[petsc-users] MatVec on GPUs
Chang Liu
cliu at pppl.gov
Mon Oct 18 15:42:27 CDT 2021
Hi Matt,
I have a related question. In my code I have many matrices and I only
want to have one living on GPU, the others still staying on CPU mem.
I wonder if there is an easier way to copy a mpiaij matrix to
mpiaijcusparse (in other words, copy data to GPUs). I can think of
creating a new mpiaijcusparse matrix, and copying the data line by line.
But I wonder if there is a better option.
I have tried MatCopy and MatConvert but neither work.
Chang
On 10/17/21 7:50 PM, Matthew Knepley wrote:
> On Sun, Oct 17, 2021 at 7:12 PM Swarnava Ghosh <swarnava89 at gmail.com
> <mailto:swarnava89 at gmail.com>> wrote:
> Do I need convert the MATSEQBAIJ to a cuda matrix in code?
> You would need a call to MatSetFromOptions() to take that type from the
> command line, and not have
> the type hard-coded in your application. It is generally a bad idea to
> hard code the implementation type.
> If I do it from command line, then are the other MatVec calls are
> ported onto CUDA? I have many MatVec calls in my code, but I
> specifically want to port just one call.
> You can give that one matrix an options prefix to isolate it.
> Thanks,
> Matt
> Sincerely,
> Swarnava
> On Sun, Oct 17, 2021 at 7:07 PM Junchao Zhang
> <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
> You can do that with command line options -mat_type aijcusparse
> -vec_type cuda
> On Sun, Oct 17, 2021, 5:32 PM Swarnava Ghosh
> <swarnava89 at gmail.com <mailto:swarnava89 at gmail.com>> wrote:
> Dear Petsc team,
> I had a query regarding using CUDA to accelerate a matrix
> vector product.
> I have a sequential sparse matrix (MATSEQBAIJ type). I want
> to port a MatVec call onto GPUs. Is there any code/example I
> can look at?
> Sincerely,
> SG
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
Chang Liu
Staff Research Physicist
+1 609 243 3438
cliu at pppl.gov
Princeton Plasma Physics Laboratory
100 Stellarator Rd, Princeton NJ 08540, USA
