[petsc-users] Error "Attempting to use an MPI routine before initializing MPICH" after compiling PETSc with Intel MPI and GCC
Stefano Zampini
stefano.zampini at gmail.com
Mon Oct 11 07:24:44 CDT 2021
You are most probably using a different mpiexec then the one used to compile petsc.
> On Oct 11, 2021, at 3:23 PM, Roland Richter <roland.richter at ntnu.no> wrote:
> I tried either ./ex19 (SNES-example), mpirun ./ex19 or mpirun -n 1 ./ex19, all with the same result.
> Regards,
> Roland
> Am 11.10.21 um 14:22 schrieb Matthew Knepley:
>> On Mon, Oct 11, 2021 at 8:07 AM Roland Richter <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>> Hei,
>> at least in gdb it fails with
>> [Inferior 1 (process 7854) exited with code 01]
>> (gdb) backtrace
>> No stack.
>> What were you running? If it never makes it into PETSc code, I am not sure what we are
>> doing to cause this.
>> Thanks,
>> Matt
>> Regards,
>> Roland
>> Am 11.10.21 um 13:57 schrieb Matthew Knepley:
>>> On Mon, Oct 11, 2021 at 5:24 AM Roland Richter <roland.richter at ntnu.no <mailto:roland.richter at ntnu.no>> wrote:
>>> Hei,
>>> I compiled PETSc with Intel MPI (MPICH) and GCC as compiler (i.e. using
>>> Intel OneAPI together with the supplied mpicxx-compiler). Compilation
>>> and installation worked fine, but running the tests resulted in the
>>> error "Attempting to use an MPI routine before initializing MPICH". A
>>> simple test program (attached) worked fine with the same combination.
>>> What could be the reason for that?
>>> Hi Roland,
>>> Can you get a stack trace for this error using the debugger?
>>> Thanks,
>>> Matt
>>> Thanks!
>>> Regards,
>>> Roland Richter
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20211011/a19f8029/attachment.html>
