[petsc-users] Is it possible to keep track of original elements # after a call to DMPlexDistribute ?
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Sun Oct 24 22:49:38 CDT 2021
Hi Matthew,
ok, I started back from your ex44.c example and added the global array
of coordinates. I just have to code the creation of the local
coordinates now.
Eric
On 2021-10-20 6:55 p.m., Matthew Knepley wrote:
> On Wed, Oct 20, 2021 at 3:06 PM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca
> <mailto:Eric.Chamberland at giref.ulaval.ca>> wrote:
> Hi Matthew,
> we tried to reproduce the error in a simple example.
> The context is the following: We hard coded the mesh and initial
> partition into the code (see sConnectivity and sInitialPartition)
> for 2 ranks and try to create a section in order to use the
> DMPlexNaturalToGlobalBegin function to retreive our initial
> element numbers.
> Now the call to DMPlexDistribute give different errors depending
> on what type of component we ask the field to be created. For our
> objective, we would like a global field to be created on elements
> only (like a P0 interpolation).
> We now have the following error generated:
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: Inconsistency in indices, 18 should be 17
> [0]PETSC ERROR: See
> https://www.mcs.anl.gov/petsc/documentation/faq.html
> <https://www.mcs.anl.gov/petsc/documentation/faq.html> for trouble
> shooting.
> [0]PETSC ERROR: Petsc Release Version 3.15.0, Mar 30, 2021
> [0]PETSC ERROR: ./bug on a named rohan by ericc Wed Oct 20
> 14:52:36 2021
> [0]PETSC ERROR: Configure options
> --prefix=/opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7
> --with-mpi-compilers=1 --with-mpi-dir=/opt/openmpi-4.1.0_gcc7
> --with-cxx-dialect=C++14 --with-make-np=12
> --with-shared-libraries=1 --with-debugging=yes --with-memalign=64
> --with-visibility=0 --with-64-bit-indices=0 --download-ml=yes
> --download-mumps=yes --download-superlu=yes --download-hpddm=yes
> --download-slepc=yes --download-superlu_dist=yes
> --download-parmetis=yes --download-ptscotch=yes
> --download-metis=yes --download-strumpack=yes
> --download-suitesparse=yes --download-hypre=yes
> --with-blaslapack-dir=/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
> --with-mkl_pardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
> --with-mkl_cpardiso-dir=/opt/intel/oneapi/mkl/2021.1.1/env/..
> --with-scalapack=1
> --with-scalapack-include=/opt/intel/oneapi/mkl/2021.1.1/env/../include
> --with-scalapack-lib="-L/opt/intel/oneapi/mkl/2021.1.1/env/../lib/intel64
> -lmkl_scalapack_lp64 -lmkl_blacs_openmpi_lp64"
> [0]PETSC ERROR: #1 PetscSFCreateSectionSF() at
> /tmp/ompi-opt/petsc-3.15.0-debug/src/vec/is/sf/utils/sfutils.c:409
> [0]PETSC ERROR: #2 DMPlexCreateGlobalToNaturalSF() at
> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexnatural.c:184
> [0]PETSC ERROR: #3 DMPlexDistribute() at
> /tmp/ompi-opt/petsc-3.15.0-debug/src/dm/impls/plex/plexdistribute.c:1733
> [0]PETSC ERROR: #4 main() at bug_section.cc:159
> [0]PETSC ERROR: No PETSc Option Table entries
> [0]PETSC ERROR: ----------------End of Error Message -------send
> entire error message to petsc-maint at mcs.anl.gov
> <mailto:petsc-maint at mcs.anl.gov>----------
> Hope the attached code is self-explaining, note that to make it
> short, we have not included the final part of it, just the buggy
> part we are encountering right now...
> Thanks for your insights,
> Thanks for making the example. I tweaked it slightly. I put in a test
> case that just makes a parallel 7 x 10 quad mesh. This works
> fine. Thus I think it must be something connected with the original
> mesh. It is hard to get a handle on it without the coordinates.
> Do you think you could put the coordinate array in? I have added the
> code to load them (see attached file).
> Thanks,
> Matt
> Eric
> On 2021-10-06 9:23 p.m., Matthew Knepley wrote:
>> On Wed, Oct 6, 2021 at 5:43 PM Eric Chamberland
>> Hi Matthew,
>> we tried to use that. Now, we discovered that:
>> 1- even if we "ask" for sfNatural creation with
>> DMSetUseNatural, it is not created because
>> DMPlexCreateGlobalToNaturalSF looks for a "section": this is
>> not documented in DMSetUseNaturalso we are asking ourselfs:
>> "is this a permanent feature or a temporary situation?"
