[petsc-users] MatVec on GPUs
Swarnava Ghosh
swarnava89 at gmail.com
Sun Oct 17 19:09:58 CDT 2021
Thanks Matt and Junchao.
Sincerely,
Swarnava
On Sun, Oct 17, 2021 at 7:50 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Sun, Oct 17, 2021 at 7:12 PM Swarnava Ghosh <swarnava89 at gmail.com>
> wrote:
>> Do I need convert the MATSEQBAIJ to a cuda matrix in code?
> You would need a call to MatSetFromOptions() to take that type from the
> command line, and not have
> the type hard-coded in your application. It is generally a bad idea to
> hard code the implementation type.
>> If I do it from command line, then are the other MatVec calls are ported
>> onto CUDA? I have many MatVec calls in my code, but I specifically want to
>> port just one call.
> You can give that one matrix an options prefix to isolate it.
> Thanks,
> Matt
>> Sincerely,
>> Swarnava
>> On Sun, Oct 17, 2021 at 7:07 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> You can do that with command line options -mat_type aijcusparse
>>> -vec_type cuda
>>> On Sun, Oct 17, 2021, 5:32 PM Swarnava Ghosh <swarnava89 at gmail.com>
>>> wrote:
>>>> Dear Petsc team,
>>>> I had a query regarding using CUDA to accelerate a matrix vector
>>>> product.
>>>> I have a sequential sparse matrix (MATSEQBAIJ type). I want to port a
>>>> MatVec call onto GPUs. Is there any code/example I can look at?
>>>> Sincerely,
>>>> SG
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211017/f3a94005/attachment-0001.html>
