[petsc-users] request to add an option similar to use_omp_threads for mumps to cusparse solver
Junchao Zhang junchao.zhang at gmail.com
Tue Oct 12 09:24:17 CDT 2021
Hi, Chang,
   For the mumps solver, we usually transfers matrix and vector data within
a compute node.  For the idea you propose, it looks like we need to gather
data within MPI_COMM_WORLD, right?
   Mark, I remember you said cusparse solve is slow and you would rather do
it on CPU. Is it right?
--Junchao Zhang
On Mon, Oct 11, 2021 at 10:25 PM Chang Liu via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> Currently, it is possible to use mumps solver in PETSC with
> -mat_mumps_use_omp_threads option, so that multiple MPI processes will
> transfer the matrix and rhs data to the master rank, and then master
> rank will call mumps with OpenMP to solve the matrix.
> I wonder if someone can develop similar option for cusparse solver.
> Right now, this solver does not work with mpiaijcusparse. I think a
> possible workaround is to transfer all the matrix data to one MPI
> process, and then upload the data to GPU to solve. In this way, one can
> use cusparse solver for a MPI program.
> Chang
> Chang Liu
> Staff Research Physicist
> +1 609 243 3438
> cliu at pppl.gov
> Princeton Plasma Physics Laboratory
> 100 Stellarator Rd, Princeton NJ 08540, USA
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211012/27cdc90d/attachment.html>
