[petsc-users] [External] Re: request to add an option similar to use_omp_threads for mumps to cusparse solver
Chang Liu
cliu at pppl.gov
Tue Oct 12 12:45:08 CDT 2021
Hi Mark,
The option I use is like
-pc_type bjacobi -pc_bjacobi_blocks 16 -ksp_type fgmres -mat_type
aijcusparse -sub_pc_factor_mat_solver_type cusparse -sub_ksp_type
preonly -sub_pc_type lu -ksp_max_it 2000 -ksp_rtol 1.e-300 -ksp_atol 1.e-300
I think this one do both factorization and solve on gpu.
You can check the runex72_aijcusparse.sh file in petsc install
directory, and try it your self (this is only lu factorization without
iterative solve).
Chang
On 10/12/21 1:17 PM, Mark Adams wrote:
> On Tue, Oct 12, 2021 at 11:19 AM Chang Liu <cliu at pppl.gov
> <mailto:cliu at pppl.gov>> wrote:
> Hi Junchao,
> No I only needs it to be transferred within a node. I use block-Jacobi
> method and GMRES to solve the sparse matrix, so each direct solver will
> take care of a sub-block of the whole matrix. In this way, I can use
> one
> GPU to solve one sub-block, which is stored within one node.
> It was stated in the documentation that cusparse solver is slow.
> However, in my test using ex72.c, the cusparse solver is faster than
> mumps or superlu_dist on CPUs.
> Are we talking about the factorization, the solve, or both?
> We do not have an interface to cuSparse's LU factorization (I just
> learned that it exists a few weeks ago).
> Perhaps your fast "cusparse solver" is '-pc_type lu -mat_type
> aijcusparse' ? This would be the CPU factorization, which is the
> dominant cost.
> Chang
> On 10/12/21 10:24 AM, Junchao Zhang wrote:
> > Hi, Chang,
> > For the mumps solver, we usually transfers matrix and vector
> data
> > within a compute node. For the idea you propose, it looks like
> we need
> > to gather data within MPI_COMM_WORLD, right?
> > Mark, I remember you said cusparse solve is slow and you would
> > rather do it on CPU. Is it right?
> > --Junchao Zhang
> > On Mon, Oct 11, 2021 at 10:25 PM Chang Liu via petsc-users
> > <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> <mailto:petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>>
> wrote:
> > Hi,
> > Currently, it is possible to use mumps solver in PETSC with
> > -mat_mumps_use_omp_threads option, so that multiple MPI
> processes will
> > transfer the matrix and rhs data to the master rank, and then
> master
> > rank will call mumps with OpenMP to solve the matrix.
> > I wonder if someone can develop similar option for cusparse
> solver.
> > Right now, this solver does not work with mpiaijcusparse. I
> think a
> > possible workaround is to transfer all the matrix data to one MPI
> > process, and then upload the data to GPU to solve. In this
> way, one can
> > use cusparse solver for a MPI program.
> > Chang
> > Chang Liu
> > Staff Research Physicist
> > +1 609 243 3438
> > cliu at pppl.gov <mailto:cliu at pppl.gov> <mailto:cliu at pppl.gov
> > Princeton Plasma Physics Laboratory
> > 100 Stellarator Rd, Princeton NJ 08540, USA
> Chang Liu
> +1 609 243 3438
Chang Liu
+1 609 243 3438
cliu at pppl.gov