>> I think explaining this will help clear up a lot.
>> What the Natural2Global map does is permute a solution vector
>> into the ordering that it would have had prior to mesh distribution.
>> Now, in order to do this permutation, I need to know the original
>> (global) data layout. If it is not specified _before_
>> distribution, we
>> cannot build the permutation. The section describes the data
>> layout, so I need it before distribution.
>> I cannot think of another way that you would implement this, but
>> if you want something else, let me know.
>> 2- We then tried to create a "section" in different manners:
>> we took the code into the example
>> petsc/src/dm/impls/plex/tests/ex15.c. However, we ended up
>> with a segfault:
>> corrupted size vs. prev_size
>> [rohan:07297] *** Process received signal ***
>> [rohan:07297] Signal: Aborted (6)
>> [rohan:07297] Signal code: (-6)
>> [rohan:07297] [ 0]
>> /lib64/libpthread.so.0(+0x13f80)[0x7f6f13be3f80]
>> [rohan:07297] [ 1]
>> /lib64/libc.so.6(gsignal+0x10b)[0x7f6f109b718b]
>> [rohan:07297] [ 2] /lib64/libc.so.6(abort+0x175)[0x7f6f109b8585]
>> [rohan:07297] [ 3] /lib64/libc.so.6(+0x7e2f7)[0x7f6f109fb2f7]
>> [rohan:07297] [ 4] /lib64/libc.so.6(+0x857ea)[0x7f6f10a027ea]
>> [rohan:07297] [ 5] /lib64/libc.so.6(+0x86036)[0x7f6f10a03036]
>> [rohan:07297] [ 6] /lib64/libc.so.6(+0x861a3)[0x7f6f10a031a3]
>> [rohan:07297] [ 7] /lib64/libc.so.6(+0x88740)[0x7f6f10a05740]
>> [rohan:07297] [ 8]
>> /lib64/libc.so.6(__libc_malloc+0x1b8)[0x7f6f10a070c8]
>> [rohan:07297] [ 9]
>> /lib64/libc.so.6(__backtrace_symbols+0x134)[0x7f6f10a8b064]
>> [rohan:07297] [10]
>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z12reqBacktraceRNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE+0x4e)[0x4538ce]
>> [rohan:07297] [11]
>> /home/mefpp_ericc/GIREF/bin/MEF++.dev(_Z15attacheDebuggerv+0x120)[0x4523c0]
>> [rohan:07297] [12]
>> /home/mefpp_ericc/GIREF/lib/libgiref_dev_Util.so(traitementSignal+0x612)[0x7f6f28f503a2]
>> [rohan:07297] [13] /lib64/libc.so.6(+0x3a210)[0x7f6f109b7210]
>> [rohan:07297] [14]
>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscTrMallocDefault+0x6fd)[0x7f6f22f1b8ed]
>> [rohan:07297] [15]
>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscMallocA+0x5cd)[0x7f6f22f19c2d]
>> [rohan:07297] [16]
>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(PetscSFCreateSectionSF+0xb48)[0x7f6f23268e18]
>> [rohan:07297] [17]
>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexCreateGlobalToNaturalSF+0x13b2)[0x7f6f241a5602]
>> [rohan:07297] [18]
>> /opt/petsc-3.15.0_debug_openmpi-4.1.0_gcc7/lib/libpetsc.so.3.15(DMPlexDistribute+0x39b1)[0x7f6f23fdca21]
>> I am not sure what happened here, but if you could send a sample
>> code, I will figure it out.
>> If we do not create a section, the call to DMPlexDistribute
>> is successful, but DMPlexGetGlobalToNaturalSF return a null
>> SF pointer...
>> Yes, it just ignores it in this case because it does not have a
>> global layout.
>> Here are the operations we are calling ( this is almost the
>> code we are using, I just removed verifications and creation
>> of the connectivity which use our parallel structure and code):
>> PetscInt* lCells = 0;
>> PetscInt lNumCorners = 0;
>> PetscInt lDimMail = 0;
>> PetscInt lnumCells = 0;
>> //At this point we create the cells for PETSc expected
>> input for DMPlexBuildFromCellListParallel and set
>> lNumCorners, lDimMail and lnumCells to correct values.
