[petsc-users] HDF5 timestepping in PETSc 3.16
Tue Oct 19 05:12:22 CDT 2021
On Mon, Oct 18, 2021 at 10:35 PM Adrian Croucher <a.croucher at auckland.ac.nz>
wrote:
> Any response on this?
> This is a bit of a showstopper for me - I can't upgrade to PETSc 3.16 if
> it does not allow my users to read their HDF5 files created using
> earlier versions of PETSc.
> So far I can't see a workaround. Possibly the timestepping functions
> need some kind of optional parameter to specify what the default
> timestepping attribute should be, if it's not present in the file
> (rather than just assuming it's false)?
I will fix it. I think I can do it tomorrow. Class just started this week
do it is hectic :)
I think you are right. We should always write the attribute, but have it be
false. We should
interpret a missing attribute as an old file.
     Matt
> Regards, Adrian
> On 10/14/21 4:19 PM, Adrian Croucher wrote:
> > hi
> > I am just testing out PETSc 3.16 and making the necessary changes to
> > my code. Amongst other things I now have to add a
> > PetscViewerHDF5PushTimestepping() call before starting to output
> > time-dependent results to HDF5 using a PetscViewer.
> > I now also have to add this call before reading in sets of previously
> > computed time-dependent results (for restarting a simulation from the
> > results of a previous run).
> > The problem with this is that if I try to read in the results of any
> > previous run, computed with an earlier version of PETSc (< 3.16), an
> > error is raised because the time-dependent datasets in the file do not
> > have the 'timestepping' attribute.
> > Is there something else I need to do to make this work?
> > - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211019/1c71c7da/attachment-0001.html>
