[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Tue Oct 26 12:35:01 CDT 2021
Here is a screenshot of the partition I hard coded (top) and
vertices/element numbers (down):
I have not yet modified the ex44.c example to properly assign the
coordinates...
(but I would not have done it like it is in the last version because the
sCoords array is the global array with global vertices number)
I will have time to do this tomorrow...
Maybe I can first try to reproduce all this with a smaller mesh?
Eric
On 2021-10-26 9:46 a.m., Matthew Knepley wrote:
> Okay, I ran it. Something seems off with the mesh. First, I cannot
> simply explain the partition. The number of shared vertices and edges
> does not seem to come from a straight cut. Second, the mesh look
> scrambled on output.
>   Thanks,
>     Matt
> On Sun, Oct 24, 2021 at 11:49 PM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
>     Hi Matthew,
>     ok, I started back from your ex44.c example and added the global
>     array of coordinates.  I just have to code the creation of the
>     local coordinates now.
>     Eric
>     On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
>>     On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland
>>         Hi Matthew,
>>         we tried to reproduce the error in a simple example.
>>         The context is the following: We hard coded the mesh and
>>         initial partition into the code (see sConnectivity and
>>         sInitialPartition) for 2 ranks and try to create a section in
>>         order to use the DMPlexNaturalToGlobalBegin function to
>>         retreive our initial element numbers.
>>         Now the call to DMPlexDistribute give different errors
>>         depending on what type of component we ask the field to be
>>         created.  For our objective, we would like a global field to
>>         be created on elements only (like a P0 interpolation).
>>         We now have the following error generated:
>>         [0]PETSC ERROR: --------------------- Error Message
>>         [0]PETSC ERROR: Petsc has generated inconsistent data
>>         [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
>>         [0]PETSC ERROR: See
>>         https://www.mcs.anl.gov/petsc/documentation/faq.html
>>         <https://www.mcs.anl.gov/petsc/documentation/faq.html> for
>>         trouble shooting.
>>         [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
>>         [0]PETSC ERROR: ./bug on a  named rohan by ericc Wed Oct 20
>>         14:52:36 2021
>>         [0]PETSC ERROR: Configure options
>>         --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
>>         --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
>>         --with-cxx-dialect=C++14 --with-make-np=12
>>         --with-shared-libraries=1 --with-debugging=yes
>>         --with-memalign=64 --with-visibility=0
>>         --with-64-bit-indices=0 --download-ml=yes
>>         --download-mumps=yes --download-superlu=yes
>>         --download-hpddm=yes --download-slepc=yes
>>         --download-superlu_dist=yes --download-parmetis=yes
>>         --download-ptscotch=yes --download-metis=yes
>>         --download-strumpack=yes --download-suitesparse=yes
>>         --download-hypre=yes
>>         --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>         --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>         --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
>>         --with-scalapack=1
>>         --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
>>         --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
>>         -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
>>         [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
>>         /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
>>         [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
>>         /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
>>         [0]PETSC ERROR: #3 DMPlexDistribute() at
>>         /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
>>         [0]PETSC ERROR: #4 main() at bug_section.cc:159
>>         [0]PETSC ERROR: No PETSc Option Table entries
>>         [0]PETSC ERROR: ----------------End of Error Message
>>         -------send entire error message to petsc-maint at mcs.anl.gov
>>         <mailto:petsc-maint at mcs.anl.gov>----------
>>         Hope the attached code is self-explaining, note that to make
>>         it short, we have not included the final part of it, just the
>>         buggy part we are encountering right now...
>>         Thanks for your insights,
>>     Thanks for making the example. I tweaked it slightly. I put in a
>>     test case that just makes a parallel 7 x 10 quad mesh. This works
>>     fine. Thus I think it must be something connected with the
>>     original mesh. It is hard to get a handle on it without the
>>     coordinates.
>>     Do you think you could put the coordinate array in? I have added
>>     the code to load them (see attached file).
