mesh.
> It is hard to get a handle on it without the coordinates.
> Do you think you could put the coordinate array in? I have added the code
> to load them (see attached file).
> Thanks,
> Matt
>> Eric
>> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland <
>>> Hi Matthew,
>>> we tried to use that. Now, we discovered that:
>>> 1- even if we "ask" for sfNatural creation with DMSetUseNatural, it is
>>> not created because DMPlexCreateGlobalToNaturalSF looks for a "section":
>>> this is not documented in DMSetUseNaturalso we are asking ourselfs: "is
>>> this a permanent feature or a temporary situation?"
>> I think explaining this will help clear up a lot.
>> What the Natural2Global map does is permute a solution vector into the
>> ordering that it would have had prior to mesh distribution.
>> Now, in order to do this permutation, I need to know the original
>> (global) data layout. If it is not specified _before_ distribution, we
>> cannot build the permutation. The section describes the data layout, so
>> I need it before distribution.
>> I cannot think of another way that you would implement this, but if you
>> want something else, let me know.
>>> 2- We then tried to create a "section" in different manners: we took the
>>> code into the example petsc/src/dm/impls/plex/tests/ex15.c. However, we
>>> ended up with a segfault:
>>> corrupted size vs. prev_size
>>> [rohan:07297] *** Process received signal ***
>>> [rohan:07297] Signal: Aborted (6)
>>> [rohan:07297] Signal code: (-6)
>>> [rohan:07297] [ 0] /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>> [rohan:07297] [ 1] /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>> [rohan:07297] [ 2] /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>> [rohan:07297] [ 3] /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>> [rohan:07297] [ 4] /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>> [rohan:07297] [ 5] /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>> [rohan:07297] [ 6] /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>> [rohan:07297] [ 7] /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>> [rohan:07297] [ 8] /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>> [rohan:07297] [ 9]
>>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>> [rohan:07297] [10]
>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>> [rohan:07297] [11]
>>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>> [rohan:07297] [12]
>>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>> [rohan:07297] [13] /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>> [rohan:07297] [14]
>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>> [rohan:07297] [15]
>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>> [rohan:07297] [16]
>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>> [rohan:07297] [17]
>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>> [rohan:07297] [18]
>>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>> I am not sure what happened here, but if you could send a sample code, I
>> will figure it out.
>>> If we do not create a section, the call to DMPlexDistribute is
>>> successful, but DMPlexGetGlobalToNaturalSF return a null SF pointer...
>> Yes, it just ignores it in this case because it does not have a global
>> layout.
>>> Here are the operations we are calling ( this is almost the code we are
>>> using, I just removed verifications and creation of the connectivity which
>>> use our parallel structure and code):
>>> PetscInt* lCells = 0;
>>> PetscInt lNumCorners = 0;
>>> PetscInt lDimMail = 0;
>>> PetscInt lnumCells = 0;
>>> //At this point we create the cells for PETSc expected input for
>>> DMPlexBuildFromCellListParallel and set lNumCorners, lDimMail and lnumCells
>>> to correct values.
>>> DM lDMBete = 0
>>> DMPlexCreate(lMPIComm,&lDMBete);
>>> DMSetDimension(lDMBete, lDimMail);
>>> DMPlexBuildFromCellListParallel(lDMBete,
>>> lnumCells,
>>> PETSC_DECIDE,
>>> pLectureElementsLocaux.reqNbTotalSommets(),
>>> lNumCorners,
>>> lCells,
>>> PETSC_NULL);
>>> DM lDMBeteInterp = 0;
>>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>> DMDestroy(&lDMBete);
>>> lDMBete = lDMBeteInterp;
>>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>>> PetscSF lSFMigrationSansOvl = 0;
>>> PetscSF lSFMigrationOvl = 0;
>>> DM lDMDistribueSansOvl = 0;
>>> DM lDMAvecOverlap = 0;
>>> PetscPartitioner lPart;
>>> DMPlexGetPartitioner(lDMBete, &lPart);
>>> PetscPartitionerSetFromOptions(lPart);
>>> PetscSection section;
>>> PetscInt numFields = 1;
>>> PetscInt numBC = 0;
>>> PetscInt numComp[1] = {1};
>>> PetscInt numDof[4] = {1, 0, 0, 0};
>>> PetscInt bcFields[1] = {0};
>>> IS bcPoints[1] = {NULL};
>>> DMSetNumFields(lDMBete, numFields);
>>> DMPlexCreateSection(lDMBete, NULL, numComp, numDof, numBC, bcFields,
>>> bcPoints, NULL, NULL, §ion);
>>> DMSetLocalSection(lDMBete, section);
>>> DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl,
>>> &lDMDistribueSansOvl); // segfault!
>>> So we have other question/remarks:
>>> 3- Maybe PETSc expect something specific that is missing/not verified:
>>> for example, we didn't gave any coordinates since we just want to partition
>>> and compute overlap for the mesh... and then recover our element numbers in
>>> a "simple way"
>>> 4- We are telling ourselves it is somewhat a "big price to pay" to have
>>> to build an unused section to have the global to natural ordering set ?
>>> Could this requirement be avoided?
>> I don't think so. There would have to be _some_ way of describing your
>> data layout in terms of mesh points, and I do not see how you could use
>> less memory doing that.
>>> 5- Are there any improvement towards our usages in 3.16 release?
>> Let me try and run the code above.
>> Thanks,
>> Matt
>>> Thanks,
>>> Eric
>>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>> On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland <
>>>> Hi,
>>>> I come back with _almost_ the original question:
>>>> I would like to add an integer information (*our* original element
>>>> number, not petsc one) on each element of the DMPlex I create with
>>>> DMPlexBuildFromCellListParallel.
>>>> I would like this interger to be distribruted by or the same way
>>>> DMPlexDistribute distribute the mesh.
>>>> Is it possible to do this?
>>> I think we already have support for what you want. If you call
>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>> before DMPlexDistribute(), it will compute a PetscSF encoding the global
>>> to natural map. You
>>> can get it with
>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>> and use it with
>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>> Is this sufficient?
>>> Thanks,
>>> Matt
>>>> Thanks,
>>>> Eric
>>>> On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>> > Hi,
>>>> > I want to use DMPlexDistribute from PETSc for computing overlapping
>>>> > and play with the different partitioners supported.
>>>> > However, after calling DMPlexDistribute, I noticed the elements are
>>>> > renumbered and then the original number is lost.
>>>> > What would be the best way to keep track of the element renumbering?
>>>> > a) Adding an optional parameter to let the user retrieve a vector or
>>>> > "IS" giving the old number?
>>>> > b) Adding a DMLabel (seems a wrong good solution)
>>>> > c) Other idea?
>>>> > Of course, I don't want to loose performances with the need of this
>>>> > "mapping"...
>>>> > Thanks,
>>>> > Eric
>>>> Eric Chamberland, ing., M. Ing
>>>> Professionnel de recherche
>>>> GIREF/Université Laval
>>>> (418) 656-2131 poste 41 22 42
>>> What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211026/cc7a9de6/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211026/cc7a9de6/attachment-0001.png>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211026/cc7a9de6/attachment-0001.obj>
