[petsc-users] MatVec on GPUs
Sun Oct 17 18:50:14 CDT 2021
On Sun, Oct 17, 2021 at 7:12 PM Swarnava Ghosh <swarnava89 at gmail.com> wrote:
> Do I need convert the MATSEQBAIJ to a cuda matrix in code?
You would need a call to MatSetFromOptions() to take that type from the
command line, and not have
the type hard-coded in your application. It is generally a bad idea to hard
code the implementation type.
> If I do it from command line, then are the other MatVec calls are ported
> onto CUDA? I have many MatVec calls in my code, but I specifically want to
> port just one call.
You can give that one matrix an options prefix to isolate it.
     Matt
> Sincerely,
> Swarnava
> On Sun, Oct 17, 2021 at 7:07 PM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
>> You can do that with command line options -mat_type aijcusparse -vec_type
>> cuda
>> On Sun, Oct 17, 2021, 5:32 PM Swarnava Ghosh <swarnava89 at gmail.com>
>> wrote:
>>> Dear Petsc team,
>>> I had a query regarding using CUDA to accelerate a matrix vector
>>> product.
>>> I have a sequential sparse matrix (MATSEQBAIJ type). I want to port a
>>> MatVec call onto GPUs. Is there any code/example I can look at?
>>> Sincerely,
>>> SG
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211017/1a9f0d5f/attachment.html>
