[petsc-users] [External] Re: request to add an option similar to use_omp_threads for mumps to cusparse solver
Mark Adams mfadams at lbl.gov
Tue Oct 12 12:17:29 CDT 2021
On Tue, Oct 12, 2021 at 11:19 AM Chang Liu <cliu at pppl.gov> wrote:
> Hi Junchao,
> No I only needs it to be transferred within a node. I use block-Jacobi
> method and GMRES to solve the sparse matrix, so each direct solver will
> take care of a sub-block of the whole matrix. In this way, I can use one
> GPU to solve one sub-block, which is stored within one node.
> It was stated in the documentation that cusparse solver is slow.
> However, in my test using ex72.c, the cusparse solver is faster than
> mumps or superlu_dist on CPUs.
Are we talking about the factorization, the solve, or both?
We do not have an interface to cuSparse's LU factorization (I just learned
that it exists a few weeks ago).
Perhaps your fast "cusparse solver" is '-pc_type lu -mat_type aijcusparse'
? This would be the CPU factorization, which is the dominant cost.
> Chang
> On 10/12/21 10:24 AM, Junchao Zhang wrote:
> > Hi, Chang,
> >     For the mumps solver, we usually transfers matrix and vector data
> > within a compute node.  For the idea you propose, it looks like we need
> > to gather data within MPI_COMM_WORLD, right?
> >     Mark, I remember you said cusparse solve is slow and you would
> > rather do it on CPU. Is it right?
> > --Junchao Zhang
> > On Mon, Oct 11, 2021 at 10:25 PM Chang Liu via petsc-users
> > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
> >     Hi,
> >     Currently, it is possible to use mumps solver in PETSC with
> >     -mat_mumps_use_omp_threads option, so that multiple MPI processes
> will
> >     transfer the matrix and rhs data to the master rank, and then master
> >     rank will call mumps with OpenMP to solve the matrix.
> >     I wonder if someone can develop similar option for cusparse solver.
> >     Right now, this solver does not work with mpiaijcusparse. I think a
> >     possible workaround is to transfer all the matrix data to one MPI
> >     process, and then upload the data to GPU to solve. In this way, one
> can
> >     use cusparse solver for a MPI program.
> >     Chang
> >     Chang Liu
> >     Staff Research Physicist
> >     +1 609 243 3438
> >     cliu at pppl.gov <mailto:cliu at pppl.gov>
> >     Princeton Plasma Physics Laboratory
> >     100 Stellarator Rd, Princeton NJ 08540, USA
> Chang Liu
> +1 609 243 3438
> cliu at pppl.gov
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211012/a6880cb4/attachment.html>