>>       Thanks,
>>          Matt
>>         Eric
>>         On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>>>         On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland
>>>             Hi Matthew,
>>>             we tried to use that.  Now, we discovered that:
>>>             1- even if we "ask" for sfNatural creation with
>>>             DMSetUseNatural, it is not created because
>>>             DMPlexCreateGlobalToNaturalSF looks for a "section":
>>>             this is not documented in DMSetUseNaturalso we are
>>>             asking ourselfs: "is this a permanent feature or a
>>>             temporary situation?"
>>>         I think explaining this will help clear up a lot.
>>>         What the Natural2Global map does is permute a solution
>>>         vector into the ordering that it would have had prior to
>>>         mesh distribution.
>>>         Now, in order to do this permutation, I need to know the
>>>         original (global) data layout. If it is not specified
>>>         _before_ distribution, we
>>>         cannot build the permutation.  The section describes the
>>>         data layout, so I need it before distribution.
>>>         I cannot think of another way that you would implement this,
>>>         but if you want something else, let me know.
>>>             2- We then tried to create a "section" in different
>>>             manners: we took the code into the example
>>>             petsc/src/dm/impls/plex/tests/ex15.c. However, we ended
>>>             up with a segfault:
>>>             corrupted size vs. prev_size
>>>             [rohan:07297] *** Process received signal ***
>>>             [rohan:07297] Signal: Aborted (6)
>>>             [rohan:07297] Signal code:  (-6)
>>>             [rohan:07297] [ 0]
>>>             /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>>>             [rohan:07297] [ 1]
>>>             /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>>>             [rohan:07297] [ 2]
>>>             /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>>>             [rohan:07297] [ 3]
>>>             /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>>>             [rohan:07297] [ 4]
>>>             /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>>>             [rohan:07297] [ 5]
>>>             /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>>>             [rohan:07297] [ 6]
>>>             /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>>>             [rohan:07297] [ 7]
>>>             /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>>>             [rohan:07297] [ 8]
>>>             /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>>>             [rohan:07297] [ 9]
>>>             /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>>>             [rohan:07297] [10]
>>>             /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>>>             [rohan:07297] [11]
>>>             /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>>>             [rohan:07297] [12]
>>>             /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>>>             [rohan:07297] [13]
>>>             /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>>>             [rohan:07297] [14]
>>>             /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>>>             [rohan:07297] [15]
>>>             /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>>>             [rohan:07297] [16]
>>>             /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>>>             [rohan:07297] [17]
>>>             /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>>>             [rohan:07297] [18]
>>>             /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>>>         I am not sure what happened here, but if you could send a
>>>         sample code, I will figure it out.
>>>             If we do not create a section, the call to
>>>             DMPlexDistribute is successful, but
>>>             DMPlexGetGlobalToNaturalSF return a null SF pointer...
>>>         Yes, it just ignores it in this case because it does not
>>>         have a global layout.
>>>             Here are the operations we are calling ( this is almost
>>>             the code we are using, I just removed verifications and
>>>             creation of the connectivity which use our parallel
>>>             structure and code):
>>>               PetscInt* lCells      = 0;
>>>               PetscInt  lNumCorners = 0;
>>>               PetscInt  lDimMail    = 0;
>>>               PetscInt  lnumCells   = 0;
>>>               //At this point we create the cells for PETSc expected
>>>             input for DMPlexBuildFromCellListParallel and set
>>>             lNumCorners, lDimMail and lnumCells to correct values.
>>>               DM       lDMBete = 0
>>>               DMPlexCreate(lMPIComm,&lDMBete);
>>>               DMSetDimension(lDMBete, lDimMail);
>>>             DMPlexBuildFromCellListParallel(lDMBete,
>>>             lnumCells,
>>>             PETSC_DECIDE,
>>>             pLectureElementsLocaux.reqNbTotalSommets(),
>>>             lNumCorners,
>>>             lCells,
>>>             PETSC_NULL);
>>>               DM lDMBeteInterp = 0;
>>>               DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>>>               DMDestroy(&lDMBete);
>>>               lDMBete = lDMBeteInterp;
>>>               DMSetUseNatural(lDMBete,PETSC_TRUE);
>>>               PetscSF lSFMigrationSansOvl = 0;
>>>               PetscSF lSFMigrationOvl = 0;
>>>               DM lDMDistribueSansOvl = 0;
>>>               DM lDMAvecOverlap = 0;
>>>               PetscPartitioner lPart;
>>>               DMPlexGetPartitioner(lDMBete, &lPart);
>>>             PetscPartitionerSetFromOptions(lPart);
>>>               PetscSection   section;
>>>               PetscInt       numFields   = 1;
>>>               PetscInt       numBC       = 0;
>>>               PetscInt       numComp[1]  = {1};
>>>               PetscInt       numDof[4]   = {1, 0, 0, 0};
>>>               PetscInt       bcFields[1] = {0};
>>>               IS             bcPoints[1] = {NULL};
>>>               DMSetNumFields(lDMBete, numFields);
>>>               DMPlexCreateSection(lDMBete, NULL, numComp, numDof,
>>>             numBC, bcFields, bcPoints, NULL, NULL, &section);
>>>               DMSetLocalSection(lDMBete, section);
>>>               DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl,
>>>             &lDMDistribueSansOvl); // segfault!