>> DM lDMBete = 0
>> DMPlexCreate(lMPIComm,&lDMBete);
>> DMSetDimension(lDMBete, lDimMail);
>> DMPlexBuildFromCellListParallel(lDMBete,
>> lnumCells,
>> PETSC_DECIDE,
>> pLectureElementsLocaux.reqNbTotalSommets(),
>> lNumCorners,
>> lCells,
>> PETSC_NULL);
>> DM lDMBeteInterp = 0;
>> DMPlexInterpolate(lDMBete, &lDMBeteInterp);
>> DMDestroy(&lDMBete);
>> lDMBete = lDMBeteInterp;
>> DMSetUseNatural(lDMBete,PETSC_TRUE);
>> PetscSF lSFMigrationSansOvl = 0;
>> PetscSF lSFMigrationOvl = 0;
>> DM lDMDistribueSansOvl = 0;
>> DM lDMAvecOverlap = 0;
>> PetscPartitioner lPart;
>> DMPlexGetPartitioner(lDMBete, &lPart);
>> PetscPartitionerSetFromOptions(lPart);
>> PetscSection section;
>> PetscInt numFields = 1;
>> PetscInt numBC = 0;
>> PetscInt numComp[1] = {1};
>> PetscInt numDof[4] = {1, 0, 0, 0};
>> PetscInt bcFields[1] = {0};
>> IS bcPoints[1] = {NULL};
>> DMSetNumFields(lDMBete, numFields);
>> DMPlexCreateSection(lDMBete, NULL, numComp, numDof, numBC,
>> bcFields, bcPoints, NULL, NULL, §ion);
>> DMSetLocalSection(lDMBete, section);
>> DMPlexDistribute(lDMBete, 0, &lSFMigrationSansOvl,
>> &lDMDistribueSansOvl); // segfault!
>> So we have other question/remarks:
>> 3- Maybe PETSc expect something specific that is missing/not
>> verified: for example, we didn't gave any coordinates since
>> we just want to partition and compute overlap for the mesh...
>> and then recover our element numbers in a "simple way"
>> 4- We are telling ourselves it is somewhat a "big price to
>> pay" to have to build an unused section to have the global to
>> natural ordering set ? Could this requirement be avoided?
>> I don't think so. There would have to be _some_ way of describing
>> your data layout in terms of mesh points, and I do not see how
>> you could use less memory doing that.
>> 5- Are there any improvement towards our usages in 3.16 release?
>> Let me try and run the code above.
>> Thanks,
>> Matt
>> Thanks,
>> Eric
>> On 2021-09-29 7:39 p.m., Matthew Knepley wrote:
>>> On Wed, Sep 29, 2021 at 5:18 PM Eric Chamberland
>>> Hi,
>>> I come back with _almost_ the original question:
>>> I would like to add an integer information (*our*
>>> original element
>>> number, not petsc one) on each element of the DMPlex I
>>> create with
>>> DMPlexBuildFromCellListParallel.
>>> I would like this interger to be distribruted by or the
>>> same way
>>> DMPlexDistribute distribute the mesh.
>>> Is it possible to do this?
>>> I think we already have support for what you want. If you call
>>> https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html
>>> <https://petsc.org/main/docs/manualpages/DM/DMSetUseNatural.html>
>>> before DMPlexDistribute(), it will compute a PetscSF
>>> encoding the global to natural map. You
>>> can get it with
>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html
>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGetGlobalToNaturalSF.html>
>>> and use it with
>>> https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html
>>> <https://petsc.org/main/docs/manualpages/DMPLEX/DMPlexGlobalToNaturalBegin.html>
>>> Is this sufficient?
>>> Thanks,
>>> Matt
>>> Thanks,
>>> Eric
>>> On 2021-07-14 1:18 p.m., Eric Chamberland wrote:
>>> > Hi,
>>> > I want to use DMPlexDistribute from PETSc for
>>> computing overlapping
>>> > and play with the different partitioners supported.
>>> > However, after calling DMPlexDistribute, I noticed the
>>> elements are
>>> > renumbered and then the original number is lost.
>>> > What would be the best way to keep track of the
>>> element renumbering?
>>> > a) Adding an optional parameter to let the user
>>> retrieve a vector or
>>> > "IS" giving the old number?
>>> > b) Adding a DMLabel (seems a wrong good solution)
>>> > c) Other idea?
>>> > Of course, I don't want to loose performances with the
>>> need of this
>>> > "mapping"...
>>> > Thanks,
>>> > Eric
>>> Eric Chamberland, ing., M. Ing
>>> Professionnel de recherche
>>> GIREF/Université Laval
>>> (418) 656-2131 poste 41 22 42
>>> What most experimenters take for granted before they begin
>>> their experiments is infinitely more interesting than any
>>> results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/
>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments is infinitely more interesting than any results to
>> -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211024/64ee73c5/attachment-0001.html>
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211024/64ee73c5/attachment-0001.bin>
