[petsc-users] HDF5 timestepping in PETSc 3.16
Adrian Croucher
a.croucher at auckland.ac.nz
Mon Oct 18 21:35:08 CDT 2021
Any response on this?
This is a bit of a showstopper for me - I can't upgrade to PETSc 3.16 if
it does not allow my users to read their HDF5 files created using
earlier versions of PETSc.
So far I can't see a workaround. Possibly the timestepping functions
need some kind of optional parameter to specify what the default
timestepping attribute should be, if it's not present in the file
(rather than just assuming it's false)?
Regards, Adrian
On 10/14/21 4:19 PM, Adrian Croucher wrote:
> hi
> I am just testing out PETSc 3.16 and making the necessary changes to
> my code. Amongst other things I now have to add a
> PetscViewerHDF5PushTimestepping() call before starting to output
> time-dependent results to HDF5 using a PetscViewer.
> I now also have to add this call before reading in sets of previously
> computed time-dependent results (for restarting a simulation from the
> results of a previous run).
> The problem with this is that if I try to read in the results of any
> previous run, computed with an earlier version of PETSc (< 3.16), an
> error is raised because the time-dependent datasets in the file do not
> have the 'timestepping' attribute.
> Is there something else I need to do to make this work?
> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