>>>             So we have other question/remarks:
>>>             3- Maybe PETSc expect something specific that is
>>>             missing/not verified: for example, we didn't gave any
>>>             coordinates since we just want to partition and compute
>>>             overlap for the mesh... and then recover our element
>>>             numbers in a "simple way"
>>>             4- We are telling ourselves it is somewhat a "big price
>>>             to pay" to have to build an unused section to have the
>>>             global to natural ordering set ? Could this requirement
>>>             be avoided?
>>>         I don't think so. There would have to be _some_ way of
>>>         describing your data layout in terms of mesh points, and I
>>>         do not see how you could use less memory doing that.
>>>             5- Are there any improvement towards our usages in 3.16
>>>             release?
>>>         Let me try and run the code above.
>>>           Thanks,
>>>              Matt
>>>             Thanks,
>>>             Eric
>>>             On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>>>             On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland
>>>>                 Hi,
>>>>                 I come back with _almost_ the original question:
>>>>                 I would like to add an integer information (*our*
>>>>                 original element
>>>>                 number, not petsc one) on each element of the
>>>>                 DMPlex I create with
>>>>                 DMPlexBuildFromCellListParallel.
>>>>                 I would like this interger to be distribruted by or
>>>>                 the same way
>>>>                 DMPlexDistribute distribute the mesh.
>>>>                 Is it possible to do this?
>>>>             I think we already have support for what you want. If
>>>>             you call
>>>>             https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>>>             <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>>>             before DMPlexDistribute(), it will compute a PetscSF
>>>>             encoding the global to natural map. You
>>>>             can get it with
>>>>             https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>>>             <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>>>             and use it with
>>>>             https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>>>             <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>>>             Is this sufficient?
>>>>               Thanks,
>>>>                  Matt
>>>>                 Thanks,
>>>>                 Eric
>>>>                 On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>>>                 > Hi,
>>>>                 > I want to use DMPlexDistribute from PETSc for
>>>>                 computing overlapping
>>>>                 > and play with the different partitioners supported.
>>>>                 > However, after calling DMPlexDistribute, I
>>>>                 noticed the elements are
>>>>                 > renumbered and then the original number is lost.
>>>>                 > What would be the best way to keep track of the
>>>>                 element renumbering?
>>>>                 > a) Adding an optional parameter to let the user
>>>>                 retrieve a vector or
>>>>                 > "IS" giving the old number?
>>>>                 > b) Adding a DMLabel (seems a wrong good solution)
>>>>                 > c) Other idea?
>>>>                 > Of course, I don't want to loose performances
>>>>                 with the need of this
>>>>                 > "mapping"...
>>>>                 > Thanks,
>>>>                 > Eric
>>>>                 Eric Chamberland, ing., M. Ing
>>>>                 Professionnel de recherche
>>>>                 GIREF/Université Laval
>>>>                 (418) 656-2131 poste 41 22 42
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>>             https://www.cse.buffalo.edu/~knepley/
>>>>             <http://www.cse.buffalo.edu/~knepley/>
>>>         What most experimenters take for granted before they begin
>>>         their experiments is infinitely more interesting than any
>>>         -- Norbert Wiener
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211026/cfb4bccf/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211026/cfb4bccf/attachment-0001.png>
